carb screws are buggerd.
Casper
PostPosted: 00:00 - 18 Apr 2012    Post subject: Reply with quote
Junior hacksaw and make them flat head screws. Dont go to deep as you run the risk of snapping part of the head of. You could also cut a cross and use a larger philips. Oh and go out and buy new screws. Get stainless allen head ones.
Casper
PostPosted: 00:03 - 18 Apr 2012    Post subject: Reply with quote
Only other option i can think of just now is cut away two sides so its flat and get mole grips on the head.
andym
PostPosted: 00:05 - 18 Apr 2012    Post subject: Reply with quote
if you have any needle nose mole grips you should be able to get them round the head and give them just that little bit of a twist.... I've used them on many a rounding screw and it works great
andym
PostPosted: 00:08 - 18 Apr 2012    Post subject: Reply with quote
Forgot to ask if they were still on the bike as I assumed they were off.
You might find you have to give it a couple of tries first though, and if the screws aren't too rounded then you should be able to use them again
bodger
PostPosted: 12:04 - 18 Apr 2012    Post subject: Reply with quote
Had the same problem on my XJ600n. The screws are as soft as putty. I got round it by using a small flat bladed screwdriver and tapped them round with a small hammer on the edge of the screwhead.(carefully).Got to use new screws afterwards obviously.
Pie-Roe
PostPosted: 12:57 - 18 Apr 2012    Post subject: Reply with quote
I got replacement screws and drain bolts when I did mine.
Had to dremel down a side part to get mole grips on number 2 and 3.
All the bits I needed cost about 21 quid.
Raffles
PostPosted: 14:45 - 18 Apr 2012    Post subject: Reply with quote
There should probably be a sticky for this as it is a very common problem. The heads are usually rounded off because people use the wrong type of screwdriver. The tool required is a J.I.S. screwdriver and they are not readily available in this country.
Anyway as for sorting the immediate problem, you will need to remove the carbs from the bike. Once they are on your workbench/floor you should be able to remove the chewed screws with a combination of a small set of mole grips and an ill-fitting Phillips type of screwdriver.
The proper screwdrivers for the job are available from the link below:-
https://www.probuild-uk.co.uk/jis-screwdriver-set?language=en¤cy=GBP
BTW Don't even consider putting the old screws back into the carbs.
Best of luck.
karthead
PostPosted: 12:23 - 20 Apr 2012    Post subject: Reply with quote
you can do this but it will ruin the screw (it doesnt really matter, like mentioned earlier, you would want to get new screws anyway)
With a flat head drill bit, put it in line with one of the crosses on the screws and hammer it on an angle (this will make an indent on the screw). After a couple of hits it will turn, and you should be able to get it out.
Raffles
PostPosted: 14:13 - 20 Apr 2012    Post subject: Reply with quote
Carbs are quite delicate and it's not a great idea to start laying into them with big hammers. The last time that I did so I took a chunk out of one of the carbs which I then had to bodge up with J B Kwik.
mickfulton
PostPosted: 20:59 - 20 Apr 2012    Post subject: Reply with quote
Had teh exact same prob today. 16 screws top and bottom all shit, rotten and painted on - never been loosened in 21 years. Used the hacksaw method with the carbs in a vice wrapped in foamy gear, found the biggest flat head socket wrench attachment and used plenty of wd40 and patience.
I say me, it was actually the missus who spent hours at it Embarassed It took a while and I would have just tried to drill it out, but she done it ( how luck am I Smile - a woman who can fix bikes )
Current half-cars :2004 SV650, VX535 1991
Exes: YBR 125 2007,GPZ500S 1998
Ingah
PostPosted: 00:37 - 21 Apr 2012    Post subject: Reply with quote
Is there a good reason no one's mentioned trying an impact driver?
-- Ingah
Raffles
PostPosted: 10:22 - 21 Apr 2012    Post subject: Reply with quote
''Carbs are quite delicate and it's not a great idea to start laying into them with big hammers. The last time that I did so I took a chunk out of one of the carbs which I then had to bodge up with J B Kwik''
karthead
PostPosted: 10:58 - 21 Apr 2012    Post subject: Reply with quote
I was talking about the screws, if he is careful enough he should be able to get the screws out, no harm done
The last post was made 13 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 16 - Page Size: 100.78 Kb
