dt125r jetting
madcookie38
PostPosted: 16:00 - 19 Jun 2012    Post subject: dt125r jetting Reply with quote
Hi Guys just wonderd if anyone could tell me what affect over jetting could have on my dt125r, Because i took the carb off as had trouble getting the bike to run well at low revs an not much low down power, And found the jets had been changed, I found out the standed jet should be a 210 but my bike has a 220 init would this cause it to flood at low revs, Ive done a lot of work on the bike ie new crank seals fixed power valve etc but just find the bike wants to die at low revs its seams ok when you thash it but cause i use it for green lanning i want power all the way up the revs not just in the power band. Its got a standed air fitter and snockle, the power valve is set as it should be and the ring has been removed from the exhaust, Has anyone got any thoughts on this matter or is it poss its something else making it not run well ?,
Any help or ideas would be great
The last post was made 13 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 16 - Page Size: 28.95 Kb
