How do you know if you valves need done?
Gazz
PostPosted: 12:30 - 24 May 2012    Post subject: How do you know if you valves need done? Reply with quote
Just wondering, for example; if you buy a second hand bike with no service history then you dont know when this will have been done on the bike, and it is quite expensive in terms of servicing goes.
So what are the symptoms are that this is needing done?
And also, what is done in the process?
hazza
PostPosted: 12:39 - 24 May 2012    Post subject: Reply with quote
Entirely dependant upon the bike. Some valves open up and become tappy when they need doing, some close up and get quieter when they need adjusting. Some are the shim type and others are the standard adjustable ones. If you have a bike with no service history, its probably best to asume that nothing has been done and do a full service inc valves. Its not that hard in all honesty. Get a Haynes and get your hands dirty!
Regards
Harry.
UrbanRacer
PostPosted: 12:41 - 24 May 2012    Post subject: Reply with quote
It sounds like a tambourine Laughing
Quote Me Happy
PostPosted: 12:56 - 24 May 2012    Post subject: Reply with quote
Measure them?
If it's the locknut type then it's really easy usually.
Walloper
PostPosted: 14:00 - 24 May 2012    Post subject: Reply with quote
In general, engine valve seats and valve faces wear as the engine is used.
Wear in the seats and valves allow the valve stems to be pulled further into the valve guides of the cylinder head.
This has the effect of making the valve clearance/gap less (or closer).
In extreme cases the effect of wear means the valve cannot fully close (due to the stem resting on the cam-follower/lever.
This will cause poor compression.
Poor compression leads to low power, torque and possible difficult starting.
The noise is not always easy to distinguish fro the other shit that goes on inside a motorcycle engine so usually it is best to do a check.
The check normally requires the tank and air-box to be removed which is a pain.
This is why it can cost a wee bit the have the valves checked/adjusted.
Some engine to add cost need to be checked and if adjustment is needed the camshafts have to come out. This can involve engine removal. This can mean mental costs.
Before you buy the bike find out about what it may cost to check and if required, rectify any defect.
If it's an older bike then it's likely there is no trade certs for service (if even that is worth the paper it's scribbled on).
If you are not certain walk, run or drive away.
You could maybe negotiate with the seller for a discount to cover the cost mind. And then everyone is happy.
Buying anything is never cut and dry. If you know anyone who knows about bikes then take them with you.
Use the Internet (bcf) to find out as much as you can about the machine you are interested in. DO not wait until you hand over the Shekels. Rolling Eyes
PostPosted: 15:02 - 24 May 2012    Post subject: Re: How do you know if you valves need done? Reply with quote
On a lot of bikes it's fairly easy to check them - but ones with shims it's a bit more hassle to actually change them if needing doing.
Usually very easy to do both if it's tappets.
EazyDuz
PostPosted: 15:52 - 24 May 2012    Post subject: Reply with quote
On what kind of bikes do the valves get tighter over use? I would have thought all would get looser over time due to wear.
Anyway, this is what a bike sounds like with loose tappets and/or loose chain tensioner (some bikes have an auto tensioner, others you do at service intervals)
https://www.youtube.com/watch?v=y-ojHNiHUsc
Basic way to know if its the tappets is to put your ear as close to the tappets as you can with the engine running.
DrDonnyBrago
PostPosted: 16:45 - 24 May 2012    Post subject: Re: How do you know if you valves need done? Reply with quote
I think when buying, it is fair to assume that ALL used bikes without service history are due a valve clearances check.
I think you have misunderstood the meaning of tight/loose valves.
flumpy7
PostPosted: 19:38 - 24 May 2012    Post subject: Re: How do you know if you valves need done? Reply with quote
Call me sceptical but I'd say its no less likely they need doing even if it has a service history. I do a valve clearance check and full service on all my bikes as soon as i get them. Thats the only way i know its been done Thumbs Up
Out of interest....can you give a few examples of bikes that need engine removal for valve clearances.....mental note to avoid!
2012 Sinnis apache
Walloper
PostPosted: 11:40 - 25 May 2012    Post subject: Re: How do you know if you valves need done? Reply with quote
It's not as clear cut as that.
For example, the Triumph Sprint ST I owned needed the engine removed to do the 'tappets' as there was no way to remove the camshafts in place. The earlier series engine for the same model bike could be done in-place using a spring compressing tool.
2006 on (maybe not exact) Honda VFRs were slated by the bike press as the engine required removal to adjust tappets.
Honda eventually came around to putting off this big job and relied on gap check or compression check.
My Triumph Sprint ST had about 17000 miles on and when I checked the 'tappets' there were all within OEM specification.
When valve clearance is specified there is normally a 'range'
i.e.
For a 955, the clearances should be:
Inlet 0.10mm - 0.15mm
Exhaust 0.15mm - 0.20mm
This is to give a acceptable usable life and it also allows for inaccuracy of the measurement.
I would not really worry about it too much as there are loads of bikes out there with MUCH worserererer things wrong with them than valve clearance.
Find all the bikes with known frame issues where the frames can crack at stress points. Smile
I bought my first BMW R1200GS from a non BMW franchise (A Honda bike dealer) I got it a a decent price and they sent it to the local BMW dealer for a switch repair and BMW service.
I noticed a problem with the ABS system where the ABS system warning light flashed and the servo motor continued to run on after the brake was released.
I had it in two BMW Motorrad shops for checks and they found nowt wrong.
Until about 1 year later when the brake warning light stayed on and the servo never switched off.
It turned out the Modulator valve was sticking and required replacement.
£1100 and £350 labour.
BMW would not help as the bike did not have a full service history. Although the cunts had took money off me to BMW service it twice and it had been brought back to fix this fault three or four times.
I could have argued the point but I managed to get a 2nd hand modulator for £400 and BMW fitted it for less than £200. (A goodwill gesture by the Grimsby dealer, not the Goose Stepping cnuts in Bavaria).
So you can buy a bike and get a pig in a poke just your luck.
But... Most modern bikes which are in good nick are basically reliable.
Generally, if an engine starts off the key from cold and doesn't need too much fettling then the internals should be sound.
Sorry for the Teffer-esque post. Embarassed
The last post was made 14 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 16 - Page Size: 71.83 Kb
