Location of CDI on NSR
wantser
PostPosted: 15:49 - 09 Nov 2004    Post subject: Location of CDI on NSR Reply with quote
Just got myself a CDI unit to replace my restricted one and was wondering if anyone can tell my where to find the other one so I can replace it. .... I have had the carb out etc, but cant remember seeing it anywhere. Help would be good before I try tonight and get home to stick my head in the manual!! I also need a new coil before I run it first. Is this around the same area....?
Novice bike mechanic
wantser Razz
An expert is a person who has made all the mistakes that can be made in a very narrow field
wantser
PostPosted: 15:50 - 09 Nov 2004    Post subject: Reply with quote
Apologies......I've accidently put this in the wrong forum.... Embarassed
stryker
PostPosted: 15:53 - 09 Nov 2004    Post subject: Reply with quote
Not only that, the CDI is usually under the riders seat, near the battery.
Now what?
wantser
PostPosted: 16:07 - 09 Nov 2004    Post subject: Reply with quote
Embarassed will have a look later...... also...coil is the lead. So I shall retract my question and wait for the red to dissapear from my cheaks. Embarassed
mr jamez
PostPosted: 16:16 - 09 Nov 2004    Post subject: Reply with quote
On the old NSR it is under the fuel tank, on the newer fox eye models it is under the seat.
ZaphodBeeble
PostPosted: 00:29 - 10 Nov 2004    Post subject: Reply with quote
There's also the RC servo controller which is under the airbox, don't confuse that with the CDI Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
c058y
PostPosted: 15:58 - 10 Nov 2004    Post subject: Reply with quote
I have changed my cdi also in my NSR! I know the other guys said it was under the seat, but to be more accurate it is just in front of the rear lights. I found it a bugger to get out unless you remove the fairing panels at the back.
neon
PostPosted: 18:19 - 10 Nov 2004    Post subject: Reply with quote
ok can someone explain what the CDI is, i just brought a brand new nsr and was wondering what the CDI does and how do i change it, its a UK one and i think a heard someone say the UK ones arn't restricted in the CDI, can someone confirm this? ta
PostPosted: 18:24 - 10 Nov 2004    Post subject: Reply with quote
The cdi units main role is to control the ignition timing. Most UK models have no restriction in the cdi unit, although the imports from some countries are restricted and some people seem to have had problems with late UK market bikes.
You can try changing it, but you need to be very certain you get the correct one. There are several people on here who have bought a replacement cdi to get round the restriction and have had it work fine for a very short time after which the cdi unit has failed. Not sure why, but my guess would be that something else needs to be changed (maybe the coil, maybe the power valve control unit), and if you don't they draw too much current and burn out some of the circuits in the cdi unit.
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 63.13 Kb
