| gibsont |
 gibsont L Plate Warrior
| ClockworkJesu... |
 ClockworkJesu... Nitrous Nuisance
 Posted: 00:45 - 28 Sep 2011 Post subject: |
No experience, but the Sinnis Stealth has a Suzuki engine. Should be pretty sturdy upon that note.  |
| Paulington |
 Paulington World Chat Champion
| D O G |
 D O G World Chat Champion
| Paulington |
| D O G |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:48 - 28 Sep 2011 Post subject: |
| Paulington wrote: | You cannot have exceptional build quality at a low price, it's not possible. |
You MAY... depends what is 'exceptional'.... means 'the exception' so by the standards of build usually associated with Chinese bikes.... something even MORE generally crap, might be legitimately referred to as 'exceptionally' so...
Ergo: you CAN have exceptional (LOW) build quality at a low price; it would make perfect sense.... whether it would be VFM, is another matter..... depends how exceptionally low and whether price was less than dead weight!
Old marketing ploy of presumption...... you PRESUME 'quality' means GOOD quality!
And the unqualified comparison: "Persil Washes Whiter"...
Whiter than What? Daz? Surf? Curry Powder?!
OP: Sennis; one of the more common Chinese branded bikes; ergo. by the rating of chinese branded bikes..... they are in the middle of a heap of shit..... Sinis Apache Dirt bikes, come up regularly on e-bay; usually as spares or repairs projects around the time thier first (three year old) MOT is due; and they fetch about £150 a brace, for some reason they seem to come in two's.... suggesting you cant ACTUALLY make one 'useful' bike out of two......
Are they any good? Depends is it a new one; second hand one; how old? What do you want it for and whats your expectations for it?
Want something that will cut it to the podium in Club MX events; you got to be fucking joking.
Something as a weekend Toy for a spot of green laning or haking about the farm.... provided you dont have to rely on it and can hail a tractor or something to come get you when something breaks; could prove a moderate laugh for the money. But used off road they do aparently have a habbit of snapping rather vital components like swing arm spindles or frames at the first sign of a big bump.
For something to get to and from work or college on? Well, brand new; it might prove about 90% serviceable, and if you know a thing or two about bikes and before you try using the thing, take it to bits; grease everything that ought to move; loctite everything that shouldn't, solder all wiring connectors and spray everything liberally in WD40 & ACF50; you might stand a chance of having something that will 'do the job'.... wont be fastest, surest handling or the most inspiring bike about; but will do the job..... as long as you dont want to flog it in a hurry for anything like a 'sensible' fraction of what you paid.
Second Hand? Post 3 years old with a genuine MOT..... that will be a rare beast! BUT lets say you find one..... good chance it was bought by some one that took it apart before they tried using it; greased moving bits; locktited evrything elce; added soler, rust preventure and water repellant...... ought to be cheap, as in much less than half list price; and could, for the laugh, prove notionaly serviceable for the money, BUT still expect to throw it away, when it breaks... which you can expect fairly soon.......
Else wise its a project; and that might be a bit of a laugh, if all you want is something to clutter up the shed, and let your imagination run riot with, atacking bits with a mig machine or angry grinder, with absolutely NO need for it to EVER serve as something even remotely resembling a practical means of every day, nay occassional! Transport! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Nai |
 Nai World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:33 - 28 Sep 2011 Post subject: |
If you don't have overheads like R&D, marketing, salesweasels, dealer markup, warranty support, or paying your staff more than a bowl of rice a day then you can offer the same quality as a brand name bike for a lot less cost. I'm not saying that Sinnis do, but it's not impossible. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nai |
| P.addy |
 P.addy Red Rocket
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:45 - 28 Sep 2011 Post subject: |
| Nai wrote: | Curious to know Roger, was it you that had the 2 Chinese bikes here? If it was, how did they work out? |
Huoniao HN125-8 aka the Lexmoto Vixen. A basic little commuter (CM125 knock off with CG125 knock off engine), a doddle to ride, cheap to buy, parts are readily available and fully Honda compatible. It has two inherent faults: a connector block on the side stand cut-out switch that's prone to corroding (5 minutes to fix it) and the RHS exhaust hangar is prone to cracking where the rear brake stub goes through it (£25 to replace or buy a CM125 part from a breaker). Other than that, there's not much to go wrong.
Skygo / Lifan LF250B. A close to nut-and-bolt copy of the Yahama Dragstar 250. Looks great, but it's not as good as the HN, to be honest. The V twin is smooth, quiet and pulls fine low down, cycle parts work OK, but the rear exhaust has a blatant weak point that will corrode through in short order, and it's way down on power and slower than a short bus full of spackers. Parts aren't as easily available as for Chinese-branded 125s.
Insurance is actually the big headache, relatively few underwriters will touch either of them. Used to be (I hear tell) that you could get a quote for the nearest equivalent then call up and just get to them to change the bike on your cognisance, but I haven't found anyone who will do that any more. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nai |
| Mr_Cynical |
 Mr_Cynical Nitrous Nuisance
| andyscooter |
 andyscooter World Chat Champion
There is a gap of 2 years, 95 days between these two posts... |
| Doomsnite |
 Doomsnite Traffic Copper
| kramdra |
 kramdra World Chat Champion
 Posted: 17:56 - 02 Jan 2014 Post subject: Re: Sinnis motorcycles |
Old thread is old.
