CHARGING PROBLEM
jpderv
PostPosted: 22:33 - 19 Oct 2011    Post subject: CHARGING PROBLEM Reply with quote
hi again folks having problems with the hartford vr 125,
problem is i dont think its charging for the past week the lights have been rubbish and the indicators barely work,
tested the battery today and it read 7.2v and then with the bike started it was 6.4v which is capput i then screwed the terminals off the bike whilst it was running and tested the cables going to the battery and there was no voltage at all even when i revved the bike,
so i then went and purchased a new rectifier thinking that was the problem but no although when i retested the cables with them off the battery it would jump up to 4ish volts when revving im sort of at a loose end now i dont know what could be wrong.
i was always led to believe if the bike wasnt charging that when you remove the battery cables it would die at least thats the way a car works anyway but the bike continues to stay running when i do this.
anyone any suggestions?
Thanks in advance.
1st bike= skyjet 125 2nd bike= suzuki ts 50 x 3rd bike= peugeot speedfight 2 100cc 4th bike= suzuki katana 50cc 5th bike honda cg125 6th bike = yamaha dt125 r 7th bike honda rebel 125cc 8th bike hartford vr 125cc current bike = honda mtx 125
spyuggy
PostPosted: 22:55 - 19 Oct 2011    Post subject: Reply with quote
Sounds more like your regulator mate.
Treat each day as if it was your last, because one day you will be right.
jpderv
PostPosted: 22:57 - 19 Oct 2011    Post subject: Reply with quote
i have already changed that and made no difference
jpderv
PostPosted: 23:16 - 19 Oct 2011    Post subject: Reply with quote
unitycrippledatmo wrote:
not a good idea to disconnect the battery when the engine is running.Due to the recent cold and dwindling daylight its at this time of year that knackerd batteries die.Try another battery first and if you want to check the voltage always check it across the battery terminals,with and without the engine running.
What voltage does the battery read when disconnected?
i only disconnected it to test if the bike was charging
the battery red 7.2 when disconnected
jpderv
PostPosted: 23:30 - 19 Oct 2011    Post subject: Reply with quote
it may be the battery is too knacked to hold a charge.Try another one to see,This time of year small bike electrics suffer severely if they have a knacked battery.
You should get 13.5. to 14.5 volts on a good battery.(without lights on)
yeah but shouldnt i get a voltage of 13.5 to 14.5 even without a battery im getting zero volts at the end of the cables.
Fizzer Thou
PostPosted: 01:50 - 20 Oct 2011    Post subject: Reply with quote
Is the bike system 6v or 12v?There seems to be a chance that it is one or the other.If you are capable of using a multimeter it is best to ascertain which it is before you go any further.
Always have a 'Plan B'
jpderv
PostPosted: 02:14 - 20 Oct 2011    Post subject: Reply with quote
[quote="Fizzer Thou"]Is the bike system 6v or 12v?There seems to be a chance that it is one or the other.If you are capable of using a multimeter it is best to ascertain which it is before you go any further.[/quote
lol its 12v im not that thick il try get my hands on a new battery tomorrow and try that to see how that works.
MickC
PostPosted: 07:01 - 20 Oct 2011    Post subject: Reply with quote
Could be the alternator is on its way out, but as suggested check the battery first.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
whitedevil
PostPosted: 08:05 - 20 Oct 2011    Post subject: Reply with quote
https://www.offwidth.co.uk/bike/general/electrical_fault_finding_2.pdf
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Fizzer Thou
PostPosted: 11:43 - 20 Oct 2011    Post subject: Reply with quote
[quote="jpderv"]
I was not trying to imply anything.In your first post you mentioned voltages around the 6-7 volt measurement.If this was on a 6v bike then the battery would have been reading okay.As I do not know your machine and that it has a 12 volt system,then this may well imply that there may be a fault with the battery or the charging system.
If you had an Optimate you could try to recover the battery,as this is what this item does quite well.But if the battery is not holding a charge,try using another battery and then perform your voltage checks.If there is insufficient voltage across the battery terminals when the engine is revved this may well imply that there is insufficient AC volts from the alternator.
Have you tried checking the resistance from the negative terminal lead to a good point on the frame?This should read zero ohms.Anything like 10 ohms or more will show up as a bad earth,in which case your battery will not have the right path for charging from the alternator/rectifier/regulator.
weewards
PostPosted: 12:40 - 20 Oct 2011    Post subject: Battery Charger Reply with quote
Hi, all the messages so far have coverered the battery testing but on a slight tangent I use an Optimate 4 charger and not only would it tell if the battery is knackerered it would also try to fix it if the battery is sulphated, just a thought Smile
jpderv
PostPosted: 15:54 - 20 Oct 2011    Post subject: Reply with quote
Have you tried checking the resistance from the negative terminal lead to a good point on the frame?This should read zero ohms.Anything like 10 ohms or more will show up as a bad earth,in which case your battery will not have the right path for charging from the alternator/rectifier/regulator.[/quote]
na i know mate just kidding yeah i did fit a bigger battery out of a quad today the battery read 12.85v when engine was off and 12.4v when the engine was started revving the bike made no difference to the voltage i bought a new multimeter its a cheap one though so not sure if its working correctly because i put it to ac and connected the black lead to the frame and touched the red one on a fewof the wires coming out of the stator and the voltage was like 160 or something then on other wires it rose up until it was out of range and the pdf that white devil sent me doesnt really apply to me because i have a hartford.
