| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:42 - 04 Jul 2012 Post subject: What oil for my NC27? |
Hi, I think I've got a problem, I've got '91 CB1 NC27 and I filled the engine like 1400miles ago with Belray 10W40 oil. The thing is, that I've put in 3 liters of oil, the dipstick shown its level on the to top line, slightely below, and now it's like 3mm above the bottom line.
Would my honda work with 20W50 oil? I used to use 20W50 in my GPz550 and if I compare it with 10W40 in GPz550, less oil disappeared.
Thanks for your help.
btw. the final drive ratio is changed to 15/44 and I do get over 14 000rpm once in a while. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 13:46 - 04 Jul 2012 Post subject: |
You can try it and see. Does it belch blue smoke? The oil must be going somewhere. ____________________ My Flickr |
| Robby |
 Robby Dirty Old Man
| RhynoCZ |
 Posted: 18:49 - 04 Jul 2012 Post subject: |
I thought that honda wasn't really an oil burner, a friend of mine had 2 Honda bikes, CB500, CBR900RR and he never had to add oil during the season.
When I filled up the engine, I've put new filter there of course, I just went for a ride and I checked the oil level after like 100+ miles.
I checked the oil level while the bike was standing like two weeks, so it was cold and I assume that all fluids in the engine were at the bottom of it. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| temeluchus |
 Posted: 19:30 - 04 Jul 2012 Post subject: |
That's not heavy oil consumption.
If you rev it to the redline a lot it will use more oil
You can find 10w50 if you look around. ____________________ Some shite cruiser. Now with guns and FREEDOM! |
| prawny1 |
 prawny1 World Chat Champion
| JvG |
 JvG L Plate Warrior
| RhynoCZ |
 Posted: 09:22 - 05 Jul 2012 Post subject: |
I'm bit confused now, some say it's alright and some say it is not.
Check this page from the manual: https://s970.photobucket.com/albums/ae184/RhynoCZ/?action=view¤t=mazn.jpg&newest=1
I can only read first two numbers in the graph. These two say, SAE 20W50 and SAE 20W40.
GPz550 with 10W40 oil in it, needed 3.5 liters of oil per season, I filled the engine up with 3.0 L I think and then when it burner down to the bottom line of the scale (glass), I added a bit to keep it arround the center of the scale. When it was hot, I mean 30+°C the oil also leaked from the engine, not like there was a puddle under it, the oil just covered the engine because of the heat. I did 3125 miles (5000km) every season, then changed the oil. Second season I used 20W50, the same procedure, and again 3125miles with it, and not only it burned less, the engine was ''more dry'', I mean no leaks arround the gaskets. After 20W50 season, I sold the bike, so I gave the rest of the oil to the buyer, but there was no need to add some. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| temeluchus |
| Vincent |
 Vincent Banned
| temeluchus |
| RhynoCZ |
 Posted: 05:51 - 06 Jul 2012 Post subject: |
| Temeluchus wrote: | | RhynoCZ wrote: | I'm bit confused now, some say it's alright and some say it is not.
The bike is what, 20+ years old? How many miles has it covered? There is bound to be some wear in the engine and a few lightly perished seals, so some oil consumption is to be expected.
According to the manual 20w50 is ok provided where you are is between the relevant temperatures. |
Thank you for the graph. I don't know how many miles it did, the clock says less than 30 000, I think. I've got a rider on sunday, so I'm gonna tell you then.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| RhynoCZ |
 Posted: 05:55 - 06 Jul 2012 Post subject: |
| Vincent wrote: | Are you using the dip stick properly? Do you screw it in or measure it without screwing it in?
Mine doesn't burn any oil either. |
I screw it out, clean it, screw it back in, get the motorcycle upright, then screw it out and check the level. I actually hate this system, I used to have a glass on my former GPz, oil level checked in a sec with no need to do something. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| RhynoCZ |
 Posted: 06:03 - 06 Jul 2012 Post subject: |
| Temeluchus wrote: | Means nothing.
I have owned two xj600 diversions. One drank a little oil, the other didnt. Usually means a little wear in the bores or a seal somewhere is perished, so a little is burned in the cylinder(s).
