| Poseidon |
 Poseidon World Chat Champion
 Posted: 20:23 - 25 Jun 2011 Post subject: Araldite fork pitting fix |
Quick advice from the folks out there who are familiar with this bodge...
I've removed the forks, removed all the dirt and grease using brake cleaner followed by white spirits. I've pain stakingly picked out all the crud from the little pits and given them another wipe over with white spirits. I've then filled each of the pits with a small amount of araldite precision (the 24hr setting stuff) and they're currently curing.
I have some 800grit wet&dry, some 1500grit wet&dry, some fine finishing cloths, some autosol and some polishing cloths, so I have everything to get the forks back to a baby's bum smoothness.
My question is, I've heard that polishing the forks once they're smooth is a good idea, now obviously the autosol is a polish, but is it worth putting something a bit more hard wearing on there, for example, I have some autglym extra gloss protection which claims to be a "semi-permanent" barrier. I've used it on the car on top of normal polish and it does a great job of protecting the paint work, so is it worth giving the forks a couple of layers of this gloss to reduce friction/increase protection, or should I leave it after the autosol?
This is the autoglym stuff... Note, it's not to be confused with polish... It is purely a gloss layer:
https://www.holden.co.uk/productImageslTitled/Autoglym_Extra_Gloss_Protection_325ml_090.889.jpg
Product description here: https://www.autoglym.com/enGB/product-proddetail.asp?v06VQ=FH ____________________ 1977 Honda CG125
2002 Ducati Monster S4 (currently restoring) |
| LongJohn22 |
 LongJohn22 Trackday Trickster
| Ichy |
 Ichy World Chat Champion
| Poseidon |
| Poseidon |
| Ichy |
 Posted: 21:29 - 25 Jun 2011 Post subject: |
Doesn't really serve any purpose. Use it if it makes you feel better. BTW when I sand them I prefer to use an up down motion as opposed to around the tube. Makes sense to me to go with the normal movement of the stanchion. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Poseidon |
| neil. |
 neil. World Chat Champion
 Posted: 23:13 - 25 Jun 2011 Post subject: |
Would recommend fitting gaiters when you put it all back together for really good protection.  |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Pete. |
 Pete. Super Spammer
 Posted: 08:49 - 26 Jun 2011 Post subject: |
I don't think there's much point polishing the stanchions after using 1500 paper. They will get either polished or scored in use by the fork sliding bushes. ____________________ a.k.a 'Geri'
| Poseidon |
 Posted: 21:29 - 26 Jun 2011 Post subject: |
Okay, bar a small pit or two on each stanchion, they are now smoother than glass. I've gone for another round of araldite on the remaining little blemishes and hopefully by this time tomorrow, both stanchions will be 100% silk-like.
Pete you were right, after removing the excess with the 800, I gave them a good stroking with the 1500 and it returned to a mirror finish, so the autosol is not really necessary.
So far I'm incredibly impressed with the finish this has given the forks, however does anyone know how long this repair will last? I've got some gaiters on my wish list, which will obviously protect the repair from most dangers, but even so, rubbing through the fork seals must take it's toll... Anybody have actual experience of this repair and know how long it will last?
Many thanks
Poseidon ____________________ 1977 Honda CG125
| Pete. |
 Pete. Super Spammer
 Posted: 21:34 - 26 Jun 2011 Post subject: |
Should last a long time TBH. Easily long enough for you source some more stanchions. ____________________ a.k.a 'Geri'
| Poseidon |
The last post was made 15 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
