Anyone know what this is? Cat Valve
Shaft
PostPosted: 22:14 - 24 May 2011    Post subject: Anyone know what this is? Cat Valve Reply with quote
I posted this pic in my 'show & tell' moped project thread, but I wondered if I might get a better response here:
https://img69.imageshack.us/img69/3286/artycopy.jpg
I have very little experience with modern bikes in general and scooters in particular, so this has got me stumped.
The armoured hose appears to run to the airbox, so I'm guessing it's some kind of emissions gubbins, but there's no electrical connections, so whatever is in that box must be heat/pressure operated.
I was planning on changing the exhaust, but would removing this alter the way the bike runs and what would I do to rectify it?
Sorry if I'm asking the bleeding obvious, but I've not come across anything like this before.
Fisty
PostPosted: 22:17 - 24 May 2011    Post subject: Reply with quote
Its a very rare platinum powerband.
Fatter and faster than Fret
Shaft
PostPosted: 22:19 - 24 May 2011    Post subject: Reply with quote
Ho bloody ho Laughing
heehaw
PostPosted: 23:01 - 24 May 2011    Post subject: Reply with quote
well, it was...
Its important, otherwise it wouldn't be there.
Retro Rider Bicycles: CB125TDC, CBR400RR, BSA Bantam.
Shaft
PostPosted: 23:04 - 24 May 2011    Post subject: Reply with quote
Eh?
Confused
Shaft
PostPosted: 20:04 - 25 May 2011    Post subject: Reply with quote
rob yarrr wrote:
it might be a emmissions thing that sends cool air from the airbox in to the exhaust to lean it out abit
the box probs has some sort of diapram in
Turns out we guessed right.
Quite by accident, I found a picture of the same piece of kit and it is indeed a 'cat valve', some sort of Mickey Mouse emissions device.
I neither know nor care what goes on inside it, but it's going in the skip.
Cheers all.
PostPosted: 20:58 - 25 May 2011    Post subject: Reply with quote
It's a valve for pumping fresh air out of the airbox into the exhaust to supply oxygen for burning off any un-spent fuel. Has no effect on engine performance.
Shaft
PostPosted: 21:17 - 25 May 2011    Post subject: Reply with quote
Thanks for the explanation Pete, the only thing I've seen like it is on old Yank car engines, where they used to fit all sorts of Heath Robinson contraptions, usually with devastating effects on performance.
If there's that much fuel in there, I might tap it for a spark plug Twisted Evil
PostPosted: 21:41 - 25 May 2011    Post subject: Reply with quote
Aye. Also called a passive air valve. Bleeds air into the exhaust to reduce emissions.
They sometimes have a vacuum takeoff from the carb to open and shut the valve. Remember to blank this off if you remove it or you'll run lean.
The last post was made 15 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 16 - Page Size: 70.77 Kb
