Any amateur meteorologists explain this one?
PostPosted: 20:54 - 20 Sep 2011    Post subject: Any amateur meteorologists explain this one? Reply with quote
A pair of non-paralell rainbows.
Not all that clear on the picture, it was WAY more intense than this but I had to find somewhere safe to stop and take a picture.
You can see the primary one and you can see a fainter secondary, inverted one outside it. But there's another rainbow, coming off the base of the primary one at a tangent. and heading up towards the apex of the secondary one. It's also a primary rainbow with red on the outside.
https://i48.photobucket.com/albums/f216/stinkwheel/Image000-2.jpg
Now as far as I know, this defies the laws of physics. Rainbows are paralell and appear as concentric rings on account of the sun being in one place at a time.
You can see it more clearly if I mess about with the colour levels on the picture.
https://i48.photobucket.com/albums/f216/stinkwheel/Image000enhanced.jpg
SoND
PostPosted: 20:58 - 20 Sep 2011    Post subject: Reply with quote
There is always a second rainbow whether you can see it or not.
The colours are always inverted.
EDIT
Walter Lewin explains in this lecture
https://www.youtube.com/watch?v=p9iB2PALVeY
EDIT
A 3rd rainbow? I don't see it.
EDIT
I see.
It's magic. Whistle
herulach
PostPosted: 21:13 - 20 Sep 2011    Post subject: Reply with quote
OH MY GOD ITS A DOUBLE RAINBOW>
ITS SO INTENSE
YBR 125>FZS600
As I say. Faint in the picture but it was as intense as the main one initially. If you right click and view image, you'll get it bigger.
I labelled them, curves follow the red arc.
Ariel Badger
PostPosted: 21:16 - 20 Sep 2011    Post subject: Reply with quote
The wind may have blown it over.
KevTM
PostPosted: 22:08 - 20 Sep 2011    Post subject: Reply with quote
Pretty weird and interesting!
I've actually seen two fully formed rainbows side-by-side! I can't find an image in google of such a thing, just the usual "double" rainbows.
PostPosted: 22:16 - 20 Sep 2011    Post subject: Reply with quote
Somebody was moving the pot of gold.
D O G
PostPosted: 22:17 - 20 Sep 2011    Post subject: Reply with quote
Sun reflecting from a nearbly lake providing another light source?
SoND
PostPosted: 22:21 - 20 Sep 2011    Post subject: Reply with quote
Maybe there's a patch in of air without rain, that would normally block your view, that has revealed a transition between the primary and secondary bows where you can only see red light.
PostPosted: 22:45 - 20 Sep 2011    Post subject: Reply with quote
Swamp gas from a weather balloon was trapped in a thermal pocket and reflected the light from Venus.
I swear I used to know this stuff. Now I just say "A wizard did it." Or if really pressed, shout "frustum!" and then leg it.
Hockeystorm65
PostPosted: 23:10 - 20 Sep 2011    Post subject: Reply with quote
They are parallell (or actually concentric) you are seeing some parallax because of the angle of the photo and because the second one is a larger hemisphere sitting outside of the inner one. They only look parallel when viewed from a distance, when you are as close as it looks like you were, you are actually inside the circumference of them.
Very Happy Very Happy
Good judgement comes from experience.....experience comes from bad judgement!
PostPosted: 00:22 - 21 Sep 2011    Post subject: Reply with quote
I already said that a wizard did it.
doggone
PostPosted: 08:34 - 21 Sep 2011    Post subject: Reply with quote
This picture is very similar and the proposed cause is a reflective body of water as someone said above.
https://apod.nasa.gov/apod/ap070912.html
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 3 - MySQL Queries: 16 - Page Size: 81.39 Kb
