 waynee L Plate Warrior
 map Mr Calendar
 Posted: 12:35 - 19 Jun 2012 Post subject: |
If you read this from the Kawasaki GT club the current draw is 4.2 mA to about 0.28 mA. Could the sensor be shorting so when removed it all works?
From the same site you can remove the sensor and connect the wire via a 50K resistor direct to the +ve terminal for a current draw of 0.18mA.
Is the sensor ok. I know on mine the cable just disintegrated and became brittle over time. You can get replacements here or here.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