Bezzer
PostPosted: 16:14 - 20 Oct 2011    Post subject: Reply with quote
You're testing it wrong, if it's a 3 phase alternator/stator you should have 3 wires going to the reg/rec. Make sure the battery is charged then disconnect the plug that goes into the reg rec from the alternator. Start the engine and let it fast idle (it'll run just off the battery that's why it needs to be charged beforehand).
Multimeter on AC volts then check the wires from the alternator in pairs (1-2, 2-3 and 3-1) you should be getting around upper 20s AC volts, more importantly all 3 pairs should show the same. If they do the alternator is probably OK.
Connect the plug back to the reg/rec start it again and check the DC voltage across the battery terminals and you should get a rising voltage with revs to perhaps 14V or so depending on what your bike's output is. Under 13 volts then the reg/rec is shagged if the alternator tested OK and the wiring is fine. Doesn't matter if the battery is poor or not when you do that test as across the terminals will be showing the reg/rec output to the battery. If that test is fine as is the alternator output test then your battery is shagged and not holding it's charge.
jpderv
PostPosted: 18:44 - 21 Oct 2011    Post subject: Reply with quote
i charged the battery over night it was reading 12.65v this morning plugged it into the bike disconnected the reg/rec but the bike wont start with it disvonnected so i connected it back up started the bike tested the voltages across the terminals it stayed at 12.45v no matter what revs the bike was at.
and also this is the plug coming out of my stator there are more than 3 wires in it
https://i787.photobucket.com/albums/yy156/jpderv/DSC00024.jpg
https://i787.photobucket.com/albums/yy156/jpderv/DSC00025.jpg
this is the rectifier theres five wires in that
https://i787.photobucket.com/albums/yy156/jpderv/18102011395.jpg
https://i787.photobucket.com/albums/yy156/jpderv/18102011399.jpg
jpderv
PostPosted: 20:13 - 21 Oct 2011    Post subject: Reply with quote
the stator wires will have two wires to the pick up/ign trigger and should have three to the charging/lighting circuit.by finding the colour codes (compare with other similar engines/models) you can test the resistance across the coils and pick up/ign trigger to see if they are knacked or not.Sometimes the insulation gets dry and brittle .before taking the stator cover off try checking the connector block contacts are clean and a tight fit.If you get a spark you can ignore the pick up/ign trigger coil.
ok took the side casing off and there apeers to be oil inside there would that be anything to do with the bike not charging
https://i787.photobucket.com/albums/yy156/jpderv/DSC00029.jpg
https://i787.photobucket.com/albums/yy156/jpderv/DSC00030.jpg
https://i787.photobucket.com/albums/yy156/jpderv/DSC00031.jpg
does any off this look familiar?
jpderv
PostPosted: 21:13 - 21 Oct 2011    Post subject: Reply with quote
been rooting for a wiring diagram but no luck.you could try looking at alternator parts for eastern non jap bikes and see if you can find a coil set the same,making a note that one central coil is different,then,uses that as a guide to backtrack to 'resistance measurements.
many of these chinese bikes use the the same type coils
https://i787.photobucket.com/albums/yy156/jpderv/paint.jpg
i dunno if that makes any sense to you but thats the readings i got plus the ignition picup was 110ohms
Bezzer
PostPosted: 22:37 - 21 Oct 2011    Post subject: Reply with quote
12.65 isn't a fully charged battery but then again if it stays at 12.45 after starting it isn't too bad as it isn't receiving enough from the charging system too recharge it when running. If it won't start without the reg/rec connected it must be one of those systems that that splits the charge direct to the ignition side that can be used on the smaller bikes.
You really need a wiring diagram to work out which wires you need to be checking, guessing isn't going to help as electrickery can throw up some misleading results if you're checking the wrong bits. It's a stator, reg/rec or wiring fault but there's a lot of difference in the cost of each so it needs checking right before you have to splash out
jpderv
PostPosted: 22:41 - 21 Oct 2011    Post subject: Reply with quote
i know what you mean mate yeah its weird how itl stay going with the battery terminals connected if its not charging i think il just buy a new stator there only about a 10r anyway ive got a new redtifier so that rules that out thanks for your help.
and thanks to everyone else for there help to Wink Wink
The last post was made 14 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.26 - MySQL Queries: 16 - Page Size: 150.75 Kb
