| Teflon-Mike |
 Posted: 00:16 - 13 Sep 2011 Post subject: Lets talk Air-Cooled Yamaha two-stroke Singles....RSX? |
OK, well, my 'enduro' frame and bits came back from the powder-coaters today; so placing an order for parts to get it built back up. From dimensions; odered seals I am told to fit an RSX100.... we dont know if the forks are from a DT80, or an earlier DT125, or WHAT really, so it's merely co-incidence they should be same size as the RSX... and more co-incident that I have, in my trawlings trying to find compaitible parts, been pondering Yamaha 'interchangeability'. Points for instance; my bike ough NOT have them, but it has; and the ones ordered, by description seem to be common to almost everything Yamaha built in the 1970's from the FSIE to the XS650.
Anyway; RSX motor; was trying to call up micro-fish & parts numbers to check crank & crank-case numbers, without much luck; becouse in my trawlings, came accross specs that suggest that RSX100 shares same stroke as the DT125.....
I thought that the RSX engine was based on the earlier YB100, with a more inclined almost horizontal cylinder; and essentially a bored out FSIE engine.... BUT.... I also thought that the RSX100 was a 'square' bore and stroke, opened out to over square 125; and that the DT125 engine was 'Square' and bored to over-square 175... but specs I'm pulling up, suggest that the stroke is the same on the RSX100, RSX125, DT125 and DT175....
So..... now wondering; was the RSX engine based on teh air-cooled DT? Would explain its more upright cylinder.... and if so, what commonality is there between DT100; & RSX100, DT125 & RSX125 and the DT175.....
Air-cooled DT125 offered 15bhp, compared to the 11, the 'standard' RSX125 offered.... so did 'full power' air colled DT barels go on them? and if so, what about the 175's? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Blau Zedong |
 Blau Zedong Banned
| N cee thirty |
 N cee thirty Banned
| Blau Zedong |
 Blau Zedong Banned
| UnspeedySam |
 UnspeedySam World Chat Champion
| N cee thirty |
 N cee thirty Banned
| Blau Zedong |
 Blau Zedong Banned
| N cee thirty |
 N cee thirty Banned
| UnspeedySam |
| Blau Zedong |
 Blau Zedong Banned
| Teflon-Mike |
| 27cows |
 27cows World Chat Champion
 Posted: 08:04 - 15 Sep 2011 Post subject: |
To my knowledge, the other barrel that will slot straight on is the (overseas only) RX/RXS115 item. I've seen one on the road. Whole motors or bits of them turn up from time to time. But apparently there's virtually no performance gain using the 115 top end, as you might expect really.
The RXS100 is an updated version of the RS125 motor - various bits can be swapped between the two, mostly gearbox & clutch components.
Best pipe is the standard one. The spannies for the RXS are all shite, unless you enjoy riding everywhere at about 17,000rpm  ____________________ The RXS100: vehicle of choice for Chuck Norris |
The last post was made 15 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
