Honda CG 125 - rear sprocket/cush drive issue?
spr33
PostPosted: 21:03 - 09 Jun 2012    Post subject: Honda CG 125 - rear sprocket/cush drive issue? Reply with quote
Hi,
I have a '97 Honda CG 125 and I noticed on the way home from work that the bike was making a noise which I hadn't heard before.
What I believe has happened is that the rear sprocket has come loose because of the cush drives. Please see the video I took of it being loose: https://vimeo.com/43684190
Is this an easy fix? If so, how much roughly will this cost to fix (in £)?
Many thanks for any replies in advance.
kingsmith
PostPosted: 00:27 - 10 Jun 2012    Post subject: Reply with quote
https://www.wemoto.com/bikes/honda/cg_125_br-s_t/95-97/picture/cush_drive_rubber_-_individual/
cush drives Individual
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
Casper
PostPosted: 01:45 - 10 Jun 2012    Post subject: Reply with quote
Get it of for a proper look. Dont think that is your cush drive rubbers or whatever it uses. Looks more like sprocket carrier bearing. DIY job around 20 quid.
Nick_Giles
PostPosted: 03:50 - 10 Jun 2012    Post subject: Reply with quote
Ditto to the above.
If its just the bearing though I would say the price would be nearer £8 and that's with a new dust seal also.
However if you have ridden it much distance in that condition you may have butchered the cush also.
Nick.
bodger
PostPosted: 08:08 - 10 Jun 2012    Post subject: Reply with quote
Definitely looks to be the sprocket carrier bearing as suggested in previous posts.
Quite an easy fix and as Nick says wont cost more than a tenner from your local bearing factors to put right.
spr33
PostPosted: 08:22 - 10 Jun 2012    Post subject: Reply with quote
Thanks all for your replies.
I rode approximately 2 miles with it in this condition, maybe a bit more as I may not have heard the noise before.
neil.
PostPosted: 09:25 - 10 Jun 2012    Post subject: Reply with quote
Not only the bearing - looks like the studs have come away from the carrier as well because the sprocket is coming away by itself. Stripped threads in the carrier - new carrier time - https://www.ebay.co.uk/itm/HONDA-CG125-SPROCKET-CARRIER-REAR-/270855518837?pt=UK_Motorcycle_Parts&hash=item3f103f3a75#ht_501wt_936
spr33
PostPosted: 12:20 - 10 Jun 2012    Post subject: Reply with quote
I think you may be bang on the money there. I tried to tighten all of the nuts and two of them wouldn't tighten at all. I think I'd be able to replace that myself, however, if there is anything else that needs doing whilst replacing the carrier, I'd be a bit out of my depth.
Casper
PostPosted: 16:25 - 10 Jun 2012    Post subject: Reply with quote
You should be fine with the one linked. If it needs a new bearing all you are doing is taking out a retaining clip and banging the old one out. Fit new in reverse. Just remember what way round your wheel spacers came of for when you put it back togeather.
spr33
PostPosted: 18:30 - 10 Jun 2012    Post subject: Reply with quote
CHR15 wrote:
actually, looking at your video, your cg rear wheel is the same as mine. no sprocket carrier.
the cush drive rubbers press into the wheel, the nuts on the sprocket, bolt onto special bolts, threaded on one end, and plain shaft on the other end, these slide into the cush rubbers and the large circlip holds the sprocket tight against the wheel (laterally)
the reason why the nuts just seem to spin is because there's nothing holding the bolt / shaft to stop them spinning. to tighten them you have to be able to see the other side of the sprocket and get a spanner on the bolts.
Ah ha! I'm glad you pointed out that my CG doesn't have the sprocket carrier, it's the older version I have without one. It does seem like the clip is missing. I have a Haynes manual on it's way to me. I'm guessing that I need to open the drum up to see the other side of where the bolts are?
Thanks very much for your reply, very helpful Smile
spr33
PostPosted: 20:42 - 10 Jun 2012    Post subject: Reply with quote
CHR15 wrote:
no, all you need to do is remove the rear wheel.
the sprocket and the pins that are bolted to the sprocket will come out as one unit. you tighten them up, then slide the sprocket / pin assembly onto the wheel. the pins locate into the cush drive rubbers, and the sprocket locates onto a circular boss which sticks out the side of the wheel.
you then drop a shim onto the top of the sprocket and clip the circlip onto the wheel which holds the whole lot together.
That sounds quite simple. I'm struggling to find the circlip needed though. Would this one be suffice or do I need a bigger one? https://item.mobileweb.ebay.co.uk/viewitem?itemId=160801475737
Casper
PostPosted: 20:51 - 10 Jun 2012    Post subject: Reply with quote
well, if you type 'cg sprocket circlip' into ebay... Wink
https://www.ebay.co.uk/itm/HONDA-CG-125-CG125-LARGE-CIRCLIP-CIR-CLIP-TO-RETAIN-REAR-SPROCKET-ONTO-WHEEL-/300720759531?pt=UK_Motorcycle_Parts&hash=item46045aa2eb
Or
https://www.wemoto.com/bikes/honda/cg_125_br-s_t/95-97/picture/sprocket_rear_-_retaining_c-clip/
The last post was made 14 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 78.57 Kb
