The Final Plan - Tomos Racer
SpannerMonkey
PostPosted: 18:48 - 30 Mar 2012    Post subject: The Final Plan - Tomos Racer Reply with quote
So I've been working on the Tomos for ages now... spent a grand on the project in total so far...
Now the reason it hasnt gone back together is because I've been ummming and ahhhing over whether I'd be satisfied with it when it's done...
And I decided No...
So I sat down one night, trying hard to figure out what I was after... and whether it was even possible. And my new plan is to stick to a 4.5k limit, and build a 70's style mini-racer, with modern technology...
Quite a few parts will be custom, and I'm even drawing up designs to mount a 70's full fairing to aid with top speed.
The aim is to push this engine to its absolute limits, and hopefully reach 80mph with neutral conditions, not a tailwind or downhill.
Realistically, I believe this is an attainable speed if everything is set up right...
So what I'm asking of you guys, is do you guys have any suggestions?
Current ideas/suggestions include:
Wider swing-arm to accommodate wider rim and rubber.
Front disc conversion
All round disc conversion
Custom expansion chamber
Digital re-programmable internal rotor ignition with dual curve switch.
Wet nitrous is OUT OF THE QUESTION.
Stroke +2mm Crank (Custom job)
Increase compression ratio further, use octane boosters.
Change clutch material/lighten clutch
Must be Naturally Aspirated
Dual expansion chambers (Same principal as twin turbo)
My bike? A YX140 powered one-off Monkey Bike, something a little different!
PostPosted: 18:54 - 30 Mar 2012    Post subject: Re: The Final Plan - Tomos Racer Reply with quote
I would have thought wider rubber would be adding weight and rolling resistance - what would be the estimated maximum speed for what you have?
SpannerMonkey
PostPosted: 19:16 - 30 Mar 2012    Post subject: Re: The Final Plan - Tomos Racer Reply with quote
Yes but I could do with the cornering confidence... am only running 16-2.25's front and rear... I've had 55mph gps out of them so far, so a real world 53?
SpannerMonkey
PostPosted: 19:45 - 30 Mar 2012    Post subject: Reply with quote
Last time I checked, X5... I can fuck about with my bike all I like... Dont like it? dont comment! lol
Wait, what's the matter? Always have to get your opinion across? Yeah, I noticed. Grow up.
Teflon-Mike
tl;dr
PostPosted: 19:49 - 30 Mar 2012    Post subject: Reply with quote
I think you ought to do it to a pre-restriction/pre 1977 moped, retaining frame & crank cases, 50cc max displacement AND pedals.
Otherwise you dont have a super-fast moped; you have yet another, ringer-dinger 50+cc motorcycle on a moped log-book.
Kreidler or early Derbi would be my influences, as in the 1960's/70's GP50's.
Black & silver Number-Plate. 'Round' bubble fairing. Honda MT125 perhaps?
SpannerMonkey
PostPosted: 19:50 - 30 Mar 2012    Post subject: Reply with quote
Sorry Tef, but I want to do it to the Tomos =P
It's a good idea, but I like the underdog status of the tomos Laughing
The Artist
PostPosted: 19:53 - 30 Mar 2012    Post subject: Reply with quote
Looks cool although as Shaggy said, you want skinny wheels if you want to reach a decent top speed. Skinnier the better.
SpannerMonkey
PostPosted: 19:56 - 30 Mar 2012    Post subject: Reply with quote
May stick with standard size rims and just invest in top-end rubber... if there's any available for my machine! lol
PostPosted: 20:09 - 30 Mar 2012    Post subject: Reply with quote
BLUEX5 wrote:
Alex, I know full well you are shitcanning me on facebook due to epic butthurt.
A grown man with a full licence fucking around with a peddle and pop.... just sad.
So you directly equate manliness to the how many cc's/horses your bike has?
Carvel
PostPosted: 20:20 - 30 Mar 2012    Post subject: Reply with quote
Four and a half thousand pounds....
just buy a mk1 fireblade ffs.
PostPosted: 20:25 - 30 Mar 2012    Post subject: Re: The Final Plan - Tomos Racer Reply with quote
Tomos Racer
What class limits?
Or is this just a case of a more time consuming way to chuck money away than sticking it in a blender?
DrDonnyBrago
PostPosted: 20:37 - 30 Mar 2012    Post subject: Re: The Final Plan - Tomos Racer Reply with quote
https://www.designbyfront.com/images/uploads/turd_polish_thumb.jpg
Teflon-Mike
tl;dr
PostPosted: 21:04 - 30 Mar 2012    Post subject: Reply with quote
Plenty of pre-77 pedal & pops that are just as deservant, of 'under-dog' status.
I'm with G.
Chuking silly amounts of money at an 80's Thomos, is perversion above & beyond, and DOESN'T even show much creativity.
Modern, post '77 moped laws nailed down speed; so fit a spannie & a big carb & you are into the realms of re-registration, or 'ringer' other than described on the registration'.
Boring out a two-stroke, to make it go faster is no great genius either...
Thomas '50' that is actually an 80, isn't really a '50' any more, and big mph numbers rather less impressive when compared to err... Yamaha RD80MX? Honda H100? RSX100? C90?
Reason I said a pre-77 pedal & pop, is that the regs that permitted the Fast-Fifties like the FS1E, AP50 & Italian loverlies like the Girelli, Minerelli etc, only imposed the 50cc and pedal-drive limitations.
Work within those, you have some defining boundires; ie keep it 'legal' as a moped, and that gives it some relevence and makes numbers you achieve impressive.
Thomos; much 'Fun' as it may be; with no boundries or limits, and simply chucking shed loads of dosh at it, to make it go fast?!
Yeah 80mph from an 80cc big bore... why not stuff a TZR125 engine in it, and go for the ton? Or a CR125 Scrambler-lump..... you could bend the frame around a Bandit 12 engine, with blower & nitreouse.....
Its ONLY a question of cash....
Set some tangible REASON for the project; give it some kind of relevence.
And if you are intend on a 'Madd-Ass-Moped'; then do something that can tangibly CLAIM to be a 'moped' by some accepted defantition. Modern one says 32mph & its no longer a moped. One from the 80's says more than 35, its not a moped, so HAS to be a pre-77 model.
But to stay within the regs of that defanition; buts also still stay 50cc and must have means of human propulsion via pedals.
The last post was made 14 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.71 - MySQL Queries: 16 - Page Size: 102.05 Kb
