| GILDZ |
 GILDZ Derestricted Danger
 Posted: 18:09 - 05 May 2012 Post subject: HELP! PLZ! Oil leak from carb UPDATE |
I have just brought a Piaggio Hexagon 180, 2 stroke scooter, was told when I purchased it (private sale) that the autolube leaked but wasn't a problem cus he just premixed. Rode it home and it runs OK, next day found some oil under bike, (which got me thinking how can the autolube leak if he didn't fill it up?) So noticed the oil was coming out a little hole (looks drilled) near the bottom of air box, take cover off and find a little oil in the bottom and on air filter, so take the air box off, and oil in the pipe that connects on the carb, so leaving everything off I put some kitchen roll under the carb (just checked the tissue and seems to have dripped a thinner liquid (petrol and oil?) still red in colour a smells of petrol (But it as come out the carb!!!) Obviously I am new to all this (I haven't had 2 wheels for nearly 20years) looking at the pipes I don't think there is any oil in the autolube feed to the carb and the tank should be premixed!! sorry for all the waffle, anyone got any ideas what I should do now, carb clean? any suggestions gratefully received, Thanks in advance, GILDZ. ____________________ PIAGGIO HEXAGON 180 2T.
I am a complete novice, Treat me as stupid! I won't take offence!!!!
| andym |
 andym World Chat Champion
| GILDZ |
| GILDZ |
| Usher4566 |
 Usher4566 Spanner Monkey
| karthead |
 karthead Trackday Trickster
 Posted: 08:48 - 07 May 2012 Post subject: |
The engine on my KE125 is auto lube. You see, there is a point behind most autolubes, which is why they are present on some 2 stroke engines. On mine, the oil goes through the main bearings and then into the crankcase where it mixes with fuel. If you run with premix, chances are you will need to rebuild the engine very often to replace bearings as they may not get the oil. I recommend (although others might disagree) that you reconnect the autolube and use it. Although it's more of a hassle, you'll probably be better off
Andre |
| Usher4566 |
| karthead |
| Usher4566 |
| karthead |
| Usher4566 |
| GILDZ |
| Usher4566 |
| karthead |
| GILDZ |
| karthead |
| GILDZ |
| karthead |
| GILDZ |
| karthead |
The last post was made 14 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
