Stalling in neutral
Alpha-9
PostPosted: 12:40 - 23 Mar 2012    Post subject: Stalling in neutral Reply with quote
How?
This morning was odd, my bike started up fine in neutral, as i always switch it off in neutral too, I grab the clutch and start it up as I do from habit in case it's in first, but releasing the clutch it stalls - But it was in neutral
How can this happen? Even weirder I tried it again and it stalled like 3 times in neutral when I released the clutch...then it wouldnt start up properly! Made the chokey chufchuff noise and didnt start...
First time it's been like this, but I just gave it some revs as I tried to start it and it was fine, and rode the same as ever.
I've stopped in neutral a couple of times and released the clutch and its jolted forwards and stalled too...
Is it just a 'false neutral' or?
I wouldn't want it to be a symptom of an underlying issue
Didn't really want to post a thread about it as I don't think it's that major, but noones in chat and I cant access it from work anyway Crying or Very sad
I worry about my gearbox, especially after hearing YBRs can get angry gearboxes
Confused
Fzr-600 1999
daemonoid
PostPosted: 12:57 - 23 Mar 2012    Post subject: Reply with quote
Neutral light isn't always correct. It probably wasn't properly in neutral.
current: ducati monster 750
Jefr0
PostPosted: 13:00 - 23 Mar 2012    Post subject: Reply with quote
Was it not just cold?
Also, starting with the clutch held in. I'm sure on your bike even if you tried starting it in gear with clutch out it wouldn't let you as a safety feature.
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Alpha-9
PostPosted: 13:01 - 23 Mar 2012    Post subject: Reply with quote
T'was cold, but it didn't happen when I got it in winter and it was snowing Shocked
Nothing to worry about then? Better safe than sorry Very Happy
Fzr-600 1999
neil.
PostPosted: 13:02 - 23 Mar 2012    Post subject: Reply with quote
This happens quite often when the engine oil level gets a bit low or is old and in need of changing. Or it could be that your clutch cable needs some adjustment. Thumbs Up
Alpha-9
Indeed, cant start in first without clutch, thats why I always grab clutch when i start regardless
Fzr-600 1999
lihp
PostPosted: 13:04 - 23 Mar 2012    Post subject: Reply with quote
What about sidestand switch?
Does it jump when it stalls or just cuts off?
Recluso
Make sure you're not clutch-dumping either. Ease the clutch out like you would when changing gears.
Sounds more like you weren't in Neutral properly. i.e. enough for the light to show but not enough for the gear to engaged properly.
Is a problem I have now and then on my YBR too Smile
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
pits
PostPosted: 13:15 - 23 Mar 2012    Post subject: Reply with quote
Remember the Neutral light just informs you that the bulb is working.
GrumpyGuts
PostPosted: 13:47 - 23 Mar 2012    Post subject: Reply with quote
True, when I was riding the YBR, sometimes it stalled when I released the clutch. Embarassed
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Alpha-9
PostPosted: 14:04 - 23 Mar 2012    Post subject: Reply with quote
I see, the light is a light then, was probably in second actually Thinking
As i usually pull into my house in second and kick it up gently to neutral...
Makes sense Embarassed
It wasn't the side stand or anything, I can tell when its that because the oil yellow light thing comes on and it starts beeping at me Thumbs Up
Just gear faggery and neutral light lying it seems Very Happy
Fzr-600 1999
Alpha-9
PostPosted: 14:22 - 23 Mar 2012    Post subject: Reply with quote
BLUEX5 wrote:
I've heard this is a common fault on YBR's that suffer the fate of having Vinyl house numbers plastered all over the tank.
Just a thought yeah?
Your perception of space is all fucked up, there's 2 on the side!
you're just bitter because you can't get it up for the missus Crying or Very sad
Fzr-600 1999
Alpha-9
PostPosted: 14:36 - 23 Mar 2012    Post subject: Reply with quote
I r special wrote:
uninstall your anti-virus then try a reboot.
Thanks this worked!
Fzr-600 1999
Atomic Punk
PostPosted: 15:11 - 23 Mar 2012    Post subject: Reply with quote
It's called a false neutral, happens on a lot of bikes.
Check if it's in geaar by trying to roll the bike forward.
I may have lost my way but I'm way ahead of schedule.
Alpha-9
PostPosted: 15:14 - 23 Mar 2012    Post subject: Reply with quote
Oh yeah, nice tip Cool
Fzr-600 1999
Alpha-9
PostPosted: 15:29 - 23 Mar 2012    Post subject: Reply with quote
https://30.media.tumblr.com/tumblr_m0h59l1ORm1r0q2j0o2_500.png
Fzr-600 1999
The last post was made 14 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.29 - MySQL Queries: 16 - Page Size: 120.32 Kb
