| ttboy1988 |
 ttboy1988 Two Stroke Sniffer
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 02:59 - 10 Jan 2013 Post subject: |
Take it back to where you had it serviced and explain to them the problem.. ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| Imonster |
 Imonster World Chat Champion
| ttboy1988 |
 Posted: 03:33 - 10 Jan 2013 Post subject: Re: Engine Jerking after a service on a ybr 125, please help |
| Imonster wrote: | | ttboy1988 wrote: |
If i press the clutch down and let the bike roll at a certain speed you can hear the engine jerking, This was not an issue prior to the service.
No sound from the engine when it just on, only when throttle is engaged
Forgive me if I'm being thick due to the unholy time of the morning, but the two above statements seem to be contradictory? If the clutch is engaged, then the engine will be idling exactly the same as it would be when the engine is on without the throttle being engaged...
At a long shot guess though, they've tightened your chain to the recommended variance, but you've got a tight spot in it that's causing the feeling of jerkiness in the engine. Just a guess mind - as said, take it back and see what they say. |
Sorry i dont think i made it clear, when i am crusing along at 30mph and when slowing down and then i press the clutch the down and while slowing down just to hear the engine. you can hear is jerking.
I can also hear some chain noise as well. I might just take it down to them, i have a feeling that its been tightened too much |
| trevor saxe-coburg-gotha |
| ttboy1988 |
| Teflon-Mike |
 Posted: 07:09 - 10 Jan 2013 Post subject: Re: rubbing noise |
| ttboy1988 wrote: | What i mean by jerking is, its like hiccups witha 3 seconds gap, when the throttle is ingaged or (clutch pressed down while slowing down). . |
Trying to understand your symptoms from your description is, I am afraid tortiouse. You are not doing a lot to help us help you here.
BUT... comment bolded strikes chord of worry.....
I presume that you mean AS you are slowing down, you have the clutch 'in' drive removed from the rear wheel....
WHY!?
You should NOT be doing that. If the bike is moving, unless you are changing gear, the clutch should be engaged, the back wheel being driven.
Clutch ONLY goes in when you are ALMOSTR at a dead stop, or BRIEFLY while changing between gears.
What you are doing, by the sounds of it is 'Coasting' or 'Free-wheeling', and it is BAD.
You are denying yourself engine braking, for a start off, as well as control, and balence. Bikes hold themselves up as long as there is force on the driven wheel; take that force away and you have halved the stability.
I SUSPECT, that the reason you are doing this, is also becouse you are short-shifting, and using too high a gear to begin with, and you are making work for yourself having to come down so many gears when you slow to a junction..... also bad... bike should be in a 'responsive' gear, and at 30mph or so you ought not really need a gear higher than second or third. But I shall wait for you to elaborate on that suggestion.
Meanwhile; 2011 YBR.... I have a feeling that;s the change-over year between carbs and fuel injection; could be a late registered carb model or early registered fuel injection model.
BUT: if its a fuel injection model..... moment you pull the clutch in, the fuel injection system will go to the 'idle' setting, presuming that the bike is 'stationary'... but its not, you are free-wheeling....
Injection system is chucking fuel into the motor JUST to keep it turning, when IF you had the clutch out, it wouldn't need to... back wheel would be making it keep rotating through the gearbox...
So you are wasting petrol to keep the engine turning, rather than using momentum, and worse, rather than using that engine to waste your momentum, keeping it turning, you are wasting that momentum with the brakes, so you are burning MORE fuel to wear out MORE brake pads and ride LESS safely!
Before going back to the garage, who if you try explaining your problem as clearly to them as you did to us, will be just as perplexed and confused....
Try riding the thing properly...... see whether the 'jerkiness' goes away..... I suspect it probably will, but I will wait and let you report back. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Rogerborg |
 Rogerborg nimbA
The last post was made 13 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
