Yam FZR1000 RU - any good for commuting
Mrjoolz
PostPosted: 17:13 - 27 Jul 2011    Post subject: Yam FZR1000 RU - any good for commuting Reply with quote
One for sale at £1350 with 49k on it. Is it worth a look for commuting. Reliability issues?
PostPosted: 17:26 - 27 Jul 2011    Post subject: Reply with quote
Thirsty... I wouldnt like to commute on that, especially if its to save some more of money..
Go sit on it and see if its comfortable..
PostPosted: 17:31 - 27 Jul 2011    Post subject: Re: Yam FZR1000 RU - any good for commuting Reply with quote
The main issue with FZR1000s is the patented Yamaha InstaRust(TM) Downpipes which rust through if you breathe on them. The downpipes and collector box not only rust, but it is very very hard to get replacements for them which is why you don't often see FZR's for sale. Well, you do but usually for about £400 with no MOT.
Eddie Hitler
PostPosted: 22:15 - 27 Jul 2011    Post subject: Reply with quote
Have a link? Personally wouldn't spend that much.
Not sure about the rust problem you mentioned MarJay? Unless it's the EXUP valve you're referring too, as they do jam up and rust and are a total bitch to sort out. Ended up chucking mine in the bin, hardly affected the engine IMO.
They are solid bikes, bought mine for £600, used and abused with very long trips, London commutes and all sorts, sold for £400 4ish months later. Needed new tyres.. brakes.. everything. Laughing
Only thing I would watch out for are consumables, they do cost alot for the fzr. The only 1 thing I spent on that bike (apart from fuel) was some chain and sprockets. £170 from what I remember. The rear sprocket bolt had siezed, so had to take it to a garage to sort out. Shocked . Although same can be said for alot of big bikes. I'd say go for it, only if that comes down in price. No way for a 49k bike.
PostPosted: 23:09 - 27 Jul 2011    Post subject: Reply with quote
Also not sure on rusting pipes (based on the 20 year old Yamaha pipes on my Bimota, although it has had an easy life), although the EXUP valve does seize up.
For commuting around town I would think it would be a bit heavy and low bared, and with a weak clutch (although easy to change). Some seem to burn a fair bit of oil. Shimmed valves which should rarely need to be touched.
Few bits seem to have started to become unavailable new.
PostPosted: 09:39 - 28 Jul 2011    Post subject: Reply with quote
BLUEX5 wrote:
The downpipes are still available new. Parts lists - learn to use them.
Maybe but when two EXUP valve bushes and a gasket come to £90 on my FZR400... you'd expect them to be very expensive.
PostPosted: 11:12 - 28 Jul 2011    Post subject: Reply with quote
Quick check on Ron Ayers and a full set of downpipes are $1090. That includes the EXUP valve, bushes, etc. The EXUP valve on its own is $249.
Tenko
PostPosted: 12:34 - 28 Jul 2011    Post subject: Reply with quote
Some here will hate me for this... lol
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320732665162&ssPageName=STRK:MESELX:IT
No exup to worry about and just fitted recon (perfect nick) downpipes.
PostPosted: 12:46 - 28 Jul 2011    Post subject: Reply with quote
IIRC don't these drink oil like no tomorrow?
1300 seems a lot for a 20 year old bike with 50k on the clock
PostPosted: 12:51 - 28 Jul 2011    Post subject: Reply with quote
Some of them do use a bit, but seems pretty variable. The Bimota (early FZR1000 EXUP engine) doesn't really use much at all (good job as it is a git to get the fairing panel off to just top the oil up).
Al
PostPosted: 19:05 - 28 Jul 2011    Post subject: Reply with quote
The downpipes did fall apart on my FZR but they were the originals as far as I know and 15yrs old so that doesn't seem too bad to me.
I just dumped the exup valve and fitted some cheap stainless ones.
They've made it loss a bit of its low/mid range (not dynoed, just from feel) but this is a 400 which has hardly any low/mid range to start with. I doubt you'd really notice on a 1000.
Yamaha FZR400RR 3tj
My Instagram Thingy
temeluchus
PostPosted: 20:56 - 28 Jul 2011    Post subject: Reply with quote
I had an earlier fzr1000 exup, replaced a leaky original pipe with anftermarket pipe that did not have an exup valve. Lost a bit in the midrange but not enough to cause issues.
Make sure that the valve clearances have been done-they don't need doing that often (every 15-20k I think) but by 60k they almost certainly will need looking at.
Most people put it off as it is a big job with 20 fiddly shims to muck around with. Being quite a complicated head design with shims under buckets it wasn't fun.
The last post was made 14 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.28 - MySQL Queries: 16 - Page Size: 88.1 Kb
