Vacuum Taps.
Moxey
PostPosted: 23:23 - 20 Aug 2011    Post subject: Vacuum Taps. Reply with quote
Simple question really, at a constant high speed of 70+ mph is it possibe for a vacuum petcock to fail provide enough fuel to a 4 cylinder bike (i.e. Bandit) and subsequently lead to loss of cylinders firing due to fuel starvation eventually resulting in the engine stalling?
If so I would like to know why and any known solutions.
Bezzer
PostPosted: 23:41 - 20 Aug 2011    Post subject: Reply with quote
Should be fine there are plenty of bored 1216 Bandits that still run the standard tap, let alone for a standardish 600 motor running at a conservative 70mph (same tap). You've got to have a pretty radical motor to have to uprate to a Pingel tap or similar for the extra flow.
One problem could be a partially blocked breather not letting the tap flow to it's maximum , be worth checking/cleaning the breather and overflow pipes to make sure.
temeluchus
PostPosted: 00:02 - 21 Aug 2011    Post subject: Reply with quote
or the diphragm has holed, that will starve the motor. This happened to meon my old gixxer 1100 and on a GPz1100S.
Moxey
PostPosted: 15:00 - 21 Aug 2011    Post subject: Reply with quote
Well renewed the diaphragm and other components of the tap assembly just over a week ago, tank breather has been cleared out (previous owner had painted the cap and clogged it) but even so opening the fuel cap doesn't lead to a hiss or any sign of decompression.
Bike runs fine up to 60mph but any speed over that for a prolonged period (motorway) and the bike suffers from what seems like fuel starvation (had the plugs out they looked pretty lean), I'm lost off as to what can cause the problem.
Bezzer
PostPosted: 15:18 - 21 Aug 2011    Post subject: Reply with quote
Float heights all OK??
Casper
PostPosted: 15:38 - 21 Aug 2011    Post subject: Reply with quote
Are you sure you cleaned out the cap vent fully. If you have a spare key stick it in the cap and go for run, open cap when bike is starting to run out. If it picks up again then air vent is your problem.
philoldsmobil...
PostPosted: 17:40 - 21 Aug 2011    Post subject: Re: Vacuum Taps. Reply with quote
Quite possible, but there is a more likely candidate, especially if the bike has had paint.
pull the tap from the tank and you will find a fine screen around the fuel intake tubes - this often gets blocked. it only takes quite a small amount of debris to be enough restriction to starve at high RPM, especially on a gravity fed bike. (like my old GPz)
the fact that the taps usually seal with an o ring means this is a free job, provided you have something to catch the fuel in and don't loose it all. (obviously do it with the tank low on fuel, preferably after going onto reserve)
its a relatively quick, free and simple job, that could well hold the answer you are looking for. while you're at it, suck on the vacuum side of the tap, if you cant suck much its ok, if you can keep sucking - its got a hole...
PostPosted: 19:29 - 21 Aug 2011    Post subject: Reply with quote
If there a prime option on the tap?
If so my GS500 had a dodgy tap... which turned out to be both the vacuum pipe and the diaphragm and only screwed up after 60ish on the motorway.
PRI on the fuel tap eliminated it...but did like to piss petrol away when left standing Laughing
Moxey
PostPosted: 00:07 - 22 Aug 2011    Post subject: Reply with quote
Float heights have been checked quite recently (had the carbs off more than a few times) they're at 16mm atm which would be slightly richer than recommended but still acceptable, also set the pilot screws to 2 and half out which is a half turn more than recommended again would make the mixture richer but instead i'm experiencing the opposite (don't know how they would have any effect on the bike beyond tickover but worth mentioning).
Fuel tap has prime setting but then I get the opposite problem at low speed the cylinders sometimes flood and the plugs fouled after running it for a week like that, already replaced most of the components of the fuel tap that can be replaced (also cleaned the filters which somebody mentioned) so thinking it can be ruled out and something on the carbs I don't know about is the cause but what?