Still have mine in back of garage. It was nice to ride, one day might fix. Few things to note:
The dealership - who I belive are also the importer? "Onthewheel", are utter cunts, and will happily sell dangerous, broken parts as new - referring here to brakes. They would not warranty the parts either. If you need bits, try eBay first.
Engine is a Suzuki copy, not a real one. That makes it almost equal to any other chinese copy, parts and spare engines will not be as common. Top speed is about 55-60 but often much less, struggles for 40 up hill
Brakes - good design, let down by dangerous quality. I'm refering to the painted master cylinder piston here. One day I plan to replace with a cbr600 master, or similar. Having a rear disc brake is nice.
| Doomsnite |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:46 - 02 Jan 2014 Post subject: |
I can't get my head round the concept of a premium Chinese-made bike.
The YBR gets away with it because of the Yamaha name, warranty and dealer network.
I actually like Lexmotos because they started right, by building a parts supply business. I may even have been very slightly tempted by a used Lexmoto Arrow today.
But the Arrow is the cheapest bike that they do, which is where I'd start looking with a modern 125. With the Varadero not being sold any more, the 125 market looks to be almost entirely cheap and nasty sweatshop bikes, sold with amounts of markup varying from the reasonable (Lexmoto) to the risible (KTM).
Sinnis, I wouldn't touch at anywhere near what they're asking for them. Who the chuff are Sinnis? Just another ropey little UK outfit run hand-to-mouth that'll be as likely to fold as to prosper. ____________________ Biking is 1/20th as dangerous as horse riding.
| Doomsnite |
| Sable |
 Sable World Chat Champion
 Posted: 20:32 - 02 Jan 2014 Post subject: |
Mines Sinnis Trackstars still going strong after 20k in a year and a half. Mixed citys, motorways and open roads.
Black Dog Motorcycles are a good Sinnis dealer. I have heard some horror stories from a few dealers in Scotland (not Victor Devine).
Have a search for the Chinese Bikes thread in News & Issues, I did a review thing at about 12k and everything I said then still stands. On mobile so hard to find and paste a link right now.
I am happy with mine. For 1500 its done everything I have asked of it.
Edit :
Update to Sables Sinnis mega post. Explosions and shakey photos included. Also a dog.
https://www.bikechatforums.com/viewtopic.php?p=3786693#3786693 |
| Depleted |
 Depleted Two Stroke Sniffer
 Posted: 11:04 - 03 Jan 2014 Post subject: |
I have the Sinnis Max II I got it on the 1st march last year, at first it was great, no problems at all for 3 months, then the exhaust cover plate broke off - one of the two bolts holding it in had sheered completely and im LUCKY it was the one at the rear of the bike and not the one closer to the front.
Then the side stand spring flew off somehow on the same day and i nearly came off at a round about on an industrial estate near where i work.
Edit: I forgot to mention the clutch cable had nearly completely sheered off one day - it was foggy and i was riding to work, i got to Weedon crossroads and i couldnt get my bike out of 1st into 2nd so i had to lean down and manually shift the clutch lever on the engine case while riding - scariest fucking thing i've ever done. The cable was hanging by a single thread and i had to call out RAC for repairs.
Month/two month later the electronics went, my brake light was constantly on as if i was braking all the time - so after some fiddling i found out the rear brake was causing it so i disconnected the rear brake from the circuit and i had a normal brake light again.
Then more electric problems only after 6-7 months of owning the bike from brand new. The head light power went down if you revved the bike past 4k, so its either fog light or high beam only - no middle ground.
And then I came off of it at a round about outside mcdonalds in Daventry and i smashed the right mirror, brake lever, and handlebars.
Avoid Sinnis, yeah they're cheap but here's me mr £1400 brand new 125cc all mine, but it has problems and it can't even push past 65 on a good day, I wish i got a jap bike instead. |
| stevo as b4 |
| MarJay |
 MarJay But it's British!
 Posted: 11:50 - 03 Jan 2014 Post subject: |
I've been against Chinese bikes for a while now, mainly due to their build quality and the false economy of purchasing something that will be worthless in a year or two.
However... have a look at this:
https://www.motorcyclesupermarket.com/images/bikes/images/10578.1369390245.IMG_8027.jpg
That is a Sinnis Cafe Racer. That looks nice.
Not saying it won't still dissolve in a years time, but it looks very much like significant progress has been made, particularly in the area of design. That is a pretty bike. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| stevo as b4 |
 Posted: 12:04 - 03 Jan 2014 Post subject: |
Looks wise that is nice enough, but I find that style and looks are quite easy for them to get reasonably ok. Even some of those AJS chopper twins look ok and have all the style you would expect of a custom chopper etc.
But two things I am not keen on:
1, The clone Honda/Suzuki engines always seem down on power to the original Japanese engines, and are often based on the oldest designs and not the late updated models. In the bike you linked why does it use a nasty knock off piston slide carb, when the late Suzuki engine's had a CV carb etc?
2, The cycle components might look the same, but thinks like copy brake caliper's and shocks and fork internals might just not be up to the job, or be as strong, reliable or corrosion resistant as the Japanese bike parts brands.
You can still have problems with KYB, Showa, Brembo, Tokico Nissin parts etc, so what are the chances of a cheap copy part being up to the same standards.
I'm old fashioned too, and while I think Korean brands have got pretty good these days, I still would not want to spend my money on a cheap Chinese new bike, when I could buy something less funky but with all Japanese parts fitted second hand. |
The last post was made 12 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
