inidcator problems
chillpill
PostPosted: 13:10 - 30 Mar 2012    Post subject: inidcator problems Reply with quote
changed back from led indis to standard ones as i could never get the leds to work (i say standard but there not the original ones they got lost in a encounter with the road) but now they dont flash they just stay on
anyone got any ideas what to check ? im retarded at electronics even though i have an a level in it lol , positive theres no short curcuits and ive emailed the guy who i bought them of asking for the wattage of the bulbs , the relay says 4x 10w so im guessing if the wattage of the bulbs are too low they will just stay on right ?
thanks , alex
Teflon-Mike
tl;dr
PostPosted: 14:21 - 30 Mar 2012    Post subject: Re: inidcator problems Reply with quote
thanks , alex
Other way round; if you have an electro-mechanical flasher, then it's pulse timing is 'tuned' depending on the load on the circuit.
Higher wattage; slower flash (Bulb blow blinky-kators, blink fash fast)
So; do you have an electro-mech flasher timed for low watt LED's? Or do you have ballast resistors loading up an electro-mech timed for Tungstens?... ie near double normal wattage!
In which case also check fuses & check you haven't burned out the flasher!
Indies are normally 21W ish, plus the tell tale, maybe 5w, so about 50W on each circuit, perhaps 90W if you have hazards on same flasher. Drawing about 4-5A if indy only, 7.5w if hazards
chillpill
PostPosted: 15:13 - 30 Mar 2012    Post subject: Reply with quote
i have an elector mech flasher for normal bulb indis
tryed the original 10w one on the bulbs , no flashing got a 21w from the shops (these are mini bulb indicators) still no flashing
relays work fine i think you can hear them clicking over
there are no hazards and the only fuse on the bike is fine
these are really doing my head in , if anyone knows where to get some standard 10w inidcators , i would be very happy unfortunatly i cant just change the bulbs on these ones because there cheap crap
The last post was made 14 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 39.48 Kb
