CBR125 speedo all over the place
dave_bole
PostPosted: 19:22 - 11 Jun 2012    Post subject: CBR125 speedo all over the place Reply with quote
I finally got the 2004 CBR125 working but have one finally small problem...
When accelerating, the speedo jumps about all over the place until i let off the throttle and it levels out to the correct speed.
Any ideas on a first port of call?
Moxey
PostPosted: 20:45 - 11 Jun 2012    Post subject: Reply with quote
2004 CBR has analogue speedo with cable doesn't it?
Check the cable isn't snagging and is freely moving first, if all seems ok from that end I would suspect the needle bearing may have gone up at the clock, watchmakers of some sort may be able to repair that for you (Timpsons or similar).
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 07:26 - 12 Jun 2012    Post subject: Reply with quote
The speedo mech on the front wheel hasn't been put on properly. Thumbs Up
CaNsA
PostPosted: 07:48 - 12 Jun 2012    Post subject: Reply with quote
i had this on my 1st zxr400, i was doing 30mph then 140mph then 10mph, then 90mph all in the space of 3 seconds...... turned out the speedo cable was fuxord.
dave_bole
PostPosted: 11:59 - 12 Jun 2012    Post subject: Reply with quote
i have ordered a new speedo cable.
Already ruled out the battery as i have just bought a new one.
Ill let you know how it goes on the weekend when i get a chance to have a look at it
PostPosted: 15:05 - 12 Jun 2012    Post subject: Reply with quote
Did you check current one?
Also have you removed the front wheel to check your actual speedo drive is ok?
CarlosCBR
PostPosted: 16:30 - 12 Jun 2012    Post subject: Reply with quote
Definitely the speedo cable. They dry out inside the sheath and eventually snap, common fault, make sure you lube the new one before you install it.
Can be a pain in the arse getting the cable out of the drive so be gentle or you risk snapping the bit off the back of the speedo drive.
The last post was made 14 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.48 - MySQL Queries: 16 - Page Size: 56.76 Kb
