| lucky rsm |
 lucky rsm Renault 5 Driver
| Mikey CB500 |
 Mikey CB500 Scooby Slapper
| Babba |
 Babba Banned
| Noxious89123 |
 Posted: 23:21 - 07 Jan 2012 Post subject: |
Sure they didn't just swap then left and right seals over?  ____________________
| lucky rsm |
| Noxious89123 |
 Posted: 20:49 - 08 Jan 2012 Post subject: |
It's pretty easy job to remove the forks, the trickier bit is working out how to support the bike. I put mine on its centre stand then used loads of wooden blocks under the down pipes to support it. When on the centre stand, there is very little weight on the front on the bike.
Then it's just a case of removing the mudguard, brake calipers (I used some wire with a hook shape bent into each end to put through the caliper bolt holes and hung them off the bottom yoke.) and handlebars, axle and finally the wheel. Undo pinch bolts and slide out
Make sure the front of the bike is high enough so that when you drop the forks down you can remove them from the bottom yoke before they hit the floor! I didn't think about this and only had about an inch to spare. Also the forks might need a bit of wriggling and twisting to get out of the yokes once loosened, but they might also slide out under their own weight, so don't drop them onto the floor! ____________________
| P.addy |
 P.addy Red Rocket
 Posted: 20:55 - 08 Jan 2012 Post subject: |
If you get stuck you aren't massively far from me, its a piece of cake job once you have learnt how to do it  |
| lucky rsm |
| st3v3 |
 st3v3 Super Spammer
| lucky rsm |
| Babba |
 Babba Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:34 - 10 Jan 2012 Post subject: |
Bit of thin plastic or a feeler gauge, wiggle it up around the seal, see if that fixes it. If not, you lost 5 minutes. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 14 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
