Heating issues
grantl
PostPosted: 12:04 - 19 Sep 2004    Post subject: Heating issues Reply with quote
bike CBR 250r
bike runs fine, *however* seems to have an over heating issue,
i have followed the guide on flushing the radiator didn't help that much.
the thing that iam most concerned about is this when crusing on the freeway around 100-140 speed it seems to get worse. To the point where i have to have a time out and let the bike cool down some what. ( i thought on the freeway would over best chance of cooling down due to increased airflow.)
any ideas as to what the problem may be?
and how i can go about fixing it.
alains
PostPosted: 12:24 - 19 Sep 2004    Post subject: Reply with quote
take off the thermostat , then run for a while . if you go fine then buy a new one . it's not necessary to change the seal , just put some loctite .
PostPosted: 15:52 - 19 Sep 2004    Post subject: Reply with quote
Try the thermostat thing but you may find that the head gasket is blowing and pressurising the coolant system, this is a fault that tends to show itself at higher rev speeds.
When it overheats, stop and quickly check the level in the expansion bottle, if it has filled up the bottle with coolant (possibly even overflowing), I would be very suspicious of the head gasket. You fix this by replacing it, which is a pain in the arse.
Finglonga
PostPosted: 16:18 - 19 Sep 2004    Post subject: Re: Heating issues Reply with quote
grantl wrote:
bike CBR 250r
Question Describe what it happening. ''Seems to have an overheating issue'' is a bit vague its like saying 'my engine wont run properly'......everyone will try to help but you will get loads of wrong answers.
Why do you say its got a problem?
Andy Sez....
F.Y.Y.F.F.
grantl
PostPosted: 01:26 - 20 Sep 2004    Post subject: Re: Heating issues Reply with quote
Finglonga wrote:
grantl wrote:
bike CBR 250r
i thought i did i dont know how else i can put it, (when i say heating issue i mean the temp guage will red line if i dont stop)
the bike just seems to run hot especially when on the high way at higher revs eg, 10k and upwards, i have found if i get of the highway and take it easy around 8k revs it seems to cool down somewhat, however it still remains over 3/4 until i give the bike a complete break.
i haven't experinced and problems with the bike when it is running hot it seems to go ok, i havn't heard any strange noises.
grantl
PostPosted: 01:31 - 20 Sep 2004    Post subject: Reply with quote
interesting i will check this next time
thanks a bunch for post
Finglonga
PostPosted: 18:44 - 20 Sep 2004    Post subject: Reply with quote
Sounds like that Crying or Very sad Crying or Very sad
You may also find your coolant is turning darker also wich also points to head gasket. Thumbs Down
Andy Sez....
F.Y.Y.F.F.
The last post was made 21 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 16 - Page Size: 55.79 Kb
