"Welding" Plastic?
MyCarVsYourHe...
PostPosted: 21:26 - 27 Apr 2012    Post subject: "Welding" Plastic? Reply with quote
I've had some success in the past when "welding" small cracks in plastic fairings on bikes, I just wanted to know what techniques you lot use, I'm a minimalist so I just glue the broken pieces together, heat up a flat round butter knife and run it along the back side of the split which usually holds quit well.
Aff
PostPosted: 21:43 - 27 Apr 2012    Post subject: Reply with quote
I use a gas soldering iron with a knife tip, i make perpendicular cuts along the length of the crack/join to tack it. Then i make a cut down the length of the crack/join and then fill this by melting a bit of plastic over it filling the cut, this has worked pretty well for me and i haven't had a repair break yet.
On the outside i use the same technique and just sand it down and paint if afterwards.
Electric Bike Project
virus
PostPosted: 22:27 - 27 Apr 2012    Post subject: Reply with quote
Pretty much the same as aff, soldering iron and the bits ya trim off cableties, cause im all about the cabletie efficiency Embarassed Laughing
John
own: 81 xs1100g...
The Tot
PostPosted: 23:06 - 27 Apr 2012    Post subject: Reply with quote
Pretty much as the above.
Most plastic fairings are constructed from ABS, so I get lego bricks and use it as "weld filler" - I've got a dedicated soldering iron which I use solely on plastics mind.
For a belt and braces approach, I slap on 2 part epoxy resin on the inner surface, and reinforce it with gaffa tape
I broke a fairing hole/mounting lug. Welding alone wouldn't fix it because of the vibration experienced. Gaffa tape reinforcement = winning.
Never argue with autism
The last post was made 14 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 40.94 Kb
