Suzuki gs125 + top end rebuild
at106
PostPosted: 20:17 - 21 Oct 2011    Post subject: Suzuki gs125 + top end rebuild Reply with quote
I thought it was about time i got some pictures up of my suzuki gs125 project. I bought it off a member for £120 with a lot of spares including an engine and frame. In the past month or so i've stripped it down and begun rebuilding it to a road worthy state.
This is the only picture i took before completely stripping it down. I do also have the tank, seat and bodywork.
https://i448.photobucket.com/albums/qq202/at106/PICT0001-42.jpg
As you can see it wasnt in great condition.
Unfortunately i didnt get any pictures of the "restoration work" i did on it, just final pictures. The major job was deciding what to do with the frame, swingarm and stands. They all had surface rust, ideally i would of had them shot blasted and powdercoated however the best price i could get this done locally was around £160, but as this is a budget build i used a wire brush and hammerite smooth.
To remove the old paint and loose rust i used a blow lamp and a wire brush drill attachment this made the old paint come off easily but it still took many hours.
Then i cleaned the parts with water to remove any dust. After they dried i painted on methylated spirits and left it to evaporate to remove any traces of oil.
Then i could finally start painting, i started with the stands as the finish didnt matter so much. I found that two thick coats were enough to provide a good finish, but if you apply too much the paint will run. Below are the finished parts
https://i448.photobucket.com/albums/qq202/at106/d.jpg
https://i448.photobucket.com/albums/qq202/at106/f.jpg
https://i448.photobucket.com/albums/qq202/at106/frt.jpg
https://i448.photobucket.com/albums/qq202/at106/g.jpg
https://i448.photobucket.com/albums/qq202/at106/h.jpg
https://i448.photobucket.com/albums/qq202/at106/t.jpg
https://i448.photobucket.com/albums/qq202/at106/rd.jpg
If you look closely the finish isnt great but for £20 it isnt bad, and hopefully it'll last.
Next step was to fit the forks. While the bike was apart i emtied the old oil and polished the lowers. I forgot to rotate these pictures so they're sideways!
https://i448.photobucket.com/albums/qq202/at106/bvh.jpg
https://i448.photobucket.com/albums/qq202/at106/hg.jpg
https://i448.photobucket.com/albums/qq202/at106/tt.jpg
Then i fitted the swing arm and i loosely fitted the shocks. Unfortunately they're decent shocks (hagon) but they've been badly looked after so they cant be reused, unless anyone knows how to rebuild them?
https://i448.photobucket.com/albums/qq202/at106/tyt.jpg
https://i448.photobucket.com/albums/qq202/at106/tee.jpg
I did also get the engine and wheels fitted however there are no pictures as i managed to break the camera Sad
However there is a possible problem Exclamation Today i decided to remove the oil pump gauze thing to clean it and in it there were lots of what appeared like flaky paint and some small metal filings. But my biggest concern is that there was a 1/2 washer sat underneath the gauze. It's been made as a 1/2 washer but i dont know where it could be from, i'll try and get a picture of it.
That's it for now, hopefully i'll get another camera sorted and have some updates on monday.
at106
PostPosted: 20:33 - 21 Oct 2011    Post subject: Reply with quote
Haha thanks Thumbs Up
I've now got a bad picture of the washer, it measures about 27mm outer and 23mm inner diameter.
https://i448.photobucket.com/albums/qq202/at106/021.jpg
The Artist
PostPosted: 21:28 - 21 Oct 2011    Post subject: Reply with quote
Luckily you picked the best 125 in the world to work on. Thumbs Up
at106
PostPosted: 13:11 - 22 Oct 2011    Post subject: Reply with quote
It's been fairly straight forward so far, the hardest part willl be all the wiring.
I've now got the pictures with the engine and wheels fitted.
https://i448.photobucket.com/albums/qq202/at106/022.jpg
https://i448.photobucket.com/albums/qq202/at106/023-1.jpg
https://i448.photobucket.com/albums/qq202/at106/024-1.jpg
https://i448.photobucket.com/albums/qq202/at106/025-1.jpg
I was going to get the indicators fitted but i need some new bolts so i didnt get a lot done, aparts from finiding i need 8 new bulbs for various things.