As long as it isnt belching smoke all the time i wouldnt worry. |
It doesn't smoke at all, I think it would be as you said, I went on the bike up to 14k like all the time (14k - 6th gear 190km/h), I'm gonna change the gear ratio to its default setting and then, I think, it would be more ''economic''. I has enormous fuel consuption right now because of the revs.
When I travell somewhere, I rev it below 10k rpm and it saves me slightly more then liter of fuel. 10k - 6th gear 130km/h. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| prawny1 |
| RhynoCZ |
 Posted: 08:23 - 06 Jul 2012 Post subject: |
| prawny1 wrote: | with the altered gearing the speedo will be nowhere near accurate by the way.
with standard dials 15f 37r is meant to give reliable speedo readings, this is because the speedo is driven off the front sprockt not the wheels.
as mensioned before 20-50 gave me a smoky start up, if you can get it 10-50 might help ,i also used 5-30 fully synthetic before gearchanges improved bit transmission/engine sound was increased so i went back to 10-40 semi synth,
i buy silkolene 10-40 workshop oil in 20l tubs so it lasts me a while depending on how many bikes i do. |
The speed I've mentioned was measured by second motorcycle, I know the actuall speed according to rev counter, I know it goes 50km/h at 3900rpm and so on. I know the speedo is inaccurate, it show approx. 6km/h+. With 15/37 it goes only 170km/h, right? With 15/41 ratio it still gets to the top: 190km/h. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Vincent |
 Vincent Banned
 Posted: 08:38 - 06 Jul 2012 Post subject: |
| RhynoCZ wrote: | | Vincent wrote: | Are you using the dip stick properly? Do you screw it in or measure it without screwing it in?
I screw it out, clean it, screw it back in, get the motorcycle upright, then screw it out and check the level. I actually hate this system, I used to have a glass on my former GPz, oil level checked in a sec with no need to do something. |
That's where you're going wrong. You're not burning oil, you're putting too much in and it's being ejected via the breather. Stick the bike on the main stand, unscrew the dipstick, clean it then just let it rest on the threads - don't screw it in. Remove and read. When you change the oil, stick the correct amount in which, IIRC, is 3.1L. It might be worth checking the bottom of the airbox for oil puddles.#
BTW; if the bike is fited with the small auxiliary air box behind the main one, check the filter element, it decomposes, turns to dust and can end up blocking the carbs and/or airbox. ____________________ Space Is Deep |
| RhynoCZ |
 Posted: 09:37 - 06 Jul 2012 Post subject: |
| Vincent wrote: | That's where you're going wrong. You're not burning oil, you're putting too much in and it's being ejected via the breather. Stick the bike on the main stand, unscrew the dipstick, clean it then just let it rest on the threads - don't screw it in. Remove and read. When you change the oil, stick the correct amount in which, IIRC, is 3.1L. It might be worth checking the bottom of the airbox for oil puddles.#
BTW; if the bike is fited with the small auxiliary air box behind the main one, check the filter element, it decomposes, turns to dust and can end up blocking the carbs and/or airbox. |
Alright then, I'm gonna measure the oil level as you say, but still, I had 3 liters of oil, which means there's no more then 3 liters in the engine. I'm gonna check the airbox anyway. I was about to check the air filter since I've got time and money. I'm gonna tell you more after I check this. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Vincent |
 Vincent Banned
 Posted: 09:51 - 06 Jul 2012 Post subject: |
If you havn't already, get yourself on here too, it's not the busiest of forums as there's not that many of these bikes around but most info is on there:-
www.hondacb1.org/forum/index.php ____________________ Space Is Deep |
| RhynoCZ |
| prawny1 |
 Posted: 17:47 - 07 Jul 2012 Post subject: |
| Vincent wrote: |
Vincent checking the oil level by screwing the dipstick all the way in the way the op does would actualy lead to a lower oil level than resting the dipstick against the thread, so your actualy recommending the op adds more oil than he normaly does.
I personaly just rest the dipstick against the threads too tbh and have never had an issue with oil in the airbox.
I have gotten used to just looking at the level through the dipstick hole on my cb-1, just to the rear of the hole you can see a sort of round casting when the oil is at the right level this casting is just a few mm higher than the oil level.
I have seen bikes where people have topped up the oil with the bike on the side stand (ala harley davidson style) and they do suffer from oiling airboxes and some have evan had the gear shaft and sprocket seals pop out due to excess crankcase pressure. ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them. |
| RhynoCZ |
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
