gsxr 600 1998 flooding engine
choonsy
PostPosted: 19:40 - 30 Sep 2012    Post subject: gsxr 600 1998 flooding engine Reply with quote
i have a flooding problem it was worse , stalling the engine and when i did get it going it was flaming out of the exhaust.
i noticed the choke was very very stiff and was jammed on so ive freed that up and is better.
i rode it to work today and its still flooding, not as bad but it is a problem still. Any hints/tips would be great from you guys.
i did noticed that when i turn the choke off i can still push the choke plunger/bar/brass bar into the carb a little with my finger, should it be going all the way in via the lever and fuel is getting past?? i have used the adjusters on choke cable and idle speed has been tinkered with but no use at all.
thanks in advance for all your help
Casper
PostPosted: 20:01 - 30 Sep 2012    Post subject: Reply with quote
Pull choke out and well grease the bar. You cable may be badly adjusted also. Fuel/air mixer screw could be wrong setting. Has the bike been like this a while?
choonsy
PostPosted: 20:10 - 30 Sep 2012    Post subject: Reply with quote
no mate, it happened the other night all of a sudden. i have freed it up but im tempted to take the bar off and give it a really good rub down when i get time. would you know if there is a spring that pulls the plunger bar into the carbs once the cable is not pulling on the bar?
Casper
PostPosted: 22:26 - 30 Sep 2012    Post subject: Reply with quote
If teh cable version is the same as a pull knob choke then yes. You will have four and held in place with a small circlip.
choonsy
PostPosted: 07:09 - 01 Oct 2012    Post subject: Reply with quote
ok i will have a look at that, and cheers
The last post was made 13 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 16 - Page Size: 43.97 Kb
