Servicing yourself
Tomzo47
PostPosted: 19:55 - 18 Sep 2012    Post subject: Servicing yourself Reply with quote
Hi guys, I'm doing an oil change and general check over/clean of my bike tomorrow, as I'm not paying somebody in a garage over £100 to do it for me. I've done basic stuff on my bike but on a service what really needs checking/cleaning or possibly replacing?
Thanks
Ybr 125 > Bandit 650SA > GSXR 600 > Triumph Sprint St1050 > CB1300 > Z1000SX + FJ1200 (written off) > VFR750 >FJ1200
Nope.
PostPosted: 20:02 - 18 Sep 2012    Post subject: Reply with quote
Drop oil, change filter, replace sump plug and refill oil. (when I say replace I mean put it back, not actually replace it)
Check chain tention, chain and sprocket wear etc. and lube chain.
Check tyre wear and pressures etc.
Check brake pad levels, check brake discs for scoring and thickness. Check brake fluid levels and if its been over two years since it was last changed then change the brake fluid.
Check the fork seals aren't leaking.
Clean/Replace the air filter.
Lube any cables that are getting tight.
Check battery levels if its a refillable battery.
Check coolant level. If its more then two years old then change it.
Change spark plugs.
Maybe do valve clearances depending on mileage specified in the owners manual.
PostPosted: 00:07 - 19 Sep 2012    Post subject: Re: Servicing yourself Reply with quote
Hairy Tom wrote:
Servicing yourself
Fnar, Fnar.
Robby
Dirty Old Man
PostPosted: 06:45 - 19 Sep 2012    Post subject: Reply with quote
Get a Haynes manual, it takes you through everything you should do.
Make sure you have all of the parts and tools required before getting to work, particularly if your bike is your only means of transport.
Don't expect a massive saving the first time round - you'll need to buy the Haynes, you may need to buy some tools.
Don't get too far outside your comfort zone. Change oil and filters is very easy. Spark plugs can be more tricky on some bikes, due to the amount you need to strip before you can get near them (my old CBR600 was a pain in the arse for this). Valve clearances on an inline-4 is nearly always a ballache, particularly if they use shims for adjustment. The usual thing in this case is to spend ages doing them, when they didn't need adjustment anyway, and break something in the process.
A local BCFer will come over and give you a hand, far too many of us do this as a hobby and have nothing of our own to fix at the moment. Change the title of the thread to "help wanted" with your location and someone will come over at the weekend.
Allow some time as well. If you start on a sunday afternoon and need the bike to go to work on monday morning, something will go wrong. If you start on saturday morning, you'll finish by lunch and can spend the rest of the day cleaning your bike and drinking beer.
Final protip - order all of the parts from one place. The saving from shopping around is minimal, particularly after postage. Much easier to wait for one big box to arrive than lots of little ones. Don't worry about ordering more than you need - if you order some brake pads, and on closer inspection you don't need them yet, you'll have them on the shelf to fit in a few months when you do need them.
Tomzo47
PostPosted: 18:45 - 19 Sep 2012    Post subject: Reply with quote
Thanks guys, haven't started yet as had to work later than planned (gotta pay the bills somehow) and its too late to start now as I have work in the morning. I'll look into getting a Haynes manual, theres a halfrauds near me so will check out there (and ebay if i can't bring myself to pay their extortionate prices ) My girlfriends dad has offered to give me a hand this time, but will bear that in mind in future thanks Thumbs Up
PostPosted: 18:48 - 19 Sep 2012    Post subject: Reply with quote
Hairy Tom wrote:
My girlfriends dad has offered to give me a hand this time.
Yurk, yurk.
bikenut
PostPosted: 13:16 - 20 Sep 2012    Post subject: Reply with quote
:D fork oil, see cmnsl for the exploded views etc...... some pics wouil;d be good. :D
The last post was made 14 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 16 - Page Size: 62.96 Kb
