Honda CG Won't Start
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
bikertomm
PostPosted: 15:20 - 13 Apr 2012    Post subject: Reply with quote
Did you try hitting it with hammer gently?
Also, following this thread with interest as mine sometimes does this.
P.
PostPosted: 15:25 - 13 Apr 2012    Post subject: Reply with quote
WTF, everyones starters are playing up Laughing
BikeNewbie
PostPosted: 15:27 - 13 Apr 2012    Post subject: Reply with quote
Yeah I gave it a few taps lightly, Still nothing.
P.
PostPosted: 15:33 - 13 Apr 2012    Post subject: Reply with quote
Well, If you can bump start and can get to Maidstone tomorrow, I'll be working on bike that day so feel free to stop in and I'll happily look Thumbs Up
BikeNewbie
PostPosted: 20:31 - 10 Jun 2012    Post subject: Reply with quote
Hello,
Well it has happened again.
It stopped doing after a few days and for about 2 months or so it was fine. Then it has started doing it again.
I don't want to keep having to bump start it everytime I use it.
So how do I clean inside the Starter Motor?
Thanks.
BikeNewbie
PostPosted: 16:48 - 11 Jun 2012    Post subject: Reply with quote
I have tried to get it working today, Basically it's clicking from the right side of the battery. I tightened the nuts up and a few sparks came of it.
So the battery is fine right? So it would have to be the solenoid? Or the starter motor?
Someone must know?
Usher4566
PostPosted: 18:01 - 11 Jun 2012    Post subject: Reply with quote
Solinoid mate .ark a screw driver across terminals of solinoid
New cd200 benly owner
BikeNewbie
PostPosted: 21:51 - 11 Jun 2012    Post subject: Reply with quote
Do what?
Usher4566
PostPosted: 18:38 - 12 Jun 2012    Post subject: Reply with quote
The starter solinoid has two terminals coming off top of it .place a screw driver across top of them so it makes a conection it will spark a bit .may free it up .or just replace .make sure igntion on by the way
Usher4566
PostPosted: 18:42 - 12 Jun 2012    Post subject: Reply with quote
If you bike won't start the first thing to check is the battery. Is it in good condition and fully charged ? See the Battery Page. If the battery tests good and the solenoid clicks at you, the solenoid might be corroded inside. To check, bypass the it. A real down and dirty way is to just connect the two big posts on the solenoid with a (OLD) screwdriver. There will be lots of sparks so have a good Fire Extinguisher handy. If nothing happens when you do this, the starter wires are broken or corroded, the starter is dead, or the starter is not grounded right. Try bypassing the everything. Hook a heavy jumper cable straight from the battery to the starter. If nothing happens, most likely the starters dead. You can also run a voltage drop test, to test the starter cables. See the Electrical tests page. If the starter works when you jumper the two terminals then you need a new solenoid. If the starter works and the solenoid does not click, the solenoid might be dead or it might be that the starter button is corroded and not making good ground or the wire going to the button may be broken. Sometimes there is a fuse in the starter system, be sure to check it. Also, on new bikes, big brother has now put in all kinds of "Safety" switches to protect us from ourselves. I don't particularly like them, however, I do have at least one rather vivid memory of trying to turn left with the side stand of my Norton down ! Anyway, check all those switches before you go and replace starters, solenoids, etc. They are usually on the clutch lever, side stand, and neutral switch. Older bikes don't have these "Helper" switches so their wiring is a bit simpler.
Usher4566
PostPosted: 18:43 - 12 Jun 2012    Post subject: Reply with quote
Cooties from dans motorcycle repair training site
There is a gap of 5 years, 314 days between these two posts...
geohammer
PostPosted: 19:04 - 21 Apr 2018    Post subject: Reply with quote
would be great to know if this ever got fixed, got a very similar issue
The last post was made 6 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 17 - Page Size: 75.05 Kb
