Stand and Back brake problem
Aidanc80
PostPosted: 11:39 - 24 Mar 2012    Post subject: Stand and Back brake problem Reply with quote
Okay guys,
Any advice on this would be great. I take my bike off stand and brakes go on tight..
Now i gave underneath a good spray and cleaned off and it was fine for a bit but was back the other day anything that i am missing??
Thanks
Aidan
Aidanc80
PostPosted: 22:22 - 28 Mar 2012    Post subject: Reply with quote
Hi Guys, I should have said this was a honda cg 125 05..
After a bit of digging i find the stand and back brake is quite common, also noticed there seems to be a problem with swing arm and back brake. Got back wheel off and trying to get into the drum seems quite difficult is there something stupid im missing to get into drum it is spinning just not coming off!
thanks
Aidan
Ichy
PostPosted: 22:26 - 28 Mar 2012    Post subject: Reply with quote
Have you tried pushing the brake arm forwards?
Aidanc80
PostPosted: 22:45 - 28 Mar 2012    Post subject: Reply with quote
Thing seems solid! Why i wanted to have a look inside!!
tomh
PostPosted: 07:08 - 29 Mar 2012    Post subject: Reply with quote
The best thing to do with the center stand is remove the pivot pin that holds the back brake lever and cenre stand on. The CG is known for its self destructing centre stand. Once the grease dries up the pivot pin starts to move when you use the center stand and worse case begins wearing a hole in the frame. It sounds like yours is becoming dry and not freely rotating so it is worth doing before any damage is caused.
While your doing that you may as well grease the swing arm if your having problems with that.
With the rear drum brake, I'm assuming you've removed the torque arm bolt and brake cable, then removed the wheel from the bike? If so try moving the black lever when pulling the drum off.
Aidanc80
PostPosted: 09:45 - 29 Mar 2012    Post subject: Reply with quote
Thanks for the reply Tom.
Yeah after searching online i see that the stand can
have problems!!
I have the wheel off and tried to get the casing off to get into brake drum it spins but wont come out of the housing!! Will give it another go today!! Theres nothing else i should be loosening for this to pop out??
Thanks
Aidan
Ichy
PostPosted: 13:38 - 29 Mar 2012    Post subject: Reply with quote
It may be that the drum has worn and there is a lip holding onto the pads. Does the drum lift out even a small amount?
Aidanc80
PostPosted: 10:15 - 31 Mar 2012    Post subject: Reply with quote
Hi Marki,
Yeah i got it off after a lot of messing around it seems i need new back drum brakes which look simple enough to replace is there anything i must do before putting new ones on??
The stand eased off yesterday after much greasing and the heat seemed to help also who knows will keep greasing it!!
Ichy
PostPosted: 13:25 - 31 Mar 2012    Post subject: Reply with quote
For starters just give it all a good wipe out to remove the brake dust. I prefer to remove the actuator arm and pivot so that they can be cleaned and lubed, not absolutely necessary though. You do need to put a light smear of grease on the pivot points though. The shoes can be fiddly to install, just attach the springs and then forced the shoes into place.
Aidanc80
PostPosted: 16:56 - 01 Apr 2012    Post subject: Reply with quote
Perfect buddy Thumbs Up
The last post was made 14 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.34 - MySQL Queries: 16 - Page Size: 65.32 Kb
