Puncture safe - UPDATED (a 2nd time)
sickpup
Old Timer
PostPosted: 02:17 - 24 Sep 2011    Post subject: Puncture safe - UPDATED (a 2nd time) Reply with quote
Anyone using it or one of the equivalents?
ClockworkJesu...
PostPosted: 02:52 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
is it like that tyre-weld anti-puncture gunge stuff?
Wouldn't let it touch my bike. Neutral
You'd never know you have a puncture. Which, I guess is half the point of the stuff, but if you get a puncture on a load-bearing point of the tyre; like the supporting wall, you now have an unsafe tyre that you don't know about. That's my take anyway.
Besides, it ruins anything it touches. Shocked Corrodes rims, kills tyres...
Not worth it.
Dan87
PostPosted: 09:45 - 24 Sep 2011    Post subject: Reply with quote
I'd be very interested to hear other peoples views.
Apparently its not like tyre weld or slime, you can remove it from the tyre should you get a puncture (that it cant repair itself) so you can get the tyre plugged.
PostPosted: 09:52 - 24 Sep 2011    Post subject: Reply with quote
Will permanently seal punctures caused by puncturing objects up to 6mm
The seal is guaranteed for the life of the tyre
Punctured – Puncturesafe seals giving a telltale mark
Perfect air retention state in the tyre
Helps extend tyre life.
Improved handling of the machine
Dampens vibrations, reduced suspension failure
No excessive heat, no excessive tyre wear
Applied before the puncture occurs
Is not a foam or a get you home product
Controls most blow-outs by giving a controlled deflation
Makes the "inner tyre" cooler
A 700 ml DIY bottle will do 2 or 3 tyres
Not seen it advertised at motogp or wsb rounds...yet it does so many wondrous things. Shifty
Nai
PostPosted: 11:51 - 24 Sep 2011    Post subject: Reply with quote
Used grunge twice on a bicycle inner tubes. Both times when I did get a puncture it made the tubes completely unrepairable. It stayed liquid which didn't create a good enough seal and I couldnt just plaster over with a patch because... Well.. it was liquid and just sprayed out and made the patch go splat when I put air in the tube.
Nice idea, but would take some effort convincing me it worked.
sickpup
Old Timer
PostPosted: 12:33 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Not worth it.
On what do you base this opinion?
Moo.
PostPosted: 12:42 - 24 Sep 2011    Post subject: Reply with quote
I used puncture safe, with all the logos around it about the royal mail using it. Yet to get a puncture so cant report.. Laughing
A2 Passed 18/6/10
PostPosted: 16:12 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Used various in dirt bikes and cars with some success. Of course, if it really works well, you don't even know you've got a puncture.
Also used aerosols that inflate the tyre. Again, had it work in some cases, but not all - ones from the pound shop have worked in some cases, can't really tell if they're any less good than other ones.
ClockworkJesu...
PostPosted: 17:05 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Not worth it.
I watched a car tyre blow out once. She had a puncture, and the car was handling fine until the supporting wall gave out. The tyre practically exploded and separated the tread from the rest of the tyre.
If you have a puncture in a supporting wall of the tyre, half the weight of the bike is pressed against it. A small hole can quickly turn into a rip and worse with a few bumps. Tyre weld or a similar product only makes the puncture airtight. It doesn't return the tyre to a previous safe condition. Smile
A friend of mine filled his punctured tyre up with a similar style gunk. When he took it to a friend's garage to get the tyre repaired, said mechanic practically slipped him around the ear; said the liquid stuff can cause the steel on the rims to corrode, and makes the tyre unrepairable after use.
stonesie
PostPosted: 17:28 - 24 Sep 2011    Post subject: Reply with quote
Funny, my tyre fitter mate says the only stuff like this to use is Puncturesafe because it doesn't do the nasty things mentioned, so I put it in my tyres and havent had a puncture. It means you can't ballance the wheel but that is no problem because it self-ballances every time you ride.
One lad I know has pulled 6 nails out of his 125's front tyre with this stuff and has had no problems, it does leave a tell-tale mark to let you know there has been a puncture.
sickpup
Old Timer
PostPosted: 19:02 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Hi ClockworkJesus I don't think we've met yet.
If you had a puncture in the sidewall puncture safe or any of the other brands wouldn't seal it as they only seal the tread area due to being forced as far from the centre as possible so that makes your first and second paragraphs redundant.
