So i got a quote from Maxton.... *Arrived*
CaNsA
PostPosted: 20:02 - 28 Aug 2012    Post subject: So i got a quote from Maxton.... *Arrived* Reply with quote
KAWASAKI ZXR400 L
FRONT
The forks look externally very similar to the 750, but internally there is quite a lot of difference - it is
a much cheaper fork inside. The forks have too much compression damping causing the bike to feel
harsh over small bumps. The forks also do not have enough rebound damping, causing them to
return very quickly when you let go of the brake. The springs inside the forks are too soft for the
average rider weight, which makes the forks dive and bottom out under braking. One of the big
problems with the ZXR400 forks is that the oil is metered at the top of the fork. Because of this, the
only way to cure this problem is to replace the cartridges. The Maxton replacement cartridges are
adjustable for preload and rebound and are sprung and valved to suit the riders weight, we have to
modify the original fork tops to take the new cartridges and damping adjusters. The cost of the
conversion is £330.00 plus VAT plus seals which cost £25.00 plus VAT. To service the forks and install
the cartridges costs an extra £110.00 plus V.A.T. Bushes if you need them cost £13.00 + V.A.T each.
REAR
The rear shock is far too hard, we fit a softer spring, but the major problem is the damping which is
too hard. The shock needs reshiming. Cost of reshiming and respringing is £180.00 plus VAT. Some
people fit a different rocker to try and improve it, but although this marginally improves it, it does
not cure the problem.
We also supply different types of Maxton unit.. The non remote unit costs £415.00 plus V.A.T but we
also make a piggy back remote reservoir unit that has a second compression adjuster and ride height
adjustment which costs £570.00 plus V.A.T.
How does that sound?
Fisty
PostPosted: 20:04 - 28 Aug 2012    Post subject: Reply with quote
If you can afford it, do it.
Fatter and faster than Fret
nisp
PostPosted: 20:48 - 28 Aug 2012    Post subject: Reply with quote
sounds like somone is trying to sound clever and make you buystuff.
take this for example:
The forks have too much compression damping causing the bike to feel harsh over small bumps.
The springs inside the forks are too soft for the average rider weight, which makes the forks dive and bottom out under braking.
dive and bottom out under braking while having too much compression damping.
it may just be me (and the way I read stuff) but I think there taking you for a ride.
buy some new progressive springs (progressive suspentonmight mak them), new fork oil (manufacturer weight)
if your inclined, buy a new rear spring/damper while your at it,
and you might just save some dosh
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
CaNsA
PostPosted: 21:07 - 28 Aug 2012    Post subject: Reply with quote
Im not gonna sell the zxr, im gonna throw money at it instead.
I am in the market for a race shock so i started looking around.
Either nitron rear/hagon prog front springs or maxton f&r.
The lump is sweet at the mo, but i am looking for a decent one i can drop off at my mechanics gaff for him to rebuild.
D O G
PostPosted: 21:53 - 28 Aug 2012    Post subject: Reply with quote
Get Racetech components, fit yourself, save cash, feel better.
PostPosted: 21:54 - 28 Aug 2012    Post subject: Reply with quote
Seems to make sense?
Compression damping too stiff to compensate for too squidgy forks.
So harsh ride from the damping, while will slow them down, but they'll still complete the same amount of dive, just over a bit longer time?
CaNsA
PostPosted: 22:10 - 28 Aug 2012    Post subject: Reply with quote
Nothing for a zxr400.... Sad
Old Git Racing
PostPosted: 13:43 - 29 Aug 2012    Post subject: Reply with quote
Everyone I know who has had dealings with Maxton, race or road have been happy. You get what you pay for i.e. high quality kit tailored to you from a company that have lots of experience. After sales back up is good too, they answer e mails, give advice etc.
