Seriously dangerous situation or bs?
illuminateTHE...
PostPosted: 19:34 - 15 Oct 2012    Post subject: Seriously dangerous situation or bs? Reply with quote
Right whilst riding my r125cc ive been hearing a constant beeping sound.
So today i decided to head down to a yamaha dealership. I gave the keys to a young Jamaican mechanic working there. After about 8 minutes he came back and told me that the beeping sound was due to my speedo, he then offered to rectify my problem for a price then i said no as the problem was not really a mechanical one more of an irritation which i can live with.
So then he said that my steering bearings were knackered and i needed them replaced sharpish.
I was pretty shocked after he said this as i can steer from left to rift smoothly. Also my bike has only been on the road for around 350miles since i binned it, you should note that i did not buy knackered parts as they looked pretty new and were all inspected/ installed by a mechanic. I personally rolled each ball within the bearing to check for any bumps marks and found nothing. [Parts = the entire front end I.E forks, radiator and yoke etc]
He then told me that its pretty dangerous to be riding my bike as my bars could lock whilst im turning into a corner. He then made me weigh up my option die or get my bike fixed. Yeah also the he quoted me around £150 to solve the so called 'problem'.
sz if you read this on another forum...
symonh2000
PostPosted: 19:47 - 15 Oct 2012    Post subject: Reply with quote
It could cause the steering to be a bit sticky if they are knackered.
get the front wheel up and make sure the steering turns without any rough or notchyness.
Taper roller bearings are the way to go IMO, they need less adjustment, last longer and are pretty easy to fit.
Not done them on an R125, but they took me about 2 hours on a TZR125.
https://www.ebay.co.uk/itm/Yamaha-YZF-R-125-2008-2010-All-Balls-Tapered-Headrace-Bearing-Set-/360491787718?pt=UK_Motorcycle_Parts&hash=item53eefc25c6
Four strokes is two strokes too many.
PostPosted: 19:51 - 15 Oct 2012    Post subject: Reply with quote
You'll have very noticeable notchyness on shot bearings. Odds are on that yours are just a bit too tight. Anyway, if you can't feel it yourself then stop worrying, it's not like they are going to jamb up sudddenly or anything.
Islander
PostPosted: 20:06 - 15 Oct 2012    Post subject: Reply with quote
So you took it in with an electronic fault - your speedo and declined his offer of repair and then suddenly you've got dangerously shot steering head bearings?
I smell male bovine excrement and an opportunist mechanic.
It's easy to check the bearings yourself - just get the front end off the ground and turn the forks from side to side - you're checking for any 'notchiness' - they should rotate freely smoothly without being excessively loose. Thumbs Up
yaigi
PostPosted: 20:08 - 15 Oct 2012    Post subject: Reply with quote
...and if it turns out everything is fine on your bike - name and shame Wink
Raffles
PostPosted: 20:35 - 15 Oct 2012    Post subject: Re: Seriously dangerous situation or bs? Reply with quote
If the mechanic was Jamaican then I reckon that you should seriously heed his warning. He will know what he's talking about when it comes to stuff jammin'
BigDan1190
PostPosted: 20:43 - 15 Oct 2012    Post subject: Re: Seriously dangerous situation or bs? Reply with quote
Dance! Clapping
illuminateTHE...
PostPosted: 20:43 - 15 Oct 2012    Post subject: Reply with quote
I never knew you could just test it by holding the front wheel up... the mechanic certainly did not do this as he just rode it up and down the high street back on forth a couple of times.
Flatbadger
PostPosted: 20:48 - 15 Oct 2012    Post subject: Reply with quote
'Pay or die' sounds like a pressure tactic to me if ever there was one (considering the circumstances you describe). Try taking your bike elsewhere, complaining of the beeping only as see what they say.
You're in ISIS
_mjs_
PostPosted: 20:58 - 15 Oct 2012    Post subject: Re: Seriously dangerous situation or bs? Reply with quote
https://pr0gramm.com/data/images/2010/08/1281382051358.jpg
Islander
PostPosted: 21:02 - 15 Oct 2012    Post subject: Reply with quote
He's not likely to have been testing the bearings lock to lock then. Laughing
You're answering your own question if you think about it. Wink
The last post was made 13 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 16 - Page Size: 74.01 Kb
