Restricting 33bhp
parkmoy
PostPosted: 11:58 - 21 Oct 2011    Post subject: Restricting 33bhp Reply with quote
I have a honda deauville nt700 2006 which needs restricting. The kit is a throttle restrictor at £170 plus 1 1/2 hrs labour if fitted by honda. Seems expensive. Anyone any diy suggestions?
PostPosted: 13:21 - 21 Oct 2011    Post subject: Reply with quote
Wow, £170 for 50p of parts, plus 90 minutes labour to screw it on? That makes Fi International look like the model of fair and reasonable vendors. Shocked
Here's what I'd do. Call your local dyno place, since you'll presumably be wanting the same kind of meaningless bit of paper that Fi or Honda would provide. Ask them for their advice - they've doubtless done this before.
If you're looking for ideas, find where the throttle inner emerges from the cable near the carbs/throttle bodies. Could you crimp a fishing weight (split shot) on to it to stop it withdrawing into the outer cable?
kramdra
PostPosted: 14:05 - 21 Oct 2011    Post subject: Re: Restricting 33bhp Reply with quote
check ebay for a used kit. Since yours is a 700, probably fuel injected, make sure it includes the throttle stop as well as washers.
Expect it to be around £30-50, and fit yourself.
Take to local dyno place. Cost me £15 for printout, 32.7bhp Smile
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 19:07 - 21 Oct 2011    Post subject: Reply with quote
Depends. The ER6 is ECU and throttle stop.
A throttle stop by itself should work, and is the simplest option for a DIY bodge. It's also the easiest to have "fall off" when you judge it appropriate. Shifty
PostPosted: 10:19 - 22 Oct 2011    Post subject: Reply with quote
Actually, now that I think about it, isn't the ER6 ECU, throttle stop and swapping a bit of wiring around? No, I have no idea why it's so complicated. Confused
andys675
PostPosted: 08:14 - 23 Oct 2011    Post subject: Reply with quote
Mk1GSF wrote:
What a stupid idea. IIRC, the Speed Four was throttle stop only, and the SV650 (later models) were done with ECU. So why both? Cost? Gobbins.
all triumphs are done by throttle stop if you use the factory kit, but surely honda do their own kits for this bike, have you asked a honda dealer?
parkmoy
PostPosted: 09:13 - 23 Oct 2011    Post subject: Reply with quote
See OP Confused
Frost
PostPosted: 09:18 - 23 Oct 2011    Post subject: Reply with quote
Easiest bike in the world to restrict to 33bhp, just pull one of the spark plug caps off Laughing
The last post was made 14 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 7.25 - MySQL Queries: 16 - Page Size: 73.04 Kb