OGR
PostPosted: 14:03 - 29 Aug 2012    Post subject: Reply with quote
I was VERY Happy with the work done by MCT. Thumbs Up
https://www.mctsuspension.com/
Joncrete Cungle
PostPosted: 14:08 - 29 Aug 2012    Post subject: Reply with quote
You get what you pay for with suspension work. If you can afford it or a similar quality improvement to your 400 go for it. Improving the suspension on my NC30 made a good handling bike even better. Cool
McJamweasel
BCF Junkie
PostPosted: 17:22 - 29 Aug 2012    Post subject: Reply with quote
I've got a couple of customers who have had Maxton work on thier Tiger 800's, one had front & read and the other just front for now but he is going back for the rear. Both are very very impressed and have said that their bikes are transformed.
thomp1983
PostPosted: 17:48 - 29 Aug 2012    Post subject: Reply with quote
have you asked cargo for his opinion on what setup's he runs?
chris
CaNsA
PostPosted: 23:24 - 29 Aug 2012    Post subject: Reply with quote
Of course Very Happy
CaNsA
PostPosted: 09:01 - 30 Aug 2012    Post subject: Reply with quote
I've just won £700.
Nitron vs Maxton.
hmmmmmzzz
thomp1983
PostPosted: 15:33 - 30 Aug 2012    Post subject: Reply with quote
and what did the oracle he is suggest? i assume you've already altered your current setup to suit your weight?
chris
CaNsA
PostPosted: 17:48 - 30 Aug 2012    Post subject: Reply with quote
Cant get the zx6r shock to work for me, and the brass screw on the remote resevoir is seized Sad
All will be reet in a couple of weeks.
NTR Race Shock 3-Way <<< Ordered Very Happy
https://www.nitron.co.uk/shop/product/1547/kawasaki-zxr400l1-9-ntr-race-shock-3-way
NTR Race (Hose)
Embraced by high-profile racers, the NTR Race shocks elevated performance is supported through precise control of its 3-way independent damping. Made for the most demanding riders, intimate feedback is transmitted from the rear wheel and allows the limits of traction to be confidently explored. The wealth of adjustment, formidable features and value are combined in a modern design to compliment any high spec machine.
// 3-way independent damping control
// 40mm damper piston
// 14mm piston rod
// Adjustable spring preload
// Independent adjustable ride height
// Hydraulic preload option
// Remote or piggyback canister
// 24 click rebound adjustment
// 16 click high speed compression adj.
// 26 click low speed compression adj.
// Complete with Nitron spring
This shock has a remote reservoir that is mounted by a 360deg swivelling hose onto the main shock body and reservoir canister.
The shock features spring preload as well as shock length adjustment. It comes preset for damping and preload and includes the bearing end spacers and preload c-spanner.
thomp1983
PostPosted: 18:25 - 30 Aug 2012    Post subject: Reply with quote
you doin much with the '6 shock and how seized is the screw have you butchered it trying to remove it?
at that amount of money for a shock i hope you already weigh as much as a streak of piss as weight loss would be far cheaper and have the same benefit
chris
CaNsA
PostPosted: 18:38 - 30 Aug 2012    Post subject: Reply with quote
full kit rider weight.....
12.5 stone.
I aint butchered the screw, it started to fuck up so i left it alone.
thomp1983
PostPosted: 20:40 - 30 Aug 2012    Post subject: Reply with quote
want some beer tokens for it? give me something to play with over the winter
chris
CaNsA
PostPosted: 21:07 - 30 Aug 2012    Post subject: Reply with quote
tenner (what i paid for it) and postage or collect Very Happy
thomp1983
PostPosted: 21:35 - 30 Aug 2012    Post subject: Reply with quote
get me a postage cost to derbyshire, im not venturing to that side of the peak district i like my parts on my bike Laughing
chris
CaNsA
PostPosted: 21:43 - 30 Aug 2012    Post subject: Reply with quote
Cat n Fiddle meet is on the cards I reckon.
Give me a chance to test the new one when its fitted.
thomp1983
PostPosted: 21:52 - 30 Aug 2012    Post subject: Reply with quote
sounds like a plan that there does, let me know a date when your sorted
chris
The last post was made 14 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 16 - Page Size: 131.88 Kb