The Artist
PostPosted: 13:50 - 22 Oct 2011    Post subject: Reply with quote
I know the gs's wiring loom quite well so if you are wondering where something connects, post a picture and I will try and identify.
at106
PostPosted: 14:09 - 22 Oct 2011    Post subject: Reply with quote
If i find any problems i will do thanks Thumbs Up
at106
PostPosted: 18:28 - 27 Oct 2011    Post subject: Reply with quote
I've now got all the electrics fitted and working, i've also had the engine running Very Happy I would get some pics but it's currently raining Thumbs Down Now all i need to do is tidy up the wiring and fit a few small parts.
However i need the rubber part which connects the airbox to the carb so does anyone have one or know where i can get one?
pepperami
PostPosted: 18:41 - 27 Oct 2011    Post subject: Reply with quote
Pics or it did`nt happen!
at106
PostPosted: 19:44 - 28 Oct 2011    Post subject: Reply with quote
Pics tomorrow Thumbs Up
Does anyone know if the engine needs to be running for the head and tail light to work?
von1papen
PostPosted: 23:45 - 28 Oct 2011    Post subject: Reply with quote
Not a GS obvs but the Honda CG head n tail lights will only work when its running (had us stumped when initially rebuilt!)
The Artist
PostPosted: 14:08 - 29 Oct 2011    Post subject: Reply with quote
Should work without engine running. Different years might be different wiring looms though. What amp and voltage is the battery?
at106
PostPosted: 16:07 - 29 Oct 2011    Post subject: Reply with quote
The battery is 12v 7ah
The Artist
PostPosted: 18:40 - 29 Oct 2011    Post subject: Reply with quote
Lights and stuff should work when the engine isn't running.
UnspeedySam
PostPosted: 22:19 - 29 Oct 2011    Post subject: Reply with quote
Looks like a cool project. Although my RXS is in a significantly better condition I want to do something similar. I have until about March to get it ready for my girlfriend after she gets her CBT.
Might have to buy myself a drill to save wire brushing off all the old paint by hand...we'll see how patient I am...
at106
PostPosted: 18:48 - 30 Oct 2011    Post subject: Reply with quote
You can always make things better (most of the time) Laughing
You can use a hand wire brush, but if you're also using a blow lamp make sure you use a wooden one otherwise it will melt, as i found out Thumbs Up
More pictures, as you can see the wiring needs tidying up but it all works, apart from the head and tail lights. There wont be any updates over the next week or two because sixth form starts again Sad
https://i448.photobucket.com/albums/qq202/at106/034.jpg
https://i448.photobucket.com/albums/qq202/at106/035.jpg
https://i448.photobucket.com/albums/qq202/at106/036.jpg
https://i448.photobucket.com/albums/qq202/at106/037.jpg
https://i448.photobucket.com/albums/qq202/at106/038.jpg
https://i448.photobucket.com/albums/qq202/at106/039.jpg
at106
PostPosted: 17:51 - 08 Nov 2011    Post subject: Reply with quote
Small update, spent around £100 for most of the parts required to complete the bike. And i've now managed to get hold of the airbox intake rubber Thumbs Up (It did cost £18!) However now the bike wont start Sad It's got compression, spark and fuel is reaching the cylinder, hopefully i'll get time tomorrow to take a look at it.
at106
PostPosted: 22:11 - 19 Nov 2011    Post subject: Reply with quote
I finally managed to get somewhere with the bike Very Happy
After it failing to start i noticed it was leaking some oil from the engine head gasket so ive now sealed that correctly and reset the valve clearances. I also connected the battery directly to the wiring loom instead of using jump leads and it started really easily.
