Car thread - How bad are Alfa Romeos these days?
garth
PostPosted: 14:56 - 06 Dec 2011    Post subject: Car thread - How bad are Alfa Romeos these days? Reply with quote
In particular 2003 ish 147 JTD Diesels.
Anyone had any experience?
PostPosted: 15:07 - 06 Dec 2011    Post subject: Reply with quote
No experience with the diesels, but happy with the petrol ones. The 156 we have is certainly better built than the Jaguar X Type we have.
What a 147 will use (and a 156 or a GT) is the upper suspension arms. They are fairly cheap and easy to replace but expect to replace them every 30k.
We have had our 156 since 102k and it is now on 147k. Non service bits it has needed are a MAF sensor, several side light bulbs, the resistor unit on the radiator for the fan, battery, a heater servo motor, set of brake disks, front brake hoses, a rear caliper, rear window winder mechanism and the upper suspension arms. Power steering pipes also got damaged on a speed hump. None of these things have been that expensive nor most difficult to change (power steering pipes were a pain though).
Also replaced the cam belts and the clutch (belts as a service item, clutch probably didn't need doing but at least means we can forget about it now)
groovylee
PostPosted: 02:48 - 07 Dec 2011    Post subject: Reply with quote
Alfas are only as good or bad as the person that owns them. keep on top of the required maintenance, and they will do fine.
just one thing to note, the cambelt changes on the twinspark petrol engines are 36K or 3 years, whichever is the soonest. DO NOT let anyone tell you otherwise, it will end up costing you.
for more info, you could try www.alfaowner.com (i used to be the south east regional rep on there, good bunch really)
apologies for the link, if i shouldn't post it please remove, but they really are one of the best sources of info for all alfa stuff.
hope it helps
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
st3v3
PostPosted: 03:38 - 07 Dec 2011    Post subject: Reply with quote
groovylee wrote:
Most vehicles are only as good or bad as the person that owns them. keep on top of the required maintenance, and they will do fine.
Edited for Accuracy.
See, this annoys me.
You say "36K or 3 years, whichever soonist"... how does that work?!
Surely it's JUST a distance thing with wear and tear, because if a car is sat stored with 12K on the clock for 7 years according to your comment it would need a cambelt change twice while storage depsite not moving a millimetre.
More realistically, let's say it's just driven round town doing 11K miles a year. that means in 3 years it does 33K, so if there's still a quota'd 3K left why does it need doing at the 3 year mark; not 3 years and 4 months?
defblade
PostPosted: 07:54 - 07 Dec 2011    Post subject: Reply with quote
Twin sparks can have a ....minor.... problem with cylinder #3 if the previous tightfisted pikey bastard owners used cheap oil:
https://img.photobucket.com/albums/v471/defblade/conrod.jpg
But I can't say about diesel engines as I've now had an Alfa and don't feel the urge again Wink
In the meantime, my 156 had had a LOT of welding to the floor and the suspension, while nice and accurate, was too soft for pushing on. And the electrics were buggy. But I did like it... until the engine went Very Happy
Robby
Dirty Old Man
PostPosted: 08:11 - 07 Dec 2011    Post subject: Reply with quote
My father in law to be has a 2003ish 147 with the 1.6 petrol engine. He loves it, great car to drive.
However, it has had the following problems:
Cam belt went at 40k/4 years. Needed a replacement engine, Alfa didn't pay for any of it.
Variator wasn't replaced at the last cambelt change, so it sounds like a diesel when warming up.
3 of the 4 door bottoms are very rusty, a screwdriver would punch through them.
Poor fuel burn - mostly used around town, achieves about 25 to the gallon. Driven in a fairly Italian manner though.
He wishes he had gone for the 2 litre, it is quite a heavy car and you don't save anything from having the 1.6, the fuel burn is the same as you would expect from the 2.0.
Would be quite a good buy now, seeing as they don't cost a great deal and will do a few years service before becoming terminal. Don't buy a scabby one and pour loads of money into making it perfect though, money down the drain. Show it too much love and it'll reward you by breaking.
garth
PostPosted: 10:39 - 07 Dec 2011    Post subject: Reply with quote
This is what I'm considering.
https://www.ebay.co.uk/itm/250945202106?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
PostPosted: 11:27 - 07 Dec 2011    Post subject: Reply with quote
Belts degrade with age and exposure to oils, etc. And sat still without moving they tend to get a natural bend where they go round pullies.
I wouldn't worry too much about the 3 years like that if not used, but would be more inclined if that were 3 years of doing 5k rather than 12k.
Alfa used to specify 72k for the cam belt change interval on the TS engines but changed that the 36k.
Shouldn't be from the oil used, rather people not keeping the oil topped up. They have a fairly small sump and when they get to 80k or so with typical use the oil consumption can get enough that they will need topping up between services. Fail to top it up and the oil level drops enough to lose oil pressure (maybe when cornering hard). If the previous owner was dodgy they then quickly top it up and sell it on so when the crank goes a few thousand miles later it is someone elses bill.
He wishes he had gone for the 2 litre, it is quite a heavy car and you don't save anything from having the 1.6, the fuel burn is the same as you would expect from the 2.0..
They should be way better than that and the 1.6 should be noticeably better on fuel than the 2L (friend who worked for an Alfa specialist went for a 1.6 because of how much better on fuel they were than the 2L engines - and he had plenty of them to play with).
What does kill the fuel consumption is a dead thermostat. The ones on the TS engines seem to fail almost always open so the car doesn't overheat but runs cold, and when cold they run richer and drink petrol.
