GPZ500 Fails to start (it usually does)
FenSean
PostPosted: 13:59 - 06 Jul 2011    Post subject: GPZ500 Fails to start (it usually does) Reply with quote
I have usually reliable GPZ500. It has always started when battery is ok. New battery charge. Nothing. Electrics are on. Nothing.
Could any one advise me.
Do I > Check if there is any DC current going down to staring-Motor on relay/Switch supplying electric to S-Motor
(When battery is flat, this relay normally clicks.)
PostPosted: 14:42 - 06 Jul 2011    Post subject: Reply with quote
Checked the usual noddy stuff? It's not in gear, the battery earth is OK, you haven't blown a fuse?
FenSean
PostPosted: 15:01 - 06 Jul 2011    Post subject: Reply with quote
Yes, just spoke with bike shop. I'm getting from top of solenoid 12volts reading, continuously. (1 lead from battery, one lead out to S-motor). This appears wrong? Test done by M-Meter on top of sole-terminals.
I also placed meter on terminals entering S-motor and pressed start button. No voltage present. I also checked the fuses in box.
Stelmer
PostPosted: 15:09 - 06 Jul 2011    Post subject: Reply with quote
I've heard of a worn ignition switch causing the warning lights to work but not the starter button.
FenSean
PostPosted: 15:17 - 06 Jul 2011    Post subject: Reply with quote
No, Their is a relay switch click noise from fuse box, its faint, but there.
thanks anyway
PostPosted: 15:46 - 06 Jul 2011    Post subject: Reply with quote
With your multimeter. You should check for voltage between each post and earth rather than between the two posts. There should be 12v at one and nothing at the other.
Try shorting between the two terminal posts on the solenoid with an old screwdriver (you ought to get sparks and suchlike so don't panic if you see them). The starter motor should turn when you do so.
If it does, there is a fair chance the solenoid is duff. I've had two of those ones go over the years.
If it doesn't there is a problem with the starter motor or its connectors (assuming the battery is ok).
Also check inside the block connector on the solenoid (which holds the main fuse) for signs of corrosion.
Macie_UK
PostPosted: 15:49 - 06 Jul 2011    Post subject: Re: GPZ500 Fails to start (it usually does) Reply with quote
The starter relay [1] played up on both of my GPzs, causing similar grief. With the ignition switched on, use a screwdriver to bridge the 2 big posts on the relay - if it turns the engine over you have just found the culprit.
[1] There are actually 2 starting relays on the GPz500s - the one I'm referring to here is mounted on the LHS frame a couple of inches rearward from the battery. The *other* starting relay is housed inside the junction/fuse box thing and if that is the problem you have to replace the whole junction box, but that is much less likely to fail.
HTH
Macie
Current: Triumph TT600
Most Missed : TZR250 (for laughing like a loon) | MZ Baghira 660 | ZZR600E1 (for everything else)
PostPosted: 15:58 - 06 Jul 2011    Post subject: Re: GPZ500 Fails to start (it usually does) Reply with quote
You can take the PCB out of that junction box and solder in a new microrelay if one goes duff. Nobody was more surprised than me when I found that one out because it looks like a sealed unit at first glance. Mine started working again when I flicked the relay with my fingernail though.
FenSean
PostPosted: 08:59 - 07 Jul 2011    Post subject: Reply with quote
Thanks guys, that is very helpful, I will do the bridge test and see if the starter responds. Cheers
FenSean
PostPosted: 09:17 - 07 Jul 2011    Post subject: Reply with quote
Well thanks guys, (stinkwheel), you have made a nervous man happy.
I did the bridging terminal test on the side solenoid and sparks flew and the motor turned over. Phew.
I will now seek to get a replacement part. They are about a tena only.
The last post was made 14 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 16 - Page Size: 66.1 Kb
