Triumph TT600 - Misfiring - we have a diagnosis!
dextersaurus
PostPosted: 15:24 - 18 May 2011    Post subject: Triumph TT600 - Misfiring - we have a diagnosis! Reply with quote
So, just in time for the BCF BBQ, the bike has decided to be an absolute bastard.
Went out for a run today, noticed it struggled to start but put it down to not been run in the past few days.
Took it to the triumph garage to get the fuel mapping sorted out, and noticed on the way there the idle speed was just below 1k RPM...
Then the fuse for the headlight blew.
Then the fuse for the indicators blew.
Then i noticed a burning smell.
Perfect, it's happening again.
They plugged it in, nothing. wouldn't pick up anything from the ECM. The guy told me 'there's a wiring fault, you'll have to sort it out, we can't do anything.'
Problem is the generator/stator coil putting too much into the reg/rec and it's melted the wiring loom. again.
So to fix this, am i correct in thinking i need to buy a new stator coil, new loom, and new reg/rec?
That'll come to just under £200 for the lot, so if i'm right, i'll get buying.
Dunc
PostPosted: 15:49 - 18 May 2011    Post subject: Reply with quote
My Speed Four had a fault in the wiring loom. Apparently there is a front loom and a rear loom. My fault was with the front loom, and so I bought one from a breakers and had it fitted by Triumph.
So, you only really need to buy half a wiring loom rather than a whole one, unless of course the entire thing is melted.
dextersaurus
PostPosted: 15:52 - 18 May 2011    Post subject: Reply with quote
It's the rear part, the bit that runs behind the engine to the injectors.
Nightmare.
Can get a whole loom, with alarm, for £40.
Edit: forgot to mention, it's not a standard reg/rec in the bike. not sure what it's from, but it's higher rated anyway. non-standard wiring from my alarm too, and you can see where there's been the wires from the alternator cut before to join up the new reg/rec.
Dunc
PostPosted: 15:58 - 18 May 2011    Post subject: Reply with quote
Nightmare.
Dunc
Thats a shame, I think I threw an entire rear loom away!
ThoughtContro...
PostPosted: 16:03 - 18 May 2011    Post subject: Reply with quote
Dunc, the stator is only a series of windings of some copper wire wound round a soft iron former to increase inductance. If it's the right one for the bike, and it's been wound correctly out the factory then how can it be putting out too many volts for the Reg/Rec? The Reg/Rec is designed to dump any excess voltage the Alternator windings produce, that's a part of it's job of regulation. Failures in the stator are going to be either dead windings or a physical breakdown in the enamel covering causing the windings to become ineffective. Both of these would usually result in reduction of alternator voltage, not an increase.
Either the Triumph Reg/Recs are utter shit or their wiring is made by Italians causing the Reg/Rec to short out and burn up. I hope you just replaced those fuses that blew and not shorted them out (?), as that is the worst thing you can do.
Check the resistance of each of your stator windings to see if they're in spec, and the output of the same. Unless there is some mad measured output voltage that's way out of spec, I'd suspect the wiring loom and the Reg/Rec were the primary culprits. The stator is probably fine unless you've been giving it too much Irn Bru Wink
Just a guess.You have got their Service Manual or Haynes for the bike?
Prize cunt
ThoughtContro...
PostPosted: 16:08 - 18 May 2011    Post subject: Reply with quote
Why did they have to cut the wires from the alternator?
I'd really suspect either the odd wiring and/or the unknown Reg/Rec
Prize cunt
dextersaurus
PostPosted: 16:10 - 18 May 2011    Post subject: Reply with quote
I see... i'm just going by what i've been told.
The bike has been dropped on both sides, judging by the state of the covers, and is leaking oil from the left side cover, so i'm guessing someone's had that off to get to the stator and not bothered with a gasket.
I don't have the time or tools right now to get in and test the resistance on the stator, i'd rather spend the money on a new one now and not worry about it...
It had this problem with the last owner, who, instead of replacing, had it repaired with an upgraded reg/rec. wires melted due to the problem.
Would you recommend, since i have the money, to just buy the new parts and see if that fixes it? if not, i can sell the old parts anyway.
Of course i replaced the fuses Laughing
Couldn't remember fuse the indicators took, so put a 10 in, that blew... put a 15 in, that blew, then put a 20 in, and that blew too. so i've left it with no fuse so no indicators, and no headlight.
Not going to use the bike again till this is fixed.
Dunc
dextersaurus
PostPosted: 16:11 - 18 May 2011    Post subject: Reply with quote
i'll get some pictures for you. Gimme a half hour.
Dunc
ThoughtContro...
PostPosted: 16:30 - 18 May 2011    Post subject: Reply with quote
If you had a short that's killing fuses and you upped the 10A fuse too 20A, then you definitely fried your loom and made any shorts or wiring faults much worse. If the wiring is only rated for 10A, sticking a 20A in is like turning up the heat to supermelt. The shorts could have fried the Reg/Rec good and proper, if it wasn't already FUBAR.
You should be able to measure stator resistance from the wiring connection to Reg/Rec. Just disconnect the connector and measure across the three windings. They should all measure in the same ballpark, probably less than an Ohm. 1(overrange) is a dead winding or the wiring to it is broken. 0.0 is a shorted winding. You'll need a cheap multimeter tho, from Maplins or elsewhere.