I then set about tidying up the wiring, the right side of the bike looks pretty neat now. Apart from the rusty exhaust but it's going to stay like that because ive heard high temp paint is unlikely to stay on.
https://i448.photobucket.com/albums/qq202/at106/IMG00057.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00056.jpg
I then tidied up the left side, obviously the wires will be hidden by the fuel tank.
https://i448.photobucket.com/albums/qq202/at106/IMG00059.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00058.jpg
Next i fitted all the bodywork to see how it looked, from a distance it looks ok but up close the previous owner has badly painted the tank and plastics. I was hoping i would be able to just touch up the bad parts but i think it might need a full respray Sad However i'll try some T cut on it first and see what happens.
https://i448.photobucket.com/albums/qq202/at106/IMG00064.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00060.jpg
I also managed to fix the lighting problem, it turns out one of the connectors was damaged so that's now sorted Thumbs Up
Ive just got a new seat for £20 delivered next to do is,
Fit the new rear shocks
Fit new front brake pads and bleed brake brake
Sort out the sidestand spring
Buy and fit new tyres
And torque up the handlebars
Does anyone know what type of headlight bulb this bike takes?
tvchimp
PostPosted: 10:06 - 20 Nov 2011    Post subject: Reply with quote
BA20D bulb.
Best place is probably ebay, all the same apart from the xenon ones which are brighter (i know, have used the standard vs. xenon ones).
I've used this supplier before for bits and they're quick delivery and packaged well so shouldn't be broken when you receive it..
https://www.ebay.co.uk/itm/H6M-BA20D-395-XTREME-WHITE-XENON-MOTORBIKE-35-35W-BULB-/220656857279?pt=UK_Motorcycle_Parts&hash=item33602c70bf
nice looking bike Thumbs Up
at106
PostPosted: 10:14 - 20 Nov 2011    Post subject: Reply with quote
tvchimp wrote:
BA20D bulb.
Thanks and thanks for the link Thumbs Up I'll get one of them ordered.
at106
PostPosted: 16:29 - 24 Nov 2011    Post subject: Reply with quote
Managed to get some work done on the tank today. First job was to remove the lock as i didnt get the key for it. That was much more difficult than expected! I then set about stripping the paint off the tank. And revealing the original blue.
https://i448.photobucket.com/albums/qq202/at106/IMG00093.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00092.jpg
Hopefully i'll get that finished saturday and prepped for painting. After some experimenting i've decided to use hammerite smooth black seing as i've still got half a tin. I discovered if you paint it on leave it to dry then use wet and dry it comes up pretty good, then i'll use halfords petrol resistant lacquer.
I also fitted my new shocks today aswell as the headlight bulb.
The Artist
PostPosted: 19:15 - 24 Nov 2011    Post subject: Reply with quote
I have used that stuff loads.
Do lots of very thin coats and let it cure properly like it says on the tin. Do it in a warm place as well. If you do any coat too thick and it runs, it is fucked from then on.
at106
PostPosted: 19:57 - 24 Nov 2011    Post subject: Reply with quote
Thanks for the tips Thumbs Up When i apply the lacquer do i need to key the painted surface?
at106
PostPosted: 17:16 - 07 Dec 2011    Post subject: Reply with quote
Thought id update this a bit as i havent posted for a while. I've had quite a bit of time to work on the bike but dont seem to have got much done Confused
But today i managed to shorten the wiring loom so i could fit the headlight and i also fitted the headlight.
I've now also painted and smoothed the tank, and it looks suprisingly good. I'll get some pictures at the weekend. Now i just need to apply suzuki decals and lacquer it. But i'll wait for some warmer weather to do that.
I've also polished the body panels using T cut and they actually look good, so i wont have to repaint them Smile
Does anyone have a picture of how the front brake pads and clips are ment to go together?
Thanks
at106
PostPosted: 19:14 - 10 Dec 2011    Post subject: Reply with quote
Pictures as promised Smile
Front view showing the headlight fitted, however today i discovered that main beam is brighter but points lower than dipped beam so i need to sort that tomorrow.
https://i448.photobucket.com/albums/qq202/at106/IMG00122.jpg
New rear shocks from a ybr125 (i think) they bolted straight on.
https://i448.photobucket.com/albums/qq202/at106/IMG00123.jpg
Left side panel after a quick polish Cool
https://i448.photobucket.com/albums/qq202/at106/IMG00124.jpg
Fuel tank painted with hammerite. It still needs suzuki decals and lacquer applying then hopefully it'll shine Very Happy
https://i448.photobucket.com/albums/qq202/at106/IMG00126.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00127.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00128.jpg
https://i448.photobucket.com/albums/qq202/at106/IMG00129.jpg
Sorry for the bad pictures
The last post was made 14 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 16 - Page Size: 141.31 Kb
