Household radiators
PostPosted: 13:55 - 22 Nov 2011    Post subject: Household radiators Reply with quote
Just looking at the radiator in the spare room which I want to turn off. There appear to be 2 valves on the radiators in the house, one at each end. But on most one has a knob to enable it to be turned and the other has a blanking piece over the top.
Can either be used to turn off the radiator or is there a reason only one has a knob on it?
Reason I ask is the radiator I want to turn off has at one end no knob or blanking piece (would be easy enough to turn with a spanner, if I should) while the other end is hidden behind a filing cabinet and I can see it let alone turn it if it has a knob on it.
Raffles
PostPosted: 14:17 - 22 Nov 2011    Post subject: Reply with quote
Domestic radiators are normally controlled by one adjustable valve. The valve at the opposite end is for balancing the flow and does not normally have a means of adjustment other than a spanner. As for completely shutting down the radiator then either valve can be used for this purpose.
PostPosted: 14:25 - 22 Nov 2011    Post subject: Reply with quote
Cheers. The valves on the radiators I can see look the same on both ends, just one has a plastic knob and the other has a plastic cap covering the bit the knob turns.
Raffles
PostPosted: 14:30 - 22 Nov 2011    Post subject: Reply with quote
Just close the one that is the most accessable. It doesnay matter which one you choose as either one will stop the flow.
PostPosted: 14:39 - 22 Nov 2011    Post subject: Reply with quote
Thank you. That is what I thought (and hoped), just wasn't sure if there was some reason not to do that.
Robby
Dirty Old Man
PostPosted: 14:47 - 22 Nov 2011    Post subject: Reply with quote
You can use either, one is the inward flow and the other is the outward. The reason to have one at each end is so that you can turn both off to isolate the radiator for removal.
PostPosted: 15:08 - 22 Nov 2011    Post subject: Reply with quote
Although it must be said, I have found that if you turn them fully off using the outlet valve only, they can leak a little round that valve.
Doesn't happen if you turn them off using the inlet valve.
I think the pressure coming up the pipe tends to hold the inlet valve closed against its seat. If there is a little slack in the outlet one, the pressure tends to force it the other way and it can seep a little up round the shaft.
So I'd always turn it off using the inlet valve, which is the one with a proper knob on it or the one on the hotter of the two pipes when it's first turned on.
JonB
Afraid of Mileage
PostPosted: 17:22 - 22 Nov 2011    Post subject: Reply with quote
Come on, who hacked The Oracle's account?
PostPosted: 17:40 - 22 Nov 2011    Post subject: Reply with quote
Not hacked, just don't fancy flooding the house (I hate household DIY) and couldn't see any obvious reason to have 2 valves of the same type but only one with a knob on it.
TomCB
PostPosted: 17:42 - 22 Nov 2011    Post subject: Reply with quote
Turn it off with the TRV if you want it off (the one with the numbers on)
as said before, the one with the cap is for balancing the flow. you dont want to be balancing the rad up later on when you can just turn the TRV off and have the same result.
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
PostPosted: 17:49 - 22 Nov 2011    Post subject: Reply with quote
Laughing . Way too old to have a thermostatic valve. And getting at the other one means taking everything off the top of a filing cabinet, emptying it and moving a few piles of stuff to move the filing cabinet.
swampy
PostPosted: 18:13 - 22 Nov 2011    Post subject: Reply with quote
I'm just waiting for G to move this to Dear Aunty BCF...
Its gonna be like a golden blob clash of the titans... Very Happy
Oh, and if you turn off using the TRV, isn't there a risk of the valve opening and flooding your carpet ?
herulach
PostPosted: 18:21 - 22 Nov 2011    Post subject: Reply with quote
Generally ok, but definitely no if you're disconnecting the rad. Most TRVs will open at around 4 degrees fucking you up if you rely on it.
YBR 125>FZS600
PostPosted: 18:25 - 22 Nov 2011    Post subject: Reply with quote
Only one radiator in the house has a thermostatic valve (one that was replaced a few years ago).
Don't want to take the radiator off, just turn it off when the room isn't in use.
TomCB
PostPosted: 08:41 - 23 Nov 2011    Post subject: Reply with quote
my bad, i was thinking you just wanted it turning off, not actually disconnecting Embarassed
McJamweasel
BCF Junkie
PostPosted: 10:10 - 23 Nov 2011    Post subject: Reply with quote
When you turn it off you might find that it leaks a little from the valve, if it does just tighten the nut thats on top of the valve a little and it will stop. Thumbs Up
The last post was made 14 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 91.71 Kb