As to the third paragraph yes these products tend to be water based so could cause corrosion but as to making the tyre unrepairable that is complete and utter bollocks.
Thank you for your input. Thumbs Up
JackDaniels
PostPosted: 21:22 - 24 Sep 2011    Post subject: Reply with quote
i used Holts Tyre Weld admitidly it held air fine but when i went to get the puncture plugged the fitter told me due the the liquid he described looking like semen he told me the plug/patch thing wouldn't stick.
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
PostPosted: 21:29 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
When did you last see a tubeless tyre on a steel bike rim?
ClockworkJesu...
PostPosted: 21:36 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
I don't believe I've had the pleasure either. Razz
S'cool.
Wink Guess I'm just distrustful of anything claiming to be the next metaphorical cure for ageing.
it probably works, but in my books a pneumatic tyre will always be a pneumatic tyre, and not hydraulic. Thumbs Up
Would rather have the tyre patched, I think. Just personal preference.
I'm not sure. I don't check every bike I see for tubes, or a lack of them. Razz
PostPosted: 21:40 - 24 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Well then perhaps you should be a little more informed before offering your observations.
PostPosted: 00:51 - 25 Sep 2011    Post subject: Re: Puncture safe Reply with quote
I was going to mention that, but realised the answer was 'last time I looked art my 690 wheels'... But the tubeless system on it actually recommends using a sealant.
ClockworkJesu...
PostPosted: 01:16 - 25 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Can only do my best. Thumbs Up
But you're right. S'only an observation, to be taken or left. Mr. Green
But yeah. Can only put forward what I'm told. Thumbs Down
D O G
PostPosted: 01:25 - 25 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Better to just put forward what you've experienced.
Hence I hardly say shit. Wink
sickpup
Old Timer
PostPosted: 02:05 - 25 Sep 2011    Post subject: Re: Puncture safe Reply with quote
Precisely. I have enough experience to know what these were like 5+ years ago but no recent experience which was why I asked if anyone was using them now.
Jim Mc
PostPosted: 09:15 - 25 Sep 2011    Post subject: Reply with quote
The reason these aren't popular on bicycles is because the goo has a tendancy to settle in one part of the wheel, then as it rotates, it gums together with the rest of the goo forming a larger glob.
In pedal cycling this has a severe affect on your wheel balance and can cause some really hefty vibrations through the bike.
I'd have thought the same is true for motorcycles and cars.
PostPosted: 10:39 - 25 Sep 2011    Post subject: Reply with quote
I used one version on my 1500 wing cause fixing the rear tyre was a nightmare. I either never had a punture or it worked fine. Also it wasn't a problem when tyre change time came round. I couldn't say which brand of the stuff it was though, the bloke who did it was at goldwing meets and I just went to him.
raak
PostPosted: 11:03 - 25 Sep 2011    Post subject: Reply with quote
used slime on my old honda......never had a puncture either or it worked real well Very Happy
i would also be interested to see if anyone has used puncture safe, sickpup.
out of interest when you used similar products 5 years ago how did you rate them..?
Previous bikes: Suzuki GT250A / Yamaha DT125 / NTV Honda 650 // currently Suzuki RF900
sickpup
Old Timer
PostPosted: 11:54 - 25 Sep 2011    Post subject: Reply with quote
I didn't use them just had to clean up the mess. They often semi solidified or the solution separated in the tyre causing it to go out of balance massively and caused a mess on my tyre machine when people didn't warn you about it. I have seen corrosion on rims but this was generally in bikes that had been left standing and I've seen the same corrosion on bikes without as well.
raak
PostPosted: 10:26 - 26 Sep 2011    Post subject: Reply with quote
Did use it as i said and never noticed any real problems balance wise.
Is it really that much of a hard job to clean up?
unexpected true, that would be annoying... but if told, what can you do to make it easy to deal with.
have to say that NOT getting a puncture miles from home was upper most in my mind (never had one or had to use the kits for sale to fix one ).
The guy at the tyre fitters was way down my list of priorities... Confused
Curious about the 'Puncture Safe' would be happy to use it if reviews came back any good Cool
sickpup
Old Timer
PostPosted: 10:59 - 26 Sep 2011    Post subject: Reply with quote
Out of the tyre no, just jet wash it. Out of a tyre machine when you have a lot of tyres to fit yes.
Nothing really.
My thought as well.
The last post was made 15 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 140.86 Kb
