Fog and misting up
noobRider
PostPosted: 10:14 - 14 Oct 2012    Post subject: Fog and misting up Reply with quote
Just went for a morning ride and there was a lot of fog about. I was thinking that it was thick when I realized that my glasses had misted up badly Smile Visor up or down didn't make any difference, everything just fogs up really quickly. I was having to wipe my visor every minute or so and stopping now and again to clear my specs.
How does everyone else deal with this? I didn't like driving blind much Exclamation
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
promufa
PostPosted: 11:35 - 14 Oct 2012    Post subject: Reply with quote
I got really fed up of this... Ended up getting contact lenses. Probably the best bit of kit I ever got Very Happy
As for the visor, I have a pinlock so no misting there.. was just my specs.
'02 Triumph Speed Four
noobRider
PostPosted: 12:11 - 14 Oct 2012    Post subject: Reply with quote
I don't want to go with contact lenses. These Pinlock inserts work then? I'll check them out.
U_W v2.0
PostPosted: 12:20 - 14 Oct 2012    Post subject: Reply with quote
any reason for the anti contacts approach?
noobRider
PostPosted: 12:27 - 14 Oct 2012    Post subject: Reply with quote
I tried them once and it was incredibly painful. I'm too used to specs now.
Turkish
PostPosted: 13:27 - 14 Oct 2012    Post subject: Reply with quote
Have the same problem but pinlock doesn't help with the specs fogging up.
Try this. It works by creating a fairly good seal around your nose and cheeks, which directs breaths downward. It's made of a thick neoprene.
It's a bit of a marmite product. I'd never ride without mine, because I can't see for more than 20 seconds otherwise, but some people dont like the way it feels when breathing or they don't have much success.
It is a bit of a pain to get it set up right, bit once you get the nack it's no problem at all. The misting problem started when I bought a new lid, hjc fg-15, if you wear glasses avoid this lid like the plague imo.
ZX-6R G2
CBR125R RW6
iMark
PostPosted: 13:30 - 14 Oct 2012    Post subject: Reply with quote
Glasses should clear up if you open your visor, apart from when your sat still at lights or something.
I use comfys which redirect the breath back up towards my glasses most of the time, so they steam up quite often but clear up when I have my visor open a bit..
K8 GSXR 1000
noobRider
PostPosted: 14:05 - 14 Oct 2012    Post subject: Reply with quote
I usually keep my visor open a tiny bit but this morning everything was just getting covered in water droplets and fog. I need a heated helmet Smile
Ribenapigeon
PostPosted: 16:46 - 14 Oct 2012    Post subject: Reply with quote
I wear some oakley specs for riding and I just pull the off my face a few millimeters so air can circulate behind them which works well for stopping fogging.
Misting is a big problem, imalready making plans to make a heated air blower to fix to my helmet to warm the visor, either electric or using a heat exchanger that wraps around the exhaust pipe or radiator hose. Have to see what I can fettle.
U_W v2.0
PostPosted: 16:55 - 14 Oct 2012    Post subject: Reply with quote
sounds so epicaly dangerous lol
Islander
PostPosted: 17:26 - 14 Oct 2012    Post subject: Reply with quote
It's not as half baked as it sounds. Heating the surface that fogs up to keep it above the dew point is a common method of removing and preventing fogging up. I'd do it electrically though - use some lowish value resistors with a suitable power rating Mr. Green
In fact I've made my own dew heaters for my telescopes Razz
U_W v2.0
PostPosted: 19:47 - 14 Oct 2012    Post subject: Reply with quote
yeah but connecting it to the exhaust/radiator then to your helmet, just sounds rather risky lol. electricly, all well and good if its on its own power or a ciggy lighter socket. easy disconnect in an accident ect.
Ribenapigeon
PostPosted: 20:03 - 14 Oct 2012    Post subject: Reply with quote
I did buy some resistence wire earlier in the year. I read about making a heated visor on a norwegian BMW GS forum. They were dealing with -20 temps though. Trouble is I can't get a spare visor to experiment with anywhere.
As for ahea exchanger. It shouldent be too difficult to do maybe wraping some tubing round a radiator hose. After all that's how car heaters work.
PostPosted: 20:07 - 14 Oct 2012    Post subject: Reply with quote
Tried something similar a good few years ago. While it worked to keep my face warm it just did a very good job of directing air up either side of my nose and steaming my glasses up quickly.
About all I have found to help is controlling my breathing.
Asharin
PostPosted: 20:38 - 14 Oct 2012    Post subject: Reply with quote
I too went the contact lenses route, not due to glasses steaming up though, just got fed up of taking glasses on and off every time I wanted to take helmet off lol.
As for misting, I don't use a pinlock, I just rub Fairy liquid (the original green one) into the inside of the visor until it's clear again..stops it misting up for a few weeks until I have to re-apply. Some say it doesn't work but it does for me.
Not tried using Fairy on glasses, but I suspect it might work as well, best test on an old spare pair of specs though, in case it damages the lenses.
Worth a shot anyway, after all fairy liquid is cheap and has multiple uses Very Happy
Other cheaper detergents don't work though, sadly.
Spudly
PostPosted: 00:24 - 15 Oct 2012    Post subject: Reply with quote
Interesting, I wonder whether you could get enough charge from a couple of piezo transducers to do the job.
The Old Apprentice
DonDino
PostPosted: 07:56 - 15 Oct 2012    Post subject: Reply with quote
I'm using pinlock too, and it works great, no misting on the visor. It DOES mist underneith the pinlock insert though sometimes, which means I have to tilt my head down more than normal to see the dash, but that's a minor thing.
I'm also using specs and not sure about contacts - can't be touching my eyes!! Specs mist up when I stop at lights, traffic etc, so open visor until I get moving again - once you're moving, specs should clear up. If they don't, your helmet is not letting air in/out, open the ventilation holes (if it has any).
First bike: CBF125, Feb. - Oct. 2012
Currently riding: ER-6N since Oct. 2012
i.p.phrealy
PostPosted: 08:33 - 15 Oct 2012    Post subject: Reply with quote
bugger. that's my lid!
i use some pink spray stuff on my glasses and inside my visor, seems to work ok. can't remember the name, got it free when I bought the bike. it's in a little pump bottle and it's pink.
Specs direct do an anti fog coating for glasses, but they quoted me £75 to coat my lenses.
The last post was made 13 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 16 - Page Size: 102.78 Kb
