I hit the broken-stud jackpot!
PostPosted: 17:40 - 26 Nov 2012    Post subject: I hit the broken-stud jackpot! Reply with quote
Removed a set of Bandit headers yesterday - how many of the bolts snapped just below the head you think? All bloody eight of them!
Better do the lottery this week my luck's sure to turn sometime soon.....
DrDonnyBrago
PostPosted: 18:41 - 26 Nov 2012    Post subject: Reply with quote
I do not envy you at all Laughing .
h00dwink
PostPosted: 18:50 - 26 Nov 2012    Post subject: Reply with quote
started taking my SR125 apart yesterday. it would appear that metal turns to cheese when left to chill out.
sheared an exhaust bolt. rounded off plenty of allen bolts and mounting nuts.
nut splitting tool in post to get some revenge.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
pepperami
PostPosted: 18:57 - 26 Nov 2012    Post subject: Re: I hit the broken-stud jackpot! Reply with quote
Either you have the skills of a Gorilla or that has to be the worst luck in the world!
Do you think you are going to be able to save that head?
wilz1234
PostPosted: 19:15 - 26 Nov 2012    Post subject: Reply with quote
It's a sign.....
...that you never really needed that exhaust anyway
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
PostPosted: 20:18 - 26 Nov 2012    Post subject: Re: I hit the broken-stud jackpot! Reply with quote
These bolts were never coming out. Strange as they looked in such good condition, but I could see the neck twisting as soon as I put weight on the tool.
Of course I'll save the head - watch this space...
Nick 50
PostPosted: 20:31 - 26 Nov 2012    Post subject: Reply with quote
Pro-bolt do lots of Titanium bolts for all-sorts, except studs/nuts (AFAIK).
Does anyone know why not?
I think it can be done:
https://titanclassics.com/images/small/full%20exhaust%20manifold%20kit.jpg
That's a Titanium set for a Pre-90's Mini which is £35.
I would happily pay £50'sih for a Titanium set knowing (or hoping) never to have the problem.
PostPosted: 20:56 - 26 Nov 2012    Post subject: Reply with quote
Titanium isn't wonder-metal. Studs and bronze/aluminium bronze nuts are best. I quite like the Yamaha idea of round nuts on the studs that seem to be able to resist a frozen joint by covering the whole of the thread. Putting a steel bolt in an ally head and exposing it to road salt seems a bit like lunacy to me.
Frost
PostPosted: 21:15 - 26 Nov 2012    Post subject: Reply with quote
These days i wire brush the shit out of them, give them a drop of penetrating oil and leave them overnight. The next day i start the bike up and get the headers as hot as they'll go before attempting the nuts. I've also been known to whack them with a hammer first in the hope of losening them! When it comes to undoing them i like to do it with a breaker bar and a smack from a hammer. In my mind i imagine the stress crack in the stud spreading the whole time the torsion is on them and imagine that the sharp tap frees up the friction stuck thread Thinking
Reassembly involves a fuck tonn of copper grease Laughing
PostPosted: 22:05 - 26 Nov 2012    Post subject: Reply with quote
Bandits use socket caps, not so easy to get the shock into them nor crack with a breaker. This bike is peculiar because it's clearly not been winter-ridden and the finish on the engine is still quite good for a 1996 bike so you would expect it to free up nicely but those bolts were solid in there. Couldn't start the engine as the exhaust was off and I fancy keeping my gonads.
Last two Bandits I pulled all the bolts without breaking a single one.
PostPosted: 22:44 - 26 Nov 2012    Post subject: Reply with quote
Here's the remedy - or the start of it anyway:
https://www.bikechatforums.com/viewtopic.php?p=3405144#3405144
wilz1234
PostPosted: 23:21 - 26 Nov 2012    Post subject: Reply with quote
Studs are normally made of plain old steel because when they snap, they're a lot easier to drill out/remove. Imagine having to drill out a 12.8 steel or titanium stud.
Frost
PostPosted: 23:55 - 26 Nov 2012    Post subject: Reply with quote
So you drill the hole down the centres, then widen it, then use a thread tap to clear out the thread?
What about ones that snap off flush?
wilz1234
PostPosted: 23:59 - 26 Nov 2012    Post subject: Reply with quote
I tend to find that 12.8 hardened bolts knacker drill bits very quick because they're kinda...um....hard
PostPosted: 00:21 - 27 Nov 2012    Post subject: Reply with quote
Can't use this method for that. Either make a drill guide which clamps on the opposite bolt or drill it free-hand.
Nick 50
PostPosted: 00:34 - 27 Nov 2012    Post subject: Reply with quote
The reason I suggested Titanium is due to having a higher UTS and being able to sustain more strain and therefor not actually snapping.
It is far more corrosion and fatigue resistance so is not as likely to degrade in our climate.
I would suggest steel is more likely used as it is far cheaper and possibly a bit of planned obsolescence thrown in for good measure.
Frost
PostPosted: 00:48 - 27 Nov 2012    Post subject: Reply with quote
The problem with titanium is that though no indestructible (especially at the piss poor grades used in motorcycle parts and accessories!) It will still be tough enough to make it a total twunt to drill out or otherwise work with should it break.
The last post was made 13 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.62 - MySQL Queries: 16 - Page Size: 101.3 Kb
