Fork seals
deputy
PostPosted: 11:27 - 10 Aug 2004    Post subject: Fork seals Reply with quote
I have a 1989 NSR. The fork seals are leaking, but the problems is that the forks do not appear to be standard. The forks are Showa, where would I get a set of fork seals for these?
McJamweasel
BCF Junkie
PostPosted: 13:50 - 10 Aug 2004    Post subject: Reply with quote
What makes you say that they are Showa forks?
The chances are that if its cos there are stickers on them then thats all it is - stickers. I've seen quite a few imported NSR's with Showa stickers on the bog stock forks.
BCF: Be yourself, just don't be an arse.
PostPosted: 14:32 - 10 Aug 2004    Post subject: Reply with quote
Its quite likely that all NSR's have Showa forks.
Showa make pretty much all Honda suspension afaik. Thumbs Up
Frost
PostPosted: 18:14 - 10 Aug 2004    Post subject: Reply with quote
my ancient shitty honda has showa forks. the normal seals will fit.
PostPosted: 19:23 - 10 Aug 2004    Post subject: Reply with quote
Except the NSR was designed and built in Italy, mainly for the Italian market and used a large percentage of Italian sourced components to avoid import duty. Only the last NSR used Showa forks, most had Marzocchi forks and shock.
deputy
PostPosted: 08:27 - 13 Aug 2004    Post subject: Reply with quote
Sounds like i have probably got standard forks then.
Next question, where's the best place to get oil seals?
andy lo
PostPosted: 11:04 - 08 Sep 2004    Post subject: Reply with quote
The oil seal size is 35-47-10.5,you can get it easily. Smile
93 nsr125rp
Frost
PostPosted: 14:06 - 08 Sep 2004    Post subject: Reply with quote
local honda dealers, expect to pay £7.50 each for them. fork oil is about £6 per bottle, and make sure you have some way of getting the front wheel out
ZRX61
Victor Meldrew
PostPosted: 22:42 - 08 Sep 2004    Post subject: Reply with quote
H*nda own Showa.....
The last post was made 19 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 17 - Page Size: 61.54 Kb