Garth - doesn't mention the upper arms being replaced although just claims they are all OK. I would budget on new ones at some point fairly soon, but they are only about £50 each for OE ones and fairly easy to change (if all goes well about half an hour each on the drive, although budget on some ARB drop links as well so if they are a pain you don't care about wrecking them).
PostPosted: 14:16 - 07 Dec 2011    Post subject: Reply with quote
Can't give much insight, but had a 2008 Spider JTDM 2.4 hire car with 18000 miles on it.
After a week it decided to lose oil pressure and I watched the oil level plummet and car went into limp mode and broke down.
Before that, was fantastic. It has put me off one but I heard it was just a sensor that went faulty and the ECU decided to cut it to 30mph Laughing
Kwaks
I'm not a fast rider
PostPosted: 15:02 - 07 Dec 2011    Post subject: Reply with quote
had a 147 selespeed, 2L petrol. Loved that car but had a few problems with the selespeed so got rid. Engine and bodywork were spot on though
www.cliqueycuntsmcc.co.uk
defblade
PostPosted: 16:57 - 07 Dec 2011    Post subject: Reply with quote
The exhaust runs too near big end #3 under the sump.... cheap oil cooks out of the bearing from exhaust heat each time it's parked up (I now know).
No oil pressure light, even on corners, until one day you let off the throttle a little bit and notice the car slows down too much. Oh, you think, I wonder if a brake is binding? Nearly home, I'll check if anything's hot when I get there. Back on the throttle again (slower person in front just moved over out of right hand lane on dual carriageway) and then the oil pressure light comes on... but the BOOM, instant fog bank, loss of power and bits rattling down the bottom of the car told me more Wink There was plenty of oil in it.....
PostPosted: 17:22 - 07 Dec 2011    Post subject: Reply with quote
Not so sure on the exhaust cooking the big end as plenty of oil and metal in the sump to act as a heat sink. Oil light I meant was for the previous owner letting the level get low, damaging the big end but not immediately terminal so they flog the car quick.
One other issue that people suffer on the TS engine is from a bodged repair following a cam belt failure. These are an interference engine so a snapped belt will result in a load of bent valves, but also often it seems to damage the big ends which fail shortly after the valves are sorted.
andys675
PostPosted: 18:43 - 07 Dec 2011    Post subject: Reply with quote
the wife's nephew (ron) has a brera
one of the car buying web sites refused to make him an offer for it
so now our kids sing to him "we buy any car, not ron's!"
defblade
PostPosted: 19:10 - 07 Dec 2011    Post subject: Reply with quote
Ah, could have been that.....
PostPosted: 19:33 - 07 Dec 2011    Post subject: Reply with quote
As an aside, if it is a 2.2 petrol Brera then the engine is basically a GM engine unit with an Alfa head. It was a joint venture between Fiat and GM, as was the platform. Fair few GM versions of that engine around but I think only the 159 and Brera / Spider used the platform (it was meant to have been used by Saab as well).
knocker
PostPosted: 20:30 - 07 Dec 2011    Post subject: Reply with quote
Bought my first Alfa, a 156 six months ago and absolutely love it.
The clutch hydraulics have recently started giving me grief and the front suspension creaks a bit now and then but other than that it's been great. Lovely to look at and even better to drive.
It certainly won't be the last alfa I buy.
Shaft
PostPosted: 20:44 - 07 Dec 2011    Post subject: Reply with quote
It was used by Saab and that engine is a boat anchor; they suffer from sudden and unexplained timing chain failure, with catastrophic results.
They have also been known to snap the valve slippers, seizing the top end, with the same result.
Oldie
PostPosted: 20:51 - 07 Dec 2011    Post subject: Reply with quote
My 156 was superb - great value for money. Only ever had the one problem and that was with the wipers
PostPosted: 00:21 - 08 Dec 2011    Post subject: Reply with quote
Sorry, didn't put it very well. The engine was used in plenty of thigs but the platform was meant to be used by Saab as well that seemed to die a death.
In Alfas the engine isn't too bad for reliability. The timing chains do wear out but seem to trigger issues without snapping (engine management detects the cams getting slightly out of phase and lights the dashboard up like a Christmas tree).
Overweight lumps though (car and engine).
Shaft
PostPosted: 01:12 - 08 Dec 2011    Post subject: Reply with quote
IIRC, part of GM's Grand Master Plan was to produce a 'small' Saab, but that coincided with that particular division's downturn in fortunes (no doubt brought on by the distinctly average Vauxhall 9-3) so it never happened.
Shame about Saab, if Top Gear reckon you aren't a true petrolhead until you've owned an Alfa, Saab should be #2 on the list, or would be if GM hadn't buggered them up.
Irn-Bru
PostPosted: 01:40 - 08 Dec 2011    Post subject: Reply with quote
garth wrote:
The shell of that car looks very much like an old pre 2002 Fiat Bravo one Thinking
Shaft
PostPosted: 01:52 - 08 Dec 2011    Post subject: Reply with quote
^^^^ No great surprise, it's essentially the same car, although every cosmetic panel is different.
DXB
PostPosted: 04:29 - 08 Dec 2011    Post subject: Reply with quote
Had a 1996 3.0 liter Spider, bought some parts from Autodelta for it, was an epic car when running, but broke down with monotonous regularity.
superchargers good
The last post was made 14 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.05 - MySQL Queries: 16 - Page Size: 137.21 Kb
