Rust in tank!
MG#43
PostPosted: 14:54 - 12 Feb 2012    Post subject: Rust in tank! Reply with quote
Hi,
I've tried a search for this and haven't found anything yet. Anyone got any tips for rust in fuel tanks? It's not too bad, just the bag a bolts i chucked in and swirled around in brake cleaner hasn't done the trick. I'm going to try some Oxalic acid solution and leave in the tank for a while... Anyone tried this?
thanks! Smile
MickC
PostPosted: 18:07 - 12 Feb 2012    Post subject: Reply with quote
Here's a link to an older thread discussing your problem.
https://www.bikechatforums.com/viewtopic.php?t=214555&highlight=rusty+tank
Hope it helps
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
MG#43
PostPosted: 19:14 - 12 Feb 2012    Post subject: Reply with quote
Hope it helps
Not seeing any links there chap - unless i'm being a bit thick of course!! Smile
PostPosted: 19:29 - 12 Feb 2012    Post subject: Reply with quote
If the search function isn't working for you try this
https://www.google.co.uk/search?q=rust+in+tank+site%3Awww.bikechatforums.com&hl=en&num=10&lr=&ft=i&cr=&safe=off
MickC
PostPosted: 19:34 - 12 Feb 2012    Post subject: Reply with quote
Embarassed Fixed it
XX XXXx
bikenut
PostPosted: 15:14 - 13 Feb 2012    Post subject: rust Reply with quote
Karma ( sorry admin ) hi dude,
water getting in somehow, past rubber seal.........
when tank flushed ( and plumming, tap etc, then carb ) try to see if the small vw type petrol filter will fit tween tank and carb, these will stop all crap ( even water ) from getting to the carb.
have fitted these to bikes for years now, they work with no problems for gravity feed systems but didnt on my kwak750, which had vaccum tap ( it did work on prime position though ).
bikenut
PostPosted: 15:16 - 13 Feb 2012    Post subject: oxalic acid Reply with quote
Karma oxalic acid, brilliant for rust but not tried with petrol? do test first, its nasty stuff so be carefull.
The last post was made 14 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 55.36 Kb
