Zxr 400 cutting out
Symon27
PostPosted: 23:29 - 02 Dec 2012    Post subject: Zxr 400 cutting out Reply with quote
So basically my 400 keeps cutting out, it's something electrical as if is just ticking over an I put the full beam on it will cut out, all lights go off then back on after a secound or two. This only happens now and then
And sometimes when I rev the bike with dipped beam the lights become dull, instead of getting brighter if reved. I've check all connections and all look fine.
Any thoughts?
Honda Nsr 125 - Sold
Zxr 400 - Sold
Bandit 600 - Current (Y)
orac
PostPosted: 23:59 - 02 Dec 2012    Post subject: Reply with quote
check the reg/rec and battery. its either of them or you have a short some where on the lighting circuit
does it start OK?
CaNsA
PostPosted: 00:27 - 03 Dec 2012    Post subject: Reply with quote
Check the main live wire that runs through the loom.
I was having the same probs, pulled the loom off, and fixed a few corroded wires.
Job done!
Symon94
PostPosted: 15:07 - 03 Dec 2012    Post subject: Reply with quote
reg/rec and battery is fine.
Will check the live when im back from work.
jjdugen
PostPosted: 16:06 - 03 Dec 2012    Post subject: Reply with quote
Can't remember where exactly, but a good few of the older Kwaks have a thin earthing wire from the loom to the battery. This can fracture and give the symptoms you have. The wire comes from the loom near the battery is all I can remember..
The last post was made 13 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 42.75 Kb
