Modify or upgrade?
T0MMY
PostPosted: 11:30 - 12 Aug 2011    Post subject: Modify or upgrade? Reply with quote
Following a session and conversation with an instructor at Silverstone the other week I'm thinking about either modifying my current track bike or upgrading to something a little more capable. I've currently got a ZX6R G2 which rides pretty well for what it is but is probably nowhere near the handling capabilties of the more modern sportsbikes. The brakes are fine for the job and I'm not fussed that it's way down on power compared to most of the bikes on track but I feel like I'm reaching the limits of the handling already. I can't decide whether it's better to throw some money at it and upgrade the suspension or just sell it and get something like a CBR600RR. I'd also need to get rearsets and raise the exhaust so it could get pretty expensive.
Everyone tells me there is a major step up in how focussed the more modern 600s but I've never ridden anything built in this millenium so I'm not sure how true that is Laughing Would my current bike with a brand new and well setup shock still be way behind an unmodified CBR600RR?
ZX6R + CBR600RR
PostPosted: 12:33 - 12 Aug 2011    Post subject: Reply with quote
It'll be good enough until you're at the top level of the fast group. A suspension refresh probably wouldn't go amiss though.
T0MMY
PostPosted: 12:54 - 12 Aug 2011    Post subject: Reply with quote
Thing is my lines are still not perfect (I've only done 5 trackdays and at 4 different tracks) so I can obviously get much much faster there but after following me round the instructor seemed to think that I couldn't really push it any harder in the corners which was a bit disappointing. Sort of made me feel like I can't really progress in terms of mid corner speed where I'm already grinding the pegs and the bike is really on the edge of grip. My lines will improve with experience no matter what bike I'm riding so that's not really the problem.
ZX6R + CBR600RR
PostPosted: 13:37 - 12 Aug 2011    Post subject: Reply with quote
Sorted suspension won't massively increase mid-corner grip unless it's really bad to start with. (Edit; it may cause the bike to be lower and ground out, but this is a different problem to running out of grip to my mind).
It may help more with grip going in to corners braking and coming out on the power, but to some degree you probably want that to be predictable and with good 'feel' rather than giving you amazing performance.
I think, either way I'd keep an eye out for good second hand deals.
Leave it a bit and there will be a good market on post-season race bikes, etc.
Or try and keep an eye out for some second hand rearsets (could you hang off more as it is?), shock and fork internals.
On that, I've got all three available for a zx9-E Wink, but not sure if they will fit your bike (shock probably will) as got a feeling Kawasaki annoyingly did a few things slightly differently between the 6 and 9, despite them being pretty similar.
MarkJ
PostPosted: 13:38 - 12 Aug 2011    Post subject: Reply with quote
What track and how fast were you going with the instructor behind?
If it's really bottoming out you could give it some new springs and a rear shock. Maybe some higher rearsets if those ones are quite low. What tyres are you using and what does the rear tyre look like after a trackday, chewed up or nicely grained?
T0MMY
PostPosted: 14:08 - 12 Aug 2011    Post subject: Reply with quote
This was at Silverstone and I got a session with him very early in the day as I didn't know the lines at all. He basically said that there were many parts of the track where I hadn't got the right lines which he helped me with but that in the bits where I'd got to grips with the track I wouldn't want to be going any faster given the bike I was on. In terms of speed, I felt like I was going pretty slow as I was totally out of sorts due to not knowing the track but I would say I was in the upper third of the fast group maybe...hard to say as it's such a fast track and I was getting left for dead down the straights by nearly everything. Also, I don't have tyre warmers so by the end of the first lap all the bikes that do (90% at least it seems) are long gone whilst I get some heat into the rubber.
Here's a couple of videos. The first one was a restarted session due to a crash so everyone was on cold tyres and I stayed with the pack through the first lap for once...
https://www.youtube.com/watch?v=V8z6jJ8Ci68
This session I went out near the front and after a couple of faster guys passed me I had clear track so my last lap is probably about as quick as I was all day.
https://www.youtube.com/watch?v=_d2oJLFPmXo
I kept confusing the two pit straights and taking the wrong line into the new one and also I had trouble getting gears sometimes as my gearbox doesn't seem to like the oil I put in it recently Rolling Eyes
As for body position, I perhaps could hang off a little more but not a lot I don't think. Found these pics of the day but I'm too scabby to buy them Laughing ...
https://www.peterwilemanphotography.com/main/index/detail/1614070
https://www.peterwilemanphotography.com/main/index/detail/1612753
Looks like my head could be lower although on the corners where ground cleaance becomes a real issue I think I do pull myself more towards the inside of the corner.
ZX6R + CBR600RR
T0MMY
PostPosted: 14:22 - 12 Aug 2011    Post subject: Reply with quote
Here's a photo from Rockingham too...seems like my head is still too high so maybe that is something I need to work on...
ZX6R + CBR600RR
PostPosted: 14:26 - 12 Aug 2011    Post subject: Reply with quote
Rockingham one doesn't look so bad, but hard to tell from the angles.
However, does look like you are hanging off decently.
If you're finding the power particularly irksome, I reckon you definitely want to make plans to get a more modern bike - however, you can still consider a few bits for current bike (even just some foot peg adapters) which you can hopefully sell on separately when you get rid of the bike.
T0MMY
PostPosted: 14:32 - 12 Aug 2011    Post subject: Reply with quote
I don't mind the lack of power really...the bike felt very slow at Silverstone where you spend a lot of time accelerating from 3 figure speeds but at most tracks it's fine. Only problem is you can't follow a faster rider to learn the lines as if he's the same or faster in the corners he's long gone by the end of the straight Laughing I'm more concerned about the handling.
