New clutch lever killed my Bandit GSF600
RyanTCB
PostPosted: 20:58 - 13 Oct 2012    Post subject: New clutch lever killed my Bandit GSF600 Reply with quote
I replaced my clutch lever on my Bandit. And fudged the rest of the bike. I got no headlights only the faint flash light. I get the oil light but no neutral light. If I put the light switch on full beam I dont get the blue light on. Indicators work. No horn. Not able to turn bike on. Gear lever not clicking through the gears.
Any ideas of how all above might be connected to cause these probs after a simple clutch lever change
PostPosted: 21:00 - 13 Oct 2012    Post subject: Reply with quote
Did it get run over by an artic whilst you were out buying the lever?
Nick_Giles
PostPosted: 10:39 - 14 Oct 2012    Post subject: Reply with quote
Is it a genuine lever or a patten part.?
Is there an electrical switch associated with the clutch.?
Nick
PostPosted: 11:23 - 14 Oct 2012    Post subject: Reply with quote
On the clutch lever side, there will be 2 little rubber looking connectors ... green/blue wires here https://www.xrv.org.uk/forums/attachments/transalp/16678d1327320683-clutch-switch-clutch.jpg
Take them off and connect those 2 wires together. Make sure its in neutral. Hit the starter button Thumbs Up
Islander
PostPosted: 12:30 - 14 Oct 2012    Post subject: Reply with quote
Did you catch the wiring to the switch cluster with the spanner while you were fitting the lever?
lilredmachine
PostPosted: 14:41 - 14 Oct 2012    Post subject: Reply with quote
Islander wrote:
Did you accidentally remove the loom while you were fitting the lever?
Fixed.
RyanTCB
PostPosted: 15:43 - 14 Oct 2012    Post subject: SOLVED! Reply with quote
Thanks all for the replies. I fixed my little problem. I really don't want to post how as its embarrassing but we can't all be bike experts. So with a red face here is what the problem was.
This morning I went back out to have a real good look over my bike with Haynes manual in hand and a volt meter I set about diagnosing these multiple faults (nearly took the day off work so I could finish). I put the ignition key in and this time I got the tachometer needles to move and the neutral light come on. I tried to start and nothing!
Then it hit me and this is the red faced part. My light went in my garage last night whilst I was fitting the clutch lever so I used the headlights of the bike to illuminate the garage. 2 hours later the lights went out but by that time I had fixed the main light in the garage so hadn't notice them die. I flattened the battery Embarassed
Charged it and voila, jobs a gooden.
Islander
PostPosted: 18:02 - 14 Oct 2012    Post subject: Reply with quote
Karma For having the cajones to 'fess up. Laughing
RideLimousin
PostPosted: 19:04 - 14 Oct 2012    Post subject: Reply with quote
This still doesnt explain how you seized the gearbox though Wink
Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340
lilredmachine
PostPosted: 19:12 - 14 Oct 2012    Post subject: Reply with quote
Marvelous! Nice one on the fess up hehe. We've all done stuff like that, even the 'bike experts' Thumbs Up
RyanTCB
PostPosted: 19:24 - 14 Oct 2012    Post subject: Reply with quote
Didn't seize just wasn't engaging.
There is a gap of 208 days between these two posts...
Auzfest
PostPosted: 22:49 - 10 May 2013    Post subject: removing bandit clutch lever? Reply with quote
Got the pivot bolt out and cable off but lever won't come away,seems loose but like there's something there stopping it any ideas?
J.M.
PostPosted: 23:06 - 10 May 2013    Post subject: Re: removing bandit clutch lever? Reply with quote
Clutch switch, unscrew it and the lever will come off.
2004 R1 & 2018 XSR900
Ariel Badger
PostPosted: 23:19 - 10 May 2013    Post subject: Reply with quote
Mr. Green
The last post was made 13 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 16 - Page Size: 84.25 Kb
