| arsco77 |
 arsco77 L Plate Warrior
| arsco77 |
 Posted: 14:20 - 04 Aug 2011 Post subject: |
After doing some more research, I've come across this setup:
Main Jet: 178
Min Jet: U36
Conical Pin: D53
Throttle Valve: 45 (is that standard?)
And will this be ok for the bike??  |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:54 - 06 Aug 2011 Post subject: |
More to a plug chop than that (need a decent hill to keep enough load on the engine to keep high revs and throttle for a bit), and a grey colour would suggest it is running VERY lean.
Not sure on the jetting of that. No knowledge of the late RS125s with that strange carb. However if you are playing with jets work on the basis that they are cheap and that rich is safe. Go too rich and you will just use more fuel and lose a bit of power (and long term increase wear a bit). Go too lean and a good chance of a seizure.
| arsco77 |
| satelliteone |
 satelliteone Nitrous Nuisance
| Kickstart |
| satelliteone |
 Posted: 12:50 - 09 Aug 2011 Post subject: |
the dtr uses the 28mm mikuni`s.. but have the power thingy doofers and the main jet is 240. , but i cant remember the the size for the non power versions.
i think if i can remember, the air fuel ratio is 14:1 on any rev range, some one put me right please. I think this what your trying to achieve. Any weak air mixture in that, will cause flat spots, most problems are air fuel ratios, at the mid-high rev ranges, this is where your center pin comes in, tapered to effect. also ironing out flat spots. The air pressure around you also effects mixture, but we are trying to find a balance here.
If you running weak at the top, the engine will get hotter, and blow a hole in the pistion as the mix is weaker, and centers in the middle of the piston.
back to the carbs, you say 150 main jet, sounds about right for a CC value of a 125. on a 32-34mm
also depends on the size of the venturi that equates to the main jet sizes,
from experience 125cc, the slow running jets, always sits around the 38-40. Its the mid range to high thats the key size.
if you have the standard data on the 28mm, then go from there, just increase the main jet slightly. depending on your intake airbox or cone filters. piston size..etc..
just another thing, is that the vespa community, use the delorto carbs as a custom upgrades and as standard. and there is plenty of data on the net for these 150cc and 125cc engines. That might give you some idea of jetting. ____________________ Honda XLR125R - Project
TZR125RR Belgarda 4DL - Sold
Chinki Project done n Dusted/sold** DTR125 2003 - Finished/sold |
| Kickstart |
| satelliteone |
The last post was made 15 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
