small nick in my barrel/ snapped piston ring/ shredded parts
benandthe
PostPosted: 22:08 - 03 Sep 2011    Post subject: small nick in my barrel/ snapped piston ring/ shredded parts Reply with quote
I've managed to snap my piston ring thanks to bits of metal....
Basically I was going uphill on my 70cc scooter at about 60mph and the gudgeon pin decided to get sharp, shred the gudgeon pin and spit bits of metal all around my crank and up my ports into the head/piston: https://i1222.photobucket.com/albums/dd482/Ben_Piranha_Lewis/DSC01911.jpg
Not the best moment of my life, seeing as I was on the isle of wight scooter rally.. lol
Luckily there is only very minimal damage to the barrel :
https://i1222.photobucket.com/albums/dd482/Ben_Piranha_Lewis/SAM_0175.jpg
Any ideas/ suggestions on removing the nick?
Just, carefully, get a bremmel drill on there?
Can't really port it out anymore as it's already massively ported, it's the "Stage 6 Racing 70cc" kit.
Sold: NRG 50cc, SR125cc, CBR125cc, Mito MK 1 125cc, Speedfight 50cc, Stomp 125cc, cbr125cc, NRG 172cc, CBF 125cc, Zip 70cc, stomp 140cc
Current: CB500 (waiting on DAS)
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
MickC
PostPosted: 07:42 - 04 Sep 2011    Post subject: Reply with quote
You may also have to consider splitting the engine cases to make sure nothing has been left inside, last thing you want to do is rebuild the top end and then have some poxy piece of metal screw everything up again.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
PostPosted: 09:10 - 04 Sep 2011    Post subject: Reply with quote
Dr. Quack wrote:
If it’s a chrome bore it's a re-chrome.
If it's a cast bore it's a re-sleeve.
I'm sure there will be a re-bore kit knocking around for you scooter.
If you go for this don't forget to up-jet the carburettor.
Looks like you cay a whole new top end. (It will be a lot cheaper this way)
https://www.ebay.co.uk/itm/piaggio-nrg-polini-70cc-big-bore-kit-/270799353880?pt=UK_Motorcycle_Parts&hash=item3f0ce63818
You DON'T need to alter the jetting for simple first or second oversize. Carburettors mix air and fuel based on demand, they don't deliver a set amount.
benandthe
PostPosted: 10:33 - 04 Sep 2011    Post subject: Reply with quote
Sod the polini kit, it sucks. I'm running one now as a spare, they are cheap and nasty and slow.
I'm using the Stage 6 ally racing kit, most powerful one there is, second to the Malossi MHR (I'm producing about 12bhp with it, not bad seeing as I've not got anything else set up properly at the moment!
benandthe
Already done that, rinsed it with loads of petrol and 2 stroke, all clean. Smile
benandthe
PostPosted: 10:35 - 04 Sep 2011    Post subject: Reply with quote
Oh and the guy on ebay wrote "welcome to my auction for a brand new still in box pollini 70cc big bore kit was oriaganly brought for a nrg mc3 will up load pic asap the box has been opened to check contents. i payed £145.65 for this so grab your self a bargain many thanks
Yet you can buy them for £90 on pedparts.co.uk lol
PostPosted: 12:32 - 04 Sep 2011    Post subject: Reply with quote
There could be piston slap, we don't know how bad the barrel is.
Looking at the piston the barrel is well cooked.
Source: Built loads of top ends.
What's that got to do with my reply on re-jetting?
Two stroke barrels wear down the exhaust port side so place the pistion in and check for piston slap before deciding weather or not you will get away with a re-hone and an oversized piston kit.
You don't fit an oversize piston from honing a barrel either. Honing doesn't guarantee the bore is round unless you happen to have a sunnen in your pocket.
benandthe
PostPosted: 00:38 - 05 Sep 2011    Post subject: Reply with quote
Really don't know why people argue on my threads. lol
Anyhow, it's fixed and running like a dream again now, got a mate to carefully port it a little and the nick is gone now, the excess coking on the head is due to me not pre-mixing at the right ratio and having too much oil in there, so it's making a mess.
These Stage 6 kits are notorious for needing a new piston ever 3000 miles or so. oh well. Smile
benandthe
PostPosted: 12:23 - 05 Sep 2011    Post subject: Reply with quote
It's all good and well so far, went in for a quick dyno run at my mates shop, kicking out a lovely 10.4bhp, run on a moped dyno not a full bike dyno so it's much more accurate, all factors like air pressure and temperate and sea level elevation taken in. Very Happy
He had a look at the piston and the barrel and said no issues, but the kit is designed for sprinting rather than long distance riding really. Smile
PostPosted: 12:28 - 05 Sep 2011    Post subject: Reply with quote
benandthenrg wrote:
..but the kit is designed for sprinting rather than long distance riding really. Smile
Roughly translated - it has cooling issues!
benandthe
PostPosted: 18:23 - 05 Sep 2011    Post subject: Reply with quote
yeah, it's an air cooled scooter. gonna see what ebay has to offer and I will try to get a liquid cooled. or get some kind of additional fan blowing air on the head...
any ideas?
Im-a-Ridah
PostPosted: 18:41 - 05 Sep 2011    Post subject: Reply with quote
any ideas?
Or just get a water cooled ped and mod that instead? As for a fan, you'd be better off trying to duct air from the front, taking advantage of the existing forward movement of the bike! Powering a decent sized fan with a good volume of airflow on a ped could be a real pain! You could also try increasing the size of the cooling fins by adding some copper or aluminium sheets to them, but don't make any holes or cuts into the existing piece in doing so, just to be on the safe side.
benandthe
PostPosted: 10:25 - 06 Sep 2011    Post subject: Reply with quote
I was thinking about cutting out a section between the footwell and the front of the bike, behind the wheel, and having some kind of tubing going through from the front onto the head/engine. not sure how or what it would be made of, would also be wanting to fibreglass over it to make it look better.
Oh well, it works now and I don't normally ride her that far.
It's good for now. Very Happy
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 16 - Page Size: 106.51 Kb