If you've got the cash, and can afford it, I'd replace the lot if you suspect the stator is dodgy.
Prize cunt
dextersaurus
PostPosted: 16:50 - 18 May 2011    Post subject: Reply with quote
Right. stripped the rear end to get to it, so piccies.
Reg/rec
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0985.jpg?t=1305733580
Wiring from the reg/rec
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0986.jpg?t=1305733581
Wiring that leads to the bit that was cut
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0987.jpg?t=1305733720
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0988.jpg?t=1305733726
Alarm wiring
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0989.jpg?t=1305733726
WTF is this for?
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0990.jpg?t=1305733728
numbering on the reg/rec
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0991.jpg?t=1305733780
Hope that clears it up a bit.
Dunc
dextersaurus
PostPosted: 16:59 - 18 May 2011    Post subject: Reply with quote
some job, isn't it.
Sad
ThoughtContro...
PostPosted: 17:25 - 18 May 2011    Post subject: Reply with quote
The top yellow and black wires at the clear connector. Is that dirt, oil and crud or burned insulation?
If you've got a meter you should be able to test the alternator from that connector. There's a TT600 Service manual on Scribd
Disconnect any lighting fuses before running to minimise any more stuff getting fried.
Prize cunt
dextersaurus
Last owner said he took it to a GARAGE to get someone to do it.
If i saw that, i'd be telling them to either fix it, or pay for a replacement loom.
Looks like i'll be buying a new loom anyway.
But as in the pictures, anyone able to tell me what that connector is for, and why it's not connected to anything, and also where those yellow wires go?
Dunc
PostPosted: 17:27 - 18 May 2011    Post subject: Reply with quote
Mr Dunkable wrote:
Dunno, but my S4 had a spare what looked like injector connector like that. Never found out what it is for.
dextersaurus
PostPosted: 17:30 - 18 May 2011    Post subject: Reply with quote
TC, i have no idea, never saw it till you mentioned it there.
I don't have a meter at the moment, but i'll be getting one soon enough. get paid on friday so i'll be buying stuff then.
Got a link for that service manual?
dunc
Marjay, it might just be some kind of emissions thing for other countries then.
ThoughtContro...
PostPosted: 17:35 - 18 May 2011    Post subject: Reply with quote
...and also where those yellow wires go?
Is it possible that if a garage (or spanner monkey) has replaced the stator in the past, that the cut off yellow wiring is the original wiring that they've just left in situ, where it was neatly tidied away, and cut off either end? Where does the other end of that tubing it's in go to?
Prize cunt
MattJ
PostPosted: 17:42 - 18 May 2011    Post subject: Reply with quote
Get a CG Thumbs Up
HTH
dextersaurus
PostPosted: 17:57 - 18 May 2011    Post subject: Reply with quote
I'll explain with the use of THIS!
https://i624.photobucket.com/albums/tt325/duncdmc/DSCF0987-1.jpg?t=1305737692
Yellow is the wires that go to the reg/rec. These would have been the 3 yellow wires in the red circle.
The ones in the BLUE circle go to the genny. The ones in the red circle just go into the loom, didnt get a chance to trace them.
Dunc
ThoughtContro...
PostPosted: 17:59 - 18 May 2011    Post subject: Reply with quote
https://www.scribd.com/doc/1014488/Triumph-TT-600-03
Prize cunt
ThoughtContro...
PostPosted: 18:07 - 18 May 2011    Post subject: Reply with quote
Dunc
OK, makes sense. I'd suspect the 3 yellows in the red circle are old Reg/Rec input wires, from when it was last replaced.
Prize cunt
dextersaurus
PostPosted: 18:11 - 18 May 2011    Post subject: Reply with quote
New wiring loom is in the post, with the alarm.
Think i'll pull the flywheel and stator coil so it's ready to just go straight in when i get the new one, and i'll get the wiring tidied up for then.
Hopefully fixes my problems Rolling Eyes
Dunc
ThoughtContro...
PostPosted: 18:36 - 18 May 2011    Post subject: Reply with quote
When you get the new loom in, I'd test it all thoroughly with a meter before going out on any long rides.
Cant find any datasheet on FH008EC Regulator. It looks like FH008EB were fitted to later CBR600 and CBR1000RR and are rated at 35A. Maybe EC is a later revision? Current Shindengen production unit is FH012, rated at 50A.
Should be up to the job I'd have thought, if it isn't fried.
Prize cunt
dextersaurus
PostPosted: 18:46 - 18 May 2011    Post subject: Reply with quote
Might just keep this reg/rec then. i'll be sorting out that bloody wiring though.
So, change stator coil, sort wiring out, wire up reg/rec to new loom PROPERLY.
Dunc
ThoughtContro...
PostPosted: 18:51 - 18 May 2011    Post subject: Reply with quote
So, change stator coil, sort wiring out, wire up reg/rec to new loom PROPERLY, AND TEST ALL OUTPUTS THOROUGHLY ON MY NEW METER.
Dunc
FFA
Razz
Prize cunt
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 0.99 - MySQL Queries: 16 - Page Size: 145.49 Kb