Another thing to mention is after the bike died on me recently going along the A66 after cruising about 75, I whipped the plugs out, looked like it was running lean and there was still a spark, yet put the tap on prime for about 30 sec just to get some fuel in the bowls which I thought had run dry then tried to start it and it just would not fire up.
Eventually me and the mate I was with had to bump and electric start it to get it going (considered block jets but they've been checked recently and fuel tank isn't rusty, filters clean on the tap etc so doubtful of a blockage developing since I checked).
Bike has got me genuinely Confused
*Recommended float heights and such taken from Haynes Manual.
hmmmnz
PostPosted: 01:47 - 22 Aug 2011    Post subject: Reply with quote
as you are riding and the promlem occurs, flick over to prime on the tap,
if it starts running sweet again, then i'd be looking at you vacum line from the carbs to the tap,
if it stays the same and doesnt change anything, then i'd be looking at main jets,
the humans are dead
I kick arse for the lord
Bezzer
PostPosted: 10:27 - 22 Aug 2011    Post subject: Reply with quote
You're going to think me stupid, but hear me out Mr. Green
You seem to have checked everything out that may be causing a problem but reading the previous ...
Were these trips on a hot sunny daytime or a bit cooler early hours trips? because they are all classic carb icing scenarios. Knew someone with an Srad who used to go to work early in the morning and he would get it coming off the motorway part of his commute even at this time of the year, he ended up using ProFst all year round. Smile Bandits are also famous for it, it only has to be less than 10C to be affected, the constant highish speeds would cause partial icing but enough to make it run rough or cut out when you drop speed even at this time of the year if your bike was subsceptible to it. But it would melt and let you restart pretty quick this time of the year.
PostPosted: 12:57 - 22 Aug 2011    Post subject: Reply with quote
He ain't getting carb icing at 70mph coz I'm not getting it at night going much faster Smile
If you want to test your tap, just turn it to PRI as hmmmnz said, which by-passes the vacuum part. Sounds like either a blocked gauze filter or blocked tank breather, as others have said.
Bezzer
PostPosted: 13:11 - 22 Aug 2011    Post subject: Reply with quote
Depends what bike dude, some are more prone to it than others, even if they are the same model. If it's been happening daytime then no but if it is in the early morning then it is quite possible. Especially as he's from oop the artic north Mr. Green
Moxey
PostPosted: 13:36 - 22 Aug 2011    Post subject: Reply with quote
Well I have got my carb heaters dis-connected (due to bad wiring and didn't think they'd be needed this time of year), I'd be inclined to look into that though, think I might get some isopropanol or rewire the heaters up when I get chance.
Going to test the bike today though, I've adjusted the pilot screws again to richer mixture and going to see if any effects from that area.
philoldsmobil...
PostPosted: 22:13 - 22 Aug 2011    Post subject: Reply with quote
Oh yes, old air cooled GPz's were especially prone to it.
the carbs flooding when on prime does lead me to thing needle and seats may have issues? the carbs shouldn't flood, ever, if the needle and seat is working properly.
Moxey
PostPosted: 23:51 - 22 Aug 2011    Post subject: Reply with quote
^ Yes the Carbs shouldn't flood (only on Prime mind) but checked float heights and the valves are all in working order so bit exhausted on ideas in that area but the problem i'm getting now is opposite so looking elsewhere, also speaking of the GPZ series my dad reminded me of a friend of his who had the either the 750 or 900 (not familiar with them) and bent a con rod due to the mentioned problem Surprised makes sense to have the carb heaters I guess.
Ran the bike today and it's been fine barring didn't take it above 70 for extended periods and it was abit of a git starting up again when I pulled up to talk to somebody for barley 5 min (started on 4th or 5th attempt so not as bad as before when I had to bump it).
Managed to get in touch with somebody else who has a Bandit 6 who has his carb heater disconnected as well, his runs spot on he's referred me to somebody who's supposedly shit hot when it comes to carb's and fuelling so might as well let him have a look.
The last post was made 15 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 16 - Page Size: 99.54 Kb
