URGENT UPDATE - Quick MOT questions
PostPosted: 17:17 - 03 Aug 2011    Post subject: URGENT UPDATE - Quick MOT questions Reply with quote
Hate asking dumb questions Laughing
Basically 0l0dom0l0 has been a gem and sent me a 110 70 17 tyre for the rear of my 125.
Thing is... its a Bridgstone BT***F (dont know the model) Does the F mean front.. If so should I remove it from the tyre or leave it? Its a tubed rim a tubeless tyre, bare in mind this is just to get a years ticket on it.. its not being used all the time...rough weather/winter etc...
Also, in terms of rust... general surface rust is alright yeah? I've never really had an MOT on any bike.. never had them long enough Laughing
Everything else works, lights, plate is legal, horn I will double check... but the engine has just been rebuilt.. so hoping it lives Laughing
The rear shock isnt "bouncy" its pretty stiff but does compress etc, is there a set limit?
Martay
PostPosted: 18:45 - 03 Aug 2011    Post subject: Reply with quote
When i took the bike in for a leaky tyre seal, he put a tube in the tubless tyre. He MOT'd it at the same time no probs. HTH
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
PostPosted: 18:54 - 03 Aug 2011    Post subject: Reply with quote
At a guess, Bridgestone battlax BT45F?
In which case, yes it's a front and no it shouldn't pass its MOT with a front tyre on the rear.
That said, this is assuming they notice.
It's fine with a tube in though.
Another point. If it's a BT45, it's a bias belted tyre. It's flat-out illegal to have a bias belt rear with a radial front. This more than anything would fail an MOT so if the front is a radial and the rear is a BT45, it's illegal. If there is an 'R' in the size code of the front tyre, it's a radial (eg 90/90R17).
PostPosted: 20:39 - 03 Aug 2011    Post subject: Reply with quote
Not a BT45 for definite...
In fact... cant recall what it is.. might not even be a bridgestone.. a quick FB brings me this image https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/281517_10150250987097167_598102166_7831582_2179077_n.jpg
clancy
PostPosted: 20:46 - 03 Aug 2011    Post subject: Reply with quote
dont think thats bridgestone, looks more like a pirelli tread pattern
could be wrong
KLX 300r
clancy
PostPosted: 20:48 - 03 Aug 2011    Post subject: Reply with quote
tell a lie 99% sure its bridgestone bt 020
KLX 300r
clancy
PostPosted: 20:52 - 03 Aug 2011    Post subject: Reply with quote
Rob Fzs wrote:
same pattern as the battlax 020 on the front of my fazer
boom, thought i was right Cool
KLX 300r
PostPosted: 09:22 - 05 Aug 2011    Post subject: Reply with quote
Righhhhhhhhht.
I was unaware the tyre says front use only Laughing Can I remove this with a bit of skill and attempt to get it through the MOT. If so what methods?
Its only to get a years MOT on it, then its getting its more offroad tyres put back on.
Also its a 110 70 R 17
dogbot
PostPosted: 11:46 - 05 Aug 2011    Post subject: Reply with quote
Doesn't an R on the tyre sidewall mean "Radial"?, for the construction type?
https://en.wikipedia.org/wiki/Tire_code#Explanation_of_tire_codes
PostPosted: 12:14 - 05 Aug 2011    Post subject: Reply with quote
Yes, sorry just clarifying for Stinkwheel.
Must NOT have radial tyres on the front wheels and cross ply tyres on the rear wheels, it is also illegal to have a cross ply tyre on one side with a radial on the other.
I take it me having a rear radial is fine then? I think the front is cross ply... Laughing
dogbot
PostPosted: 12:18 - 05 Aug 2011    Post subject: Reply with quote
If they're different constructions (ie, one radial, one cross ply), it should fail, I believe
PostPosted: 12:39 - 05 Aug 2011    Post subject: Reply with quote
My old bike had a BT45 front and Avon rear
dogbot
PostPosted: 12:43 - 05 Aug 2011    Post subject: Reply with quote
a) those are different manufacturers, not necessarily different construction types and
b) *should*, not "will".
It's actually potentially quite dangerous. Back when I were a kid...
https://www.youtube.com/watch?v=c23MFIKiVdE
PostPosted: 12:53 - 05 Aug 2011    Post subject: Reply with quote
Sorry, hit enter too fast.
Im sure the tyre place said they were mixed. I never noticed any ill effects?
PostPosted: 12:58 - 05 Aug 2011    Post subject: Reply with quote
Radial rear and radial, bias belted or cross ply front is fine. Bias belted rear is fine with a bias belted or cross ply front.
Some bikes have been sold new with radial rears and cross ply fronts as standard fitment.
Paddy - your front tyre should fail the MOT I think, and if you try and chop away the marking showing it to be a front tyre they might just fail it for the damage.
PostPosted: 13:26 - 05 Aug 2011    Post subject: Reply with quote
Just being picky now.. but whats the difference between the front and rear fitment... does it really affect it that much?
I could POSSIBLY get a 100 80 17 from my CBR on the back... but thats major effort Laughing
PostPosted: 14:37 - 05 Aug 2011    Post subject: Reply with quote
Direction of the tread pattern mainly I think. But also the plies inside the tyre might be different.
PostPosted: 17:30 - 05 Aug 2011    Post subject: Reply with quote
I've seen people skim off 'not for road' use from a motocross tyre to use it for greenlaning etc.
Do it carefully and it's hardly noticeable, it would seem!
PostPosted: 17:38 - 05 Aug 2011    Post subject: Reply with quote
Like, i'll try getting rid of it... any idea what the best way to go about it is?
PostPosted: 20:02 - 05 Aug 2011    Post subject: Reply with quote
Its all rubbed off... tyre looks normal Laughing
PostPosted: 11:33 - 12 Aug 2011    Post subject: Reply with quote
Bikes going in for MOT in like half hour... shall let you know the outcome..
I have ridden it up and down the road, figured insuring it would be safer than doing nothing at all Laughing Handles ok, the rear tyre went on ok being a 110 70 rather than a 100 90.
Unsure of what pressures to run, front felt squishy at 30psi.. maybe im used to riding a sports bike with solid suspension...but the front was a little soft Laughing
Hoping it passes, they passed my "CBR" with wires everywhere, looked terrible, had angle grinder marks over the front and bodged cables... Obviously sending my bike to the same place Mr. Green
PostPosted: 15:17 - 12 Aug 2011    Post subject: Reply with quote
Laughing Failed.
Left handle grip loose.
Shock pivot mount siezed.
Rear tyre incorrect spec.
The handle grip is sorted, the shock has been removed and greased/cleaned and reinstalled. Now for the rear tyre Laughing
The last post was made 15 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.34 - MySQL Queries: 16 - Page Size: 125.25 Kb
