Tricky Theory Questions
Alpha-9
PostPosted: 10:29 - 25 Jun 2012    Post subject: Tricky Theory Questions Reply with quote
I've booked my theory for next month, wahay
I've done a few practice tests now and only passed one Embarassed
I go through them thinking pft this is easy with only a couple of questions catching me out, then it turns out I got 40/50! Fail!
Some questions that trick me out are
Number chest compressions to give someone injured?!
Stopping distances
The weird, approaching an unmarked junction honk your horn, noone has right of way thing
Any other questions that trick you out? What are the right answers?
Just trying to cover my bases, figure most of you guys have done the theory so know what weird questions come up.
Also how long is theory valid for to do the tests again?
Fzr-600 1999
multijoy
PostPosted: 10:37 - 25 Jun 2012    Post subject: Reply with quote
Beg, borrow or steal the DVD/online test access, and just keep doing the tests 3 or 4 times a day until it's drummed into you.
I believe a pass is valid for two years?
esullivan
PostPosted: 10:46 - 25 Jun 2012    Post subject: Reply with quote
I found it most helpful to get the book. I think it's called the "Official DSA Theory Test". You can get it in any bookshop or on amazon. Every question is here, followed by every answer. It's very boring, but I read through it cover-to-cover and got a perfect score on the multiple choice part.
And the usual multiple-choice strategy applies: If you encounter an unfamiliar question, you can usually eliminate at least half of the answers and get it down to 50/50.
For the stopping distance, I just memorized them. I wasn't asked during the test and have now forgotten them. In practice, the correct answer to "what distance will it take to stop from this speed" is "twice as far as you think."
EDIT: The theory pass lasts two years. When you pass your mod1, that expires whenever your theory does.
mjn51
PostPosted: 10:48 - 25 Jun 2012    Post subject: Reply with quote
pratice ....
https://www.aa-driving.co.uk/test1.html
Andy_Pagin
PostPosted: 10:55 - 25 Jun 2012    Post subject: Reply with quote
Practice till you get 50/50 every time & 90% on HPT.
Then when you do it for real you'll walk in there knowing you cannot fail.
Alpha-9
PostPosted: 11:11 - 25 Jun 2012    Post subject: Reply with quote
mjn51 wrote:
Hurr, motorway questions
I know hardly any of these, i'm rubbish!
That one was worse than ever!
You have made 16 errors.
Total score: 36.
Results
06/25/112 11:10
Mock Theory Test
You have made the following errors
Question 2
The right answer was Risk of grounding.
Question 6
The checkbox When you use your vehicle abroad shouldn't have been selected.
Question 6
The checkbox When you change your name should have been selected.
Question 12
The right answer was The steering.
Question 13
The right answer was Green.
Question 14
The right answer was switch on your hazard lights.
Question 17
The checkbox Reapply for your provisional licence should have been selected.
Question 18
The right answer was 10 metres.
Question 19
The right answer was 60 mph.
Question 23
The right answer was 73 metres.
Question 28
The right answer was All round.
Question 34
The right answer was 1/2 second.
Question 40
The right answer was Alone.
Question 41
The right answer was Octagonal.
Question 42
The checkbox White zig-zag lines should have been selected.
Question 42
The checkbox Flashing yellow beacons shouldn't have been selected.
That was boohickey! Is that aimed at car drivers? Considering it asked when shouldn't you use a vehicle on a provisional and I put with passenger son the back and got WRONG, WHEN YOURE ALONE! Wat?
Time to install the 10gb of practice material
Fzr-600 1999
dungbug
PostPosted: 11:20 - 25 Jun 2012    Post subject: Reply with quote
I used this as my practice for the theory test questions;
https://www.all4bikers.com/theory/
some of the questions included were in the test on the day too. Thumbs Up
Chest compressions are 100 per minute, the question about cooling a burn is 10 minutes (minimum) so remember 100 & 10 for those. As for the braking, just keep going over the distances, it's the only way it'll sink in I found.
I used this link for the HPT;
https://www.driving-test-success.com/hazard/hazard_perception_main.html
It'll give you an idea of when to click & get you 'into' what's required.
I used the highway code for the braking stuff, what colour studs are where on a dual carriageway as those seemed to come up often...........aceept the actual test where there wasn't one bloody question on what I'd been revising. Laughing
Keep at it chap, I used to use these links when I had a spare moment in the evenings/at work. It does help to keep trying them. Best of luck for next month. Thumbs Up
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
mjn51
PostPosted: 11:31 - 25 Jun 2012    Post subject: Reply with quote
try the M/c tests here also
https://www.direct.gov.uk/en/diol1/doitonline/dg_4017669
Alpha-9
PostPosted: 11:35 - 25 Jun 2012    Post subject: Reply with quote
Grr 41!
I like that site, it's a good one
Damn i'm rubbish at this Razz
Thanks for the helpful links guys
Any more tips? Karma Thumbs Up
Fzr-600 1999
dungbug
PostPosted: 11:38 - 25 Jun 2012    Post subject: Reply with quote
Grr 41!
Keep at it, it'll happen for ya! If you can borrow the theory test book then it'll only help, you might be able to find the DVD on Fleabay which might also help. I was worried about the HPT but it's not that bad, just try & practice the mock tests often. There was another site which had mock HPT's but I can't find the bloody thing at the mo......Will keep looking & post it here when I do. Thumbs Up
JP7
PostPosted: 12:04 - 25 Jun 2012    Post subject: Reply with quote
You've just exposed a big problem with the theory test, which is what that Bennetts Biker Petition thing was all about, having more questions about bikes.
The theory test is car based. If you drive a car on a provisional then you need to be supervised by someone over 21 who has held their licence over 3 years, and have L-plates on the vehicle. On a motorcycle, you are NOT allowed to carry any passengers.
You have to assume that the questions will be car based and ignore the fact you are going for a motorcycle test.
Some of the things you will need to know in particular are speed limits, stopping distances and road signs. Most of the other things are common sense, read each question really carefully and decide which of the answers are "Definitely not", which are "Maybe", and which are "Correct". You also need to be careful of how many answers you need to give. If the question wants you to give three answers, and you only give one, you will throw away points.
Hope that helps!
Shinigami
PostPosted: 12:08 - 25 Jun 2012    Post subject: Reply with quote
I used a book called 'learn to ride' it was pretty good for prep for theory and for extra practical advice too.
Andy_Pagin
PostPosted: 12:31 - 25 Jun 2012    Post subject: Reply with quote
First time I did the all4bikers theory practice I got about 26/50, and that's with 28 years driving experience and I consider myself a reasonably competent driver! I re-did it literally dozens of times to get a decent score, so keep at it.
dan_flash
PostPosted: 12:41 - 25 Jun 2012    Post subject: Reply with quote
+1 for the DSA Theory book, got me tuned up quite well (first time pass).
Brother - if you want the book, just wire me a few bob for postage and I'll fly it over to you tomorrow.
It can be like a pay-it-forward thing. Once you're done, send it to another BCFer. And so the cycle can continue Smile Thumbs Up
Yamaha XJ600S, Volvo v40.
carb0n
PostPosted: 12:55 - 25 Jun 2012    Post subject: Reply with quote
keep going. you might get 42 soon Wink
The last post was made 14 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 16 - Page Size: 95.97 Kb
