Author |
pb399 |
pb399 L Plate Warrior
Posted: 15:28 - 03 Aug 2004 Post subject: Honda CG125 smoking exhaust |
Hi,
Just inherited a 1991 CG125, 16k miles and pretty good condition except the exhaust smokes alot when I rev it.
I've got a Haynes manual which says it could be the valve guides or piston rings - does anyone have any idea of how much it costs to get a new set of piston rings and the cylinder rebored? What the hell are valve guides? Would it be cheaper to try and get an old CG and swap the engine?
Also, how hard would it be to fix myself - I have access to lots of tools and a bit of mechanical experience, but not huge amounts of time. The bike runs ok, but it's a bit anti-social to leave clouds of smoke behind every time I pull off
Any tips? Anyone out there fixed a CG before - any help much appreciated |
Back to top |
mr jamez |
mr jamez World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
badlydamaged |
badlydamaged Spanner Monkey
Back to top |
Big Pete |
Big Pete Spanner Monkey
Posted: 17:38 - 03 Aug 2004 Post subject: |
if you google David Silver Spares (Honda specialist), you can check the price of parts online. If it need a rebore you will need a full piston kit (piston, rings, gudgeon pin and clips) and a top end gasket set. Rebores tend to be around £10-15 per cylinder. If you have a manual and a few tools its not that bad a job, and its a good learning experience. Valve guides are a bit more of a pain, but still not a massive job (all tho you will need to get a special drift made). Its only a single cylinder bike after all. Thinking about it is far worse than actually doing it.
However, if the engine has stood for while, as has been said before, give it a service and then just ride it for a while.
Last but not least, I wouldnt buy another engine from the breakers, there is a good likelihood that the motor is no better, and for the same money you could rebuild yours. ____________________ Trust me, I`m an engineer
GarageOfPower.co.uk |
Back to top |
pb399 |
Back to top |
pb399 |
Back to top |
pb399 |
Posted: 12:26 - 18 Aug 2004 Post subject: |
emm that should be the service didn't help much |
Back to top |
ts50x0 |
ts50x0 Spanner Monkey
Posted: 13:18 - 18 Aug 2004 Post subject: |
if your thinking of getting a new engine anyway then just ignore it and keep an eye on the oil level. if it goes bang(practicaly unheard of for a cg) then just put a new engine in then.
surly it cant smoke as much as an nsr anyway???????? |
Back to top |
TheShaggyDA |
TheShaggyDA Repost Police
Back to top |
pb399 |
Posted: 10:44 - 07 Sep 2004 Post subject: |
Finally bit the bullet and replaced the rings last weekend - job went ok except for a few tricky to remove gaskets and one sheared nut that somehow I was able to get out with a pliers ! The piston and cylinder had a small amount of vertical scoring but I ignored it for the minute and put it back together anyway.
First few kicks, nothing happened...then I remembered to reconnect the spark plug
Another 10 or so kicks before I noticed the fuel tap was still turned off...
Then it started on the third go!! No smoke, quiteter running and feels like it's got a bit more power, though I'm still running it in. Broke the kickstart lever off this morning but besides that there's been no trouble - it's easy to bump start anyway.
Thanks everyone for the help and encouragement |
Back to top |
Frost |
Frost World Chat Champion
Posted: 11:05 - 07 Sep 2004 Post subject: |
If it wasnt for bad luck, you'd have no luck at all! |
Back to top |
palmer |
palmer Fiddled Kiddy
Back to top |
ZRX61 |
ZRX61 Victor Meldrew
Back to top |
mchaggis |
mchaggis World Chat Champion
Back to top |
RooRoo |
RooRoo Anal Intruder
Back to top |
The last post was made 19 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
