hot do I fit a chain?
eugeweener6
PostPosted: 13:25 - 24 Sep 2004    Post subject: hot do I fit a chain? Reply with quote
ive got an o ring chain but dont know how to fit it, any help would be great
carvell
Scuttler
PostPosted: 13:31 - 24 Sep 2004    Post subject: Reply with quote
Undo the old chain from the link that you can split the chain with.
Attach the front of the new chain to the back of the old chain.
Turn the wheel, the old chain will pull the new chain on.
Yamaha TDM 850
eugeweener6
PostPosted: 13:35 - 24 Sep 2004    Post subject: Reply with quote
how do I undo the link? do I need a special tool?
mchaggis
PostPosted: 13:41 - 24 Sep 2004    Post subject: Reply with quote
A small screwdriver worked for me. Whistle You have to basically lever one of the 'legs' up, hopefully not resulting in it going ping and flying away.
PostPosted: 14:51 - 24 Sep 2004    Post subject: Reply with quote
If its an 'o' ring chain, then you will need to use the rivet link. I am guessing this is on a bike greater than 400cc...
You will need a special chain riveting tool to connect the chain correctly. If you do not do this and use the split link that comes with the chain, it must be done only as a temporary measure.
If you have no chain rivetting tool, then I suggest that you keep the old chain on and get a garage to replace the chain.
Its definitely worth replacing the sprockets too while you are at it because the worn sprockets will only kill the new chain in short order.
Hope this helps! Smile
Frost
PostPosted: 15:23 - 24 Sep 2004    Post subject: Reply with quote
Chain splitter/riviter tools are VERY expensive to buy. Borrowing one is a good idea if you know a kind fellow who owns one. otherwise garages tend to do it fairly quickly and cheaply, as its a common job, just like replacing tires
eugeweener6
PostPosted: 15:39 - 24 Sep 2004    Post subject: Reply with quote
thanks guys, its an aprilia rs125, ive also got a new Renthal Sprocket and I know hot to fit that. Its just going to be a B**ch to fit the new chain
mr.z
PostPosted: 15:43 - 24 Sep 2004    Post subject: Reply with quote
Defenately change the sprockets as said, otherwise your just going to waste money!
To be honest if you dont have the propper tools then get sombody else to do it this time, chains are not to be messed with, too tight they will snap.. which is bad, too loose and it will jump off the gears, which is bad...
Ive seen all in one tools for £40 which if your going to allways do them yourself is a worthwhile investment Razz (if you plan on allways owning a bike chances are it will have a chain)
Guest
PostPosted: 17:46 - 24 Sep 2004    Post subject: Reply with quote
Why are you fitting an 'O' ring chain to a 125?
eugeweener6
PostPosted: 18:09 - 24 Sep 2004    Post subject: Reply with quote
why not??
PostPosted: 18:36 - 24 Sep 2004    Post subject: Reply with quote
eugeweener6 wrote:
why not??
They last longer, but cost far more. They need less frequent maintenance, but absorb slightly more power.
Swings and roundabouts really, but on a 125 I personally would not bother to use an O ring chain as the extra cost is not really justified.
Finglonga
PostPosted: 19:28 - 24 Sep 2004    Post subject: Reply with quote
Hope this is a typo!
Always replace the sprockets in pairs or you will get premature wear.
Andy Sez....
F.Y.Y.F.F.
Guest
PostPosted: 20:05 - 24 Sep 2004    Post subject: Reply with quote
eugeweener6 wrote:
why not??
What Keith said, it's needless expense in my opinion too. You certainly don't need the supposed security of an endless chain either, for many years 1000cc bikes ran quite happily on split links and they make maintenance jobs a lot easier. Fitted correctly they are just as secure as a rivetted chain link.
As others have said, always replace chain and both sprockets as a set, keep it clean and well lubed and it'll last for several ring changes Wink
dandit
PostPosted: 18:56 - 26 Sep 2004    Post subject: Reply with quote
where bouts do you live then
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 1.21 Sec - Server Load: 0.71 - MySQL Queries: 18 - Page Size: 82.76 Kb