Forgot to answer the question about the tyres...they're Racetecs (courtesy of Deano) and after a trackday they usually look pretty chewed up with lots of curled rubber at the edges. For some reason at Silverstone the rear looked less chewed and more grained but I think they're starting to harden up as they've done a lot of heat cycles now. They're more blue than usual this time if that means anything and they definitely feel less sticky to the touch than when I first got them.
ZX6R + CBR600RR
PostPosted: 14:41 - 12 Aug 2011    Post subject: Reply with quote
I'd say try new tyres first, then if they don't help take them off and put the scrubs back on so you can use them on your new bike.
But I still reckon your bike has the potential to be better than you are. I'm inclined to think the instructor is talking nonsense anyway. Most trackday instructors appear to give poor or conflicting or misleading instruction anyway. One instructor gave me the sage piece of advice "Trust your tyres more".
PostPosted: 14:51 - 12 Aug 2011    Post subject: Reply with quote
Isn't that what you're saying to Tommy, though Smile.
PostPosted: 15:11 - 12 Aug 2011    Post subject: Reply with quote
No, I'm saying that his tyres might be 'off' and new ones might help. They might provide better 'feel' which you don't believe exists... Wink
Seriously though I've had good instruction from track day instructors, and bad instruction, but I'd have to say on average its not good. The best instruction I've had is at CSS, because their instructors actually know how to explain problems and possible solutions to you. The main issue I find with track day instructors is that they can't actually explain things very well, but they also seem to sometimes give advice which is too advanced for your level.
T0MMY
PostPosted: 15:12 - 12 Aug 2011    Post subject: Reply with quote
I think the Racetecs at their best are as good as I'd ever need the tyres to be and good enough to be at the sharp end of the fast group. I think this set are starting to go off so I will need to replace them anyway soon but I think the weight, ground clearance and suspension of this bike are the bigger factors holding me back.
Obviously my poor lines are what make the biggest difference to lap times and these will improve as I start to learn the tracks but I just feel that I've plateaued a bit compared to the massive improvements in my riding and the higher corner speeds I was suddenly carrying between my first and second trackdays...8 weeks ago I'd never got my knee down (or even tried as I never had a set of leathers Laughing ). I felt like I was getting quicker and quicker and now I've sort of hit a brick wall but I guess that's what happens.
ZX6R + CBR600RR
PostPosted: 15:21 - 12 Aug 2011    Post subject: Reply with quote
Getting in to the fast group in five days (and managing to stay on Wink) isn't bad - but you do have to expect to start slowing down your rate of progress.
A lot of 'lines' is more track positioning - making sure you go right to the outside, then get your knee hanging over the kerb, then right out to the outside again.
I was quite impressed when I watched an onboard video I'd done at Rockingham that while my riding wasn't that fast, I was at least still getting decently close to the edges (ie the the side of the bike was hovering over the middle of the kerbing at the Apex.)
Mine was in relation to your comment on his bike being able to go faster.
MarkJ
PostPosted: 15:39 - 12 Aug 2011    Post subject: Reply with quote
Well you're not hanging about in the corners so if it's acceleration on the straights you want then get a more powerful bike Thumbs Up Getting on the power early and on the most efficient lines will definitely help you keep up with more powerful bikes that haven't done so well coming out of the corners, though.
I certainly improved a lot after my first few trackdays, but then progress seemed to tail off a fair bit. Nowadays it feels like I'm getting worse Neutral
T0MMY
PostPosted: 15:45 - 12 Aug 2011    Post subject: Reply with quote
To be fair I don't think I've really improved that much since my second trackday, or even the last few sessions of my first when the body positioning suddenly clicked. There's a video up on my You Tube channel of my second one at Bedford on my CB-1 and allowing for the slowness of the bike I'm not sure I actually carry any more corner speed now than I did then really.
Trying to use the whole track relies quite heavily on knowing the corner if there's not great visibility (like at Silverstone). To be going fast enough to have to use the whole track on the exit is risky if you forget which corner you're on and how much track you will have on the outside of the corner Laughing The other thing about Silverstone is that it is so wide that it's not always obvious through a series of linked corners where the optimum line is. It would be useful to time myself and try different lines but the organisers wouldn't be very impressed if they saw me doing it!
ZX6R + CBR600RR
LordShaftesbu...
PostPosted: 15:47 - 12 Aug 2011    Post subject: Reply with quote
I'd say get one of these, if only because they look like sex on two wheels.
https://www.bikechatforums.com/files/2011-triumph-daytona-675r-photo.jpg
PostPosted: 15:56 - 12 Aug 2011    Post subject: Reply with quote
Plenty of ways you can time yourself on the sly - video is one of the obvious ones.
And yes, when you're coming out of a corner and think "ohh shit, oh shit oh.... just made it!" then you know you've got the exit just right Razz. (Actually, quite probably a little slow as that suggests you were probably still off the power, when you should have planned to be on the power earlier and kept on it because you were confident of your line Smile.)
Even when you don't HAVE to get right to the outside, it's generally good practice to do so as the bike will be more relaxed so you can get on the power earlier - and just that you're getting used to taking the correct lines.
I haven't done a new track in years now Sad, but even doing Cadwell earlier this year it did take me a couple of sessions to get reasonably close to the Apexes (for me, not compared to some other people there Razz).
I didn't find a big problem with visibility for most of the corners at Silverstone (as opposed to say Paddock Hill at either Brands Hatch or Lydden.)
T0MMY
PostPosted: 16:06 - 12 Aug 2011    Post subject: Reply with quote
I'd be well up for it if I can get one for around the £800 I paid for my current bike Laughing
ZX6R + CBR600RR
The last post was made 15 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 16 - Page Size: 113.26 Kb
